1988 Marshall 2205 Questions
Discussion in 'Marshall Amps' started by mulletmule, Nov 13, 2019.
Tags:
  1. mulletmule
    mulletmule Active Member
    Nov 19, 2013
    303
    153
    Rochester NY
    Hey Guys! I just got 1988 JCM 800 2205. I'm pretty sure its stock but holy gain!! I had bought a later 80's model because I was told they were the more desirable ones. Not sure if that's valid but I did read they had more gain.
    Anyway what settings are recommended? I had been told treble and prescence at 0 but that doesn't sound good.
    Thanks for the help!
  2. Buzzard
    Buzzard Well-Known Member
    Sep 14, 2016
    815
    889
    Congrats! Awesome amp. I’ve got an 87’ 2205. It’s like an 800 on steroids. Remember it’s got 3 volumes that work together. It can go from 800 levels of gain to way more if needed. Instant Schenker tone also. I haven’t played mine in a while but I don’t remember it needing any extremes on the eq. Seemed pretty easy to get a great tone.
    mulletmule and Mitchell Pearrow like this.
  3. mulletmule
    Nov 19, 2013
    303
    153
    Rochester NY
    Thanks! Actually with everything on 5 seems to be a good starting point. Killer amp
  4. EADGBE
    EADGBE Well-Known Member
    Dec 13, 2009
    434
    274
    My favorite settings for a Marshall are treble 10, middle 0, bass 10. Gain 7-10, presence 10. Volume, wherever you want it. Another setting you could try is bass 5.5, treble 8.5 . Middle 4-6.
  5. RickyLee
    May 22, 2010
    9,540
    3,034
    Riverside CA U.S.A.
    For that Boost channel, I like to run that channel volume hot, 7 to 10. Gain 6 to 7. I run the EQ pretty much the same as all my other amps. Treble 6 ish, Mid around 4 and Bass around 4. My '88 2205 is bass heavy for sure.
    If you want the Normal channel to act more like a Clean channel, try a 12AY7 in V2.
  6. Mitchell Pearrow
    8,368
    12,459
    I fall more into the second set of your settings.
    Mitch
    steveb63 and mulletmule like this.
  7. mulletmule
    Nov 19, 2013
    303
    153
    Rochester NY
    We have the same year. That's what I am finding is it is very bass heavy unlike my 2203. But not bad if you d
    Turn it up it gets tubby for sure.
  8. mulletmule
    Nov 19, 2013
    303
    153
    Rochester NY
    I will try the second suggestion but bass on 10 would not work on this amp lol.
    steveb63 likes this.
  9. mulletmule
    Nov 19, 2013
    303
    153
    Rochester NY
    Thank you!
  10. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    400
    288
    I posted this before but here it is again ,.....no pedals ,just the amp with a
    $150 Ibanez ,Iphone,vibe and delay........Best fat round gain I ever had !
