2 jbl d120f's + 2 greenbacks ,X pattern or not?
Discussion in 'Cabinets & Speakers' started by Exotic, Jan 3, 2020.
  1. Exotic
    Exotic Active Member
    Sep 3, 2018
    344
    156
    what is the best even sound distribution download (Mobile).jpg IMG_1967 (Mobile).JPG to blend 2 jbl d120f's and 2 greenbacks in a 4x12 cabinet ,same 2 speakers on top row? or x pattern ?
  2. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    843
    800
    I would say X for an even sound dispersion. With 2 & 2 you'll pick up on 2 different sounds depending where your ear is.
  3. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    605
    459
    Edward and Duane both put the JBLs on top.
    But EVH always stacked multiple cabs. And Duane always put his single slant cab on top of a road case, so the JBLs were pointed up away from his ears.
    Using a single cab on the floor, X pattern will work better. (And since your other cabs don't have JBLs, X pattern probably would work better even if you put the JBL cab on top.)
    You've already tried the JBLs on top and decided you liked the X pattern better. You're not using the same amps as EVH or Duane -- there's no reason to load the cab Eddie-style unless you're going to replicate his whole multi-amp multi-cab rig.
    Kinkless Tetrode likes this.
  4. RLW59
    Nov 30, 2017
    605
    459
    You might try both JBLs at the bottom.
    I've often run a mix of efficient clean speakers (EVMs, C/Vs, JBLs) with dirtier less efficient Greenbacks/G1265s, and putting the clean loud ones on the floor with the warmer quieter ones up top helps to balance them.
    Both Eddie and Duane put their Celestions at ear level, with the JBLs pointing up above their ears -- by stacking or raising their cabs.
    But with one cab on the floor, putting the JBLs at the bottom accomplishes the same thing -- balances out the different efficiencies of the speakers.
  5. Exotic
    Sep 3, 2018
    344
    156
    very good ideas thanks
