1992LEM vs 1973 Super Bass
Discussion in 'Marshall Amps' started by Clammy, Dec 20, 2013.
  1. Clammy
    Clammy Well-Known Member
    Feb 24, 2010
    2,247
    1,619
    Today, I A/B'ed the 1992LEM head against my main 1973 Super Bass (bone stock). The settings were the same (Lemmy's preferred):
    Presence -8
    Bass - 0
    Middle - 10
    Treble - 0
    Volume I - 8
    Volume II - n/a
    Both heads were plugged into my JCM 800 Bass Series 4x12 and 2x15 cabs. I used my '76 Rickenbacker 4001 (set to the DiMarzio X2N-B bridge pickup) plugged into the Channel 1 high input. No effects, just the bass straight into the amp. I used my Zoom H4, about 5 feet away and about waist height, to record the clips. Between head changes, I didn't move it or change any settings. No eq'ing or post processing. The song is Ace of Spades (of course ;) ). The first couple of notes are chopped off, because I was playing to the track (using my mp3 player and in-ears), and didn't have a count in.
    Some personal observations: Setting the heads the way I did, and using my Rick copped Lemmy's live tone bang on. The 73 Super Bass head is WAAAY louder than the 1992LEM (this MAY have to do with the fact that the 73 has NOS Mullard xf2 EL-34 power tubes, and is biased to 70%, and the LEM head is running the stock Svetlana EL-34s, and is at the factory bias, which I understand is usually pretty cold. Both amps have NOS Mullard ecc83s in the preamp. Another possibility is that the plate voltage on the 73 is higher than the LEM, but I haven't actually measure the LEM yet, so that's pure speculation). When you listen to the tracks, the volume difference is strictly from the different amps. The 73 is SO loud at 8, that it overloaded the H4 mics! Overall, I'm not TOO happy with the quality of these recordings, but they give you an idea of what these amps sound like cranked up, hehehe...
    Enjoy! :p
    1992LEM:
    https://soundcloud.com/clammy69-1/1992lem
    1973 Super Bass:
    https://soundcloud.com/clammy69-1/1973sb
    Cheers!
    :hbang::hbang::hbang:
    thecasterkid and Marshall Guru like this.
  2. damienbeale
    damienbeale Well-Known Member
    Mar 1, 2013
    3,798
    1,754
    Oxford ish sorta...
    So aside from the personal observations and settings, which one gives the biggest grin factor, Clamster?
  3. Clammy
    Feb 24, 2010
    2,247
    1,619
    They both do, but the 73 rattles my teeth! :D Don't get me wrong, the LEM is loud... but the 73 is LOUD!!!! :shred:
    Cheers!
  4. whatsacleantone
    whatsacleantone Active Member
    Dec 7, 2013
    540
    162
    the EQ settings made me lol. this rules!
  5. Metalway
    Metalway Active Member
    Jun 22, 2012
    142
    85
    Quebec, Canada
    To me Lemmy's head got a bit more definition, but the super bass is way louder...So much power...
    Both heads are cool anyway.
  6. Clammy
    Feb 24, 2010
    2,247
    1,619
    The Super Bass was actually a little more defined, but it was so loud it clipped the mic input of the H4, so it sounds compressed on the recording.
    Cheers!
  7. Metalway
    Jun 22, 2012
    142
    85
    Quebec, Canada
    Good to know, with the recordings I thought it was Lemmy's head with more definition. It's alway best to hear it live.
    The volume at 8 must have been painful for your neighbors...:lol:
  8. Clammy
    Feb 24, 2010
    2,247
    1,619
    Even with the bass at zero "earth-shaking" is not even a tiny exaggeration! :D
    I've recorded the whole band at rehearsal (where we play LOUD) with the H4, and the mics never had any problems, but the 73 at that volume just totally overloaded them!
    Cheers!
  9. Metalway
    Jun 22, 2012
    142
    85
    Quebec, Canada
    It's one of the joy to play bass with a Marshall...you never short of volume power. Almost sad for those who play with Ampeg...:lol:
  10. Metalway
    Jun 22, 2012
    142
    85
    Quebec, Canada
    What's your opinion if you compare Lemmy's head with the VBA 400? 2 different beast aren't they?​
  11. Clammy
    Feb 24, 2010
    2,247
    1,619
    Yeah, very different voices. Both are amazing amps, though!
    Cheers!
  12. dreyn77
    dreyn77 Well-Known Member
    Feb 18, 2012
    12,559
    2,854
    SO! you're using the SAME guitar! the SAME pickup! and one is WAY louder!
    Well, 'he' did say it has the 'digital' front end...
    You need to have 'active' pickups and 'Boss' effects for the front.
    Is it about 'half' as loud?
    sound's like 'half' the voltage? sounds like NOT the FULL sinewave? I wonder about you....?
  13. dreyn77
    Feb 18, 2012
    12,559
    2,854
    It's the OLD 'signature' trick!
    "I can't make a buck from sombody else's product".
  14. LMP2204
    LMP2204 Active Member
    Dec 31, 2011
    179
    59
    The Clem
    Nice clips, The 73 definitely sounds more Lemmy only because its clipping the mic. However I think you should check the bias of the LEM and play with it. it should be just as loud as the 73. A local guitar shop has a new LEM1992 in stock by my house and im tempted to go in there and plug in a guitar and give it a test. I really wanna hear a guitar into it just because everybody uses them for bass only. but I imagine it would sound kick ass with a Les or Strat plugged in. Glad to hear some coverage of the lesser known marshalls!! Wish marshall would Do some reissues of the later 70's jmps.
  15. Clammy
    Feb 24, 2010
    2,247
    1,619
    I mainly play guitar through my Super Basses, and they sound amazing as guitar amps. The same with the Lemmy head. I will be checking the bias on her, and see if that makes a difference.
    Cheers!
  16. dreyn77
    Feb 18, 2012
    12,559
    2,854
    Oh, internet blindness. I see!
    hahahaha
  17. Clammy
    Feb 24, 2010
    2,247
    1,619
    Do me, and those who are interested in this topic a favour, and keep your demented spewing out of it.
    Thank you.
  18. dreyn77
    Feb 18, 2012
    12,559
    2,854
    well when you get it right (in a few years) you'll be chucking one or both amps into the rubbish!
    I can see it now! FUNNY GUY! hahahahaha. (he bought a quiet amp folks! said it himself, he did!)
  19. damienbeale
    Mar 1, 2013
    3,798
    1,754
    Oxford ish sorta...
    MODS...
    I for one am growing very tired of this paranoid, delusional, hallucinating buffoon...
    bulldozer1984 and Clammy like this.
  20. Blueslicks
    Blueslicks Well-Known Member
    Mar 10, 2011
    1,681
    1,043
    Dude, with all due respect...
    Clammy is an actively gigging and seasoned pro. The guy actually does play large arenas and festivals which can be easily verified online.
    He's the real deal and not only owns a wall of stacks but consistently uses them for their intended purpose. This is a valuable asset to a forum like this where people can actually gain knowledge from someone who can attest to matters accurately and with hard won wisdom.
    You dude are just another internet mouthpiece with quite obviously very little knowledge of how these amps perform when wheeled out of a basement and into a venue.
    There is an old saying, I believe it was by Abe Lincoln which states...
    "Better to remain silent and be thought a fool than to speak out and remove all doubt"
    For you it is much too late.
    I suggest you retire your name, come back as a new member and try again.
    Please STFU and know your role.
    Clammy, damienbeale and Metalway like this.
