1x12 Cab Rebuild Project
Discussion in 'Cabinets & Speakers' started by KraftyBob, Aug 17, 2018.
  1. KraftyBob
    KraftyBob Well-Known Member
    Sep 5, 2017
    1,380
    1,798
    Chicago Suburbs - USA
    Finally got around to finishing this. A few months back I bought a headless MG250DFX to refurbish and convert into a 1x12 speaker cab. I bought it to use with my DSL40C since there aren't a lot of options for 1x12 cabs that are as wide as the DSL. I put a G12T-75 in the cab and have the G12M-65 Creamback in the amp. I like how to two speakers compliment each other.
    All in I spent $135 USD:
    - $30 for the cab
    - $40 for a used UK G12T-75
    - $25 for the Birch plywood (new baffle)
    - $40 for grill cloth, piping, speaker jack & plate, etc.
    Side story - after I bought the cab and got it home I opened the back expecting to find low end MG speakers. To my surprise it had two V30's in it. My excitement was short lived, however, as one had voice coil rub and the other measures 7.3 ohms for 16 ohm speaker. I don't like V30's so I was hoping to sell them and pay for the cost of my project. Oh well.
    Here's what I started with - definitely has some miles on it.
    Cleaned up, Tolex repaired, and holes to mount the head plugged
    MG's don't have piping so I added it to match my DSL
    Jig used to cut the speaker hole
    T-nuts glued and pounded in, logo and mounting holes drilled. Ready for sanding and painting.
    Grill cloth added
    Finished.
    New rig.
    hanknc, ibmorjamn, tschrama and 11 others like this.
  2. Dogs of Doom
    21,423
    22,929
    looks good!
    stringtree likes this.
  3. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,642
    2,563
    WOW thatis some damn fine work, great job!
    How does it sound now?
  4. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,378
    2,303
    Nicely done!
    Let 'er rip!
    Russ
  5. Kutt
    Kutt Well-Known Member
    May 27, 2010
    1,098
    1,516
    Massachusetts, USA
    Excellent work and a great idea overall. Kudos to you.
  6. KraftyBob
    Sep 5, 2017
    1,380
    1,798
    Thanks! The mix of the two speakers is definitely it’s own sound - for the better on my opinion. I’ve always liked the T75 so when I saw it on LetGo I jumped on it. The Creamback is a little warmer, more mids while the T75 brings out the low end. I’m not hearing the highs that some people dislike. I used to keep the DSL on a stand but now that the cab is on the floor I can feel the low end at much lower volumes.
    Next time I’m home alone I’m going to try and do some recordings. The only problem is I don’t have an SM57, rather a Samson Go mic. It’s surprisingly good for the cost but not the audio quality of the SM57 so we’ll see how it turns out.
  7. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,885
    4,716
    Lakeland, TN
    Looks good, so good job!
  8. KraftyBob
    Sep 5, 2017
    1,380
    1,798
    Here's an audio clip comparing the speakers. It's recorded with a Samson Go Mic so it's not the most accurate replication of the tone, but I think it captures the differences well enough. Also, I could only record the OD with the volume at 1 so the amp isn't really breathing at this point. There's a lot of detail in the description on YouTube.
  9. Trident
    Trident Well-Known Member
    Mar 8, 2018
    1,190
    1,605
    Paradise in FLORIDA
    Nice job!
    stringtree and KraftyBob like this.
  10. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    7,555
    5,410
    North
    That is Krafty Bob , nice !
    KraftyBob likes this.
  11. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,687
    1,632
    Is there a logic behind the off-centre speaker placement?
    Or were you leaving space to possibly turn it back into a combo at a later date?
  12. clutch71
    clutch71 Well-Known Member
    Sep 26, 2007
    1,591
    1,034
    Columbus, Ohio
    Good looking project! Well done!
  13. KraftyBob
    Sep 5, 2017
    1,380
    1,798
    The speaker is centered left to right, but on the lower half of the baffle to make room for the logo. I bought it without the head as the guy was using it as a 2x12 extension cab.
    I keep threatening to convert my DSL into a head, and if I do I’ll make a new 2x12 baffle. I can’t use the 2x12 baffle from the amp as it doesn’t cover the entire front because of where the head used to be.
