1990 Fender Red Knob Twin Intermittent Siren Like Sound And Crackling
Discussion in 'The Workbench' started by jalexquijano, Jan 23, 2018.
  1. jalexquijano
    jalexquijano Member
    May 25, 2009
    266
    2
    My 1990 red knob twin produces a 5 seconds siren like sound with some crackle when the amp is warming up during the initial 45 minutes of playing. Its intermittent and its produced even without a guitar cable plugged in. Could this be a preamp tuve in v7 or v1?
  2. Len
    Len Well-Known Member
    Sep 13, 2009
    922
    625
    Crackling usually means a bad tube, dirty tube socket or cold solder joint at a tube socket.
  3. ampmadscientist
    10,835
    5,027
    Whereabouts Unknown
    A bad preamp tube is a possibility but,
    Sometimes w/ this amp
    broken or cracked controls or connections, oxidized jacks.
    The last one I worked on had a broken control....and it squealed (like a siren) intermittently.
    For some reason this amp had a problem with the controls breaking....and the controls were discontinued. But there is some substitutes around that you can install.
  4. jalexquijano
    jalexquijano Member
    May 25, 2009
    266
    2
    well i changed V7 preamp tube which is the first stage preamp. i will buy a magnifying glass and check all connections once again.
  5. jalexquijano
    jalexquijano Member
    May 25, 2009
    266
    2
    would you recommend JJ 12ax7 or sovtek 12ax7b for this high gain combo amp?
