1995 100watt Slp Super Harsh
Discussion in 'Marshall Amps' started by DannyB, Jul 7, 2018.
  1. DannyB
    DannyB Active Member
    Feb 6, 2018
    259
    113
    2 mi from Jim Beam, KY
    Me and search are not getting along, so a little help please!
    This amp is incredibly harsh to point of being useless with volume at 3 or higher.
    Would someone point me to the thread or threads I need to review?
    Or maybe it’s as simple as lifting a leg of a cap.
    Any help greatly appreciated!
  2. anitoli
    anitoli Well-Known Member
    6,512
    7,144
    Harsh as in brittle highs and crakling lows? Prolly needs power/preamp tube.
    The Ozzk likes this.
  3. Yugedrums
    Yugedrums Well-Known Member
    May 7, 2015
    344
    263
    South Carolina
    How are you using it, as in... which channel, high-treble, normal, jumpering both?
  4. DannyB
    Feb 6, 2018
    259
    113
    Both channels jumped. But its also harsh on individual channels.
    It has a new full set of JJ tubes. Not my choice at all.
  5. jlinde1973
    jlinde1973 Well-Known Member
    Dec 22, 2011
    511
    313
    Traverse City, Michigan
    JJs should take away from the harshness if anything. You should check your bias for starters. Overly hot bias can sound very harsh as well as overly cold. Hopefully the amp isnt all modded to hell.
    Trelwheen, The Ozzk and DannyB like this.
  6. DannyB
    Feb 6, 2018
    259
    113
    What is a good ballpark figure for bias?
    I run my HJS and TSL 100 around 75-77mils
  7. ampmadscientist
    13,434
    7,290
    Yes I hear this all the time....
    The amp must be played on 7 or higher, to drive the output tubes into distortion.
    This will make the amp incredibly loud.
    But this is the only way to play a Plexi.
    If you play the amp on "3," you have missed the point of a Plexi entirely. Plexi is a VERY clean amp.
    Until it is pushed to maximum.
    This is why the amp sounds "harsh."
    A. Play amp fully cranked.
    B. Use bridge pickup, and move pickup close to strings.
    C. Reduce loudness with attenuator, less speakers, Fluxtone speaker, or several methods. (one method is change output to Triode 40 watts)
    D. Change preamp to 2203, and install PPIMV.
    E. use high gain selected preamp tubes (makes a big difference)
    But if you keep playing amp on "3,"
    you missed the boat dude.
    Marshall is a different animal, it's not like other amplifiers.
    Plexi is not made for that application.
    It will always sound harsh, until you CRANK it and play it as God Herself intended.
    If you do not want to re-learn....you bought the wrong amplifier.
    Face the facts
    Plexi was made for stadiums, not bedrooms.
    You are trying to make it do something that it was never intended to do.
  8. AlvisX
    AlvisX Well-Known Member
    May 31, 2011
    3,936
    6,834
    I-55 Corridor
    It's the Gotdamn brite cap and that .0022 coupler
    Cut the brite cap value in HALF (dont remove) and change the .0022uf to .022uf ....you'll have a rock n roll machine
    This is of course MY opinion (the sh*t works) , I have been drinking, as my yard was just broken into and tools stolen ,so Im in a belligerent-er mood than usual :lol:
  9. mikebinthesky
    mikebinthesky Member
    Feb 23, 2018
    37
    33
    Not much worse than a thief-sorry dude
    DannyB likes this.
  10. DannyB
    Feb 6, 2018
    259
    113
    As I said, 3 and higher, as in 8 ran into RockCrusher attenuator. It’s harsh every where. I could have explained that better.
  11. neikeel
    3,404
    1,846
    What speakers and guitars?
  12. DannyB
    Feb 6, 2018
    259
    113
    Gibson Les Paul and 335. Using older, pre-China 4x12 w/Greenbacks
  13. mickeydg5
    22,109
    9,589
    Is a sound clip possible?
    How long have you had the amplifier?
  14. Yugedrums
    May 7, 2015
    344
    263
    South Carolina
    Not sure "harsh" is specific enough for an accurate diagnosis... many would say the high-treble channel alone is harsh, especially below 3 or 4. Once cranked up however, it's "the sound" since the bright caps get cut out the higher you go and the output tubes start to break up... tone nirvana. :hbang:
    The normal channel is usually the complete opposite of harsh, very dull and smooth. When using a jumper and blending the two channels to taste ("EQ'ing" them essentially), you can usually dial in an acceptable and non-harsh tone.
    The best Plexi sound (in my opinion), is high-treble channel alone, cranked past 4-6 (if you can stand to be in the same house with it). Jumpering the channels at those volumes gets a little muddy to me.
    I can't speak to the added effects of running it through an attenuator though, as I've never used one.
    But yes, more specific descriptions and/or sound clips would help tremendously.
    DannyB likes this.
  15. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,195
    1,886
    75 mA for EL34's? What is the plate voltage?
    Russ
  16. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    4,818
    2,868
    Bay Area, CA
    Are you talking about insanely bright and cutting? I know a lot of Plexi owners sniping off the bright cap altogether...
    DannyB likes this.
  17. DannyB
    Feb 6, 2018
    259
    113
    Re-biasing helped! Not a cure-all, but helped!
    Next up, bright caps!
    I greatly appreciate all the responses!
    You folks are great!
