2 - 12 speakers different wattage
Discussion in 'Cabinets & Speakers' started by oldmanrockin, Jul 15, 2019.
  1. oldmanrockin
    oldmanrockin Member
    Feb 22, 2017
    78
    39
    I am using a vintage 30 and a G12H-30 in a 2x12 cab. I know the vintage 30 should be louder, but am wondering if there will be any amp issues using them. Both are 16ohm wired separately to make 8ohm load, two jacks each one to a speaker, two speaker cords. When playing them i dont notice the vintage being noticebly louder. Playing out of a 40c on full power.
  2. Dogs of Doom
    18,618
    17,892
    both speakers should match in volume, for the most part. If they are both 100db efficiency, they will play the same volume, watt for watt. The only thing to keep in mind is that, when you mix speaker power, that you must rate the speakers by the lowest watt speaker.
    So, if you have, 2- 30 watt speakers, you multiply the watts by the amount of speakers. 2x30=60 watts total. If you have a 30 & a 60 watt speaker, you must rate the speakers both at 30 watts, then multiply, so having a 30=60, would be 30x2=60 total, even though the 1 speaker is 60 watts.
    The whole point is that, if you don't follow this guide, you run chance of blowing the lower powered speaker, then you'll have a mismatched cabinet ohm-wise.
  3. oldmanrockin
    oldmanrockin Member
    Feb 22, 2017
    78
    39
    Thats what i thought. So playing 2-30 watt speakers with 40 watts should be ok. I kinda like the tone the two give.
  4. Dogs of Doom
    18,618
    17,892
    V30=60 watts
    H30=30 watts
    but, yes, you lower the rating of the 60 watt to 30, so your cab will be:
    30x2=60 watts
    40 watts will be easy enough to handle...
  5. mickeydg5
    21,155
    8,835
    As Dogs mentioned the 2x12 is good for 60 watts, so the DSL40C works with that.
    60 watts rating has nothing to do with volume/loudness. That is a power handling rating. It can handle up to 60 watts or 30 watts or whatever a speaker's specifications indicate.
    The speaker specification that give indication to efficiency and loudness is the SPL rating. Both of your speaker types average 100dB.
    I like a Vintage and G12H(55) mix.
    oldmanrockin likes this.
  6. oldmanrockin
    oldmanrockin Member
    Feb 22, 2017
    78
    39
    It seems like the v30 is a bit more "meaner sounding" than the G12, i kinda like the two together.The g12 is more mellow sounding to me.
  7. mickeydg5
    21,155
    8,835
    They are different G12 30 watt speakers. Which model do you have?
  8. oldmanrockin
    oldmanrockin Member
    Feb 22, 2017
    78
    39
    I actually have the helatone30 and 60. I am not sure. He lists them as just G12H-30's. They have the same magnet as the v30 or helatone60.
  9. mickeydg5
    21,155
    8,835
    Oh, I believe that is supposed to be a G12H Anniversary. It is described as being a bit milder on the upper ranges.
    The Vintage 30 is more aggressive there.
