1977 Marshall JMP 50 Watt Master Model Mark 2 Lead 2204 in Excellent Condition
Discussion in 'Member Classifieds' started by mattpas, Feb 14, 2020.
  1. mattpas
    mattpas New Member
    Apr 26, 2019
    8
    15
    Sold
    Obi Plexi-nobi likes this.
  2. MonstersOfTheMidway
    May 1, 2008
    4,949
    2,483
    $1749 is a good price given the condition of the amp (very clean and seemingly well-maintained). Question: are the transformers original? If not original but of high quality, then it's might still be a good buy.
    Thanks for posting/sharing the info.
  3. mattpas
    mattpas New Member
    Apr 26, 2019
    8
    15
    The transformers are original.
  4. MickeyJ
    MickeyJ Well-Known Member
    Nov 11, 2019
    747
    434
    i smell a bit of bullshit here, look at the laminations on the o/t and the p/t, the rust/dirt/aging arent the same( they always are on original matched xformers) the wiring for the o/t looks new to me to.
    That o/t is new-ish/re-wind.
  5. MickeyJ
    Nov 11, 2019
    747
    434
    just use a toothbrush with some water on the top of that o/t once a day for a week, wait a few days than take your photo again, it will be much more convincing.
  6. neikeel
    3,808
    2,227
    PT gets hot, hence corrosion on lams
    OT and choke do not
    Close ups of the wiring and selector will tell you.
    Does not look too phoney to me, although the end bells are not tight on the OT lams......
    More and better pics will prove.
  7. MickeyJ
    Nov 11, 2019
    747
    434
    here we go again.
    dude, i lost you the other day when you tried to tell us that a bright cap doesnt make an amp bright and then offered a mathematical formula ( just listen to the two channels on any old marshall with a bright cap on one channel, the bright cap is the only difference).
    I don't think you're doing yourself any favors bro.
  8. MickeyJ
    Nov 11, 2019
    747
    434
    theres literally hundreds/thousands of images online.
    knock yourself out.
    what you forgot when formulating your comment was that the o/t is right next to the output tubes, lotta heat there.
    these things don't have good airflow, the hot air lingers after the amp is switched off.
    When the amp cools, the condensating moisture simply rusts everything that isn't coated.
  9. MickeyJ
    Nov 11, 2019
    747
    434
    look at the orange green wires, too bright, waaay too bright.
    lots of heat cycles, simple oxidisation ( everything breaks down, people) causes wires to get a dull finish to them.
    All my old amps are like this.
    This amp has quite obviously had an O/t change.
  10. Crikey
    Crikey Well-Known Member
    Feb 16, 2019
    380
    552
    Love this site. Will never buy a vintage marshall without having my forum buds check it out via pics. Good catch Mickey
  11. mattpas
    mattpas New Member
    Apr 26, 2019
    8
    15
    The amp was gone over by a reputable amp builder in Michigan, Dean Zink who confirmed everything is original and just needed a retube.
    This is from Dean
    The numbers on the transformers are correct for the 1987 model amp from year 1969 thru 1979. The date code (for August 1977) on the power trans is correct for your J code amp with Sept, 14 1977 date on the tag.
    Power x-former 1202 64 -- date code (8 77)
    Output x-former 784 139
  12. South Park
    1,477
    1,111
    Anything that old and a power supply . You are going to replace something
  13. MickeyJ
    Nov 11, 2019
    747
    434
    i bet dean zink didn't buy it.
  14. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    619
    246
    One thing i know is most techs are not qualified to authenticate any vintage amp unless that particular model is their passion.
    Sadly I missed the original post.
  15. MickeyJ
    Nov 11, 2019
    747
    434
    that tech would have said this was legit too, because it had the right numbers on it.
    this image is of a 1969 50 watter.
    I would have pulled the images from todays post as well, a lot earlier.
  16. neikeel
    3,808
    2,227
    You are pretty black and white kind of guy - you do not do or choose to read nuance or subtlety at all. Read my comment again, I clearly mention distorted end bells.....suggesting they may have been disturbed ie replaced and asked for more pictures (ain't going to happen because someone scared the horses off). Re: the bright cap issue. It is the size relationship between the size of the cap and the resistance it is parallel that determines if it is bright or just 'gain' that comes through so small resistance smallish cap is bright, bigger cap or more resistance is wider bandwidth - less bright more signal ie perceived gain (yes with your ears) not purely bright. Are you sure you aren't Donald J (he doesn't do subtlety or nuance either!)?
  17. MickeyJ
    Nov 11, 2019
    747
    434
    hey, I've got a couple ( a few) of these old amps and I double checked the bright cap thing, yes, the bright cap makes the amp brighter!!
    I don't know who donald J is bro, the veiled insult is totally lost on me.
    Just be more careful when chopping someone down, you won't need the tedious explanations.
  18. neikeel
    3,808
    2,227
    I’m not chopping any one down they can grow as tall as they want.
    Btw I’m sure you did your research and the pics you posted above were of an amp I restored (with NOS Drake PT) some years ago hence the different patina.
  19. MickeyJ
    Nov 11, 2019
    747
    434
    dude, you're awesome.
  20. MickeyJ
    Nov 11, 2019
    747
    434
    lets just keep it all on the bright side.
