1976 JMP Pics - Hows It Look?
Discussion in 'Marshall Amps' started by pedecamp, Aug 25, 2019.
  1. pedecamp
    12,776
    8,288
    I'm considering buying this JMP its a 1959, please take a look at the guts and let me know if it looks good and everything is in place. These amps have 4 speaker inputs? Thanks!
  2. Wenander
    Wenander Member
    Aug 10, 2015
    31
    22
    Sweden
    i think it´s modded with an FX loop ....... cant find any pics online with four holes on the back
    *edit ... now i found some with four holes on the back....weird
  3. scozz
    scozz Well-Known Member
    Jul 20, 2008
    1,491
    2,884
    These are the amps that inspired the Jcm800,...is that correct?
  4. Mitchell Pearrow
    7,267
    10,161
    If it’s the MV model, then yes I believe so !!
    Cheers Mitch
    scozz likes this.
  5. pedecamp
    12,776
    8,288
    Maybe its got two 16 ohm, one 8 ohm and one 4 ohm input. Exactly my thought, maybe get rid of two jacks and put an effects loop in it. :yesway:
    Wenander likes this.
  6. pedecamp
    12,776
    8,288
    This is a plexi non master volume amp.
    scozz and Mitchell Pearrow like this.
  7. Dogs of Doom
    18,895
    18,326
    that would make no sense...
    Trapland and MonstersOfTheMidway like this.
  8. pedecamp
    12,776
    8,288
    I'm guessing, what should it have? 16, 8, 8, 4? or 16, 16, 8, 8?
  9. pedecamp
    12,776
    8,288
    Never mind its gone...
  10. john hammond
    Mar 5, 2019
    945
    420
    nah those outputs are just normal marshall outputs, I believe usa market got 4 outputs at a one stage. ( you select speaker impedance by the rotary switch)
    that looks stock to me except for it seems to me someone has taken out the signal caps and put mustard caps into it, or fake mustard caps anyway.
    edit- the reason i think the mustards have been put into it from after new is because even though marshall stopped putting them in and then re-started again for a bit before permanently using other brands of caps is because one .022 looks stock ( they did that too, they'd just use one or two..) but the other six .022 are both a different color, and physical size.)
    Cadorman and Dogs of Doom like this.
  11. john hammond
    Mar 5, 2019
    945
    420
    large square rocker switches means its a post 76 amp ( except in canada, I have a canadian 50 that has normal early plexi style on and standby switches from 1977)
    edit- the filter caps have been changed too. this amp would have sounded rather good in my opinion. This is PHILx's favorite amp.That dogbox looking one he carries around with the BBQ front panel is one of these later rocker switch 100 4 holers.
  12. Dogs of Doom
    18,895
    18,326
    I think John Hammond is correct. they are just parallel outputs & the selector dial dictates the tap.
  13. Mitchell Pearrow
    7,267
    10,161
    Thanks for the clarification !
  14. ampmadscientist
    13,031
    6,902
    Start the reactor. free Mars!
    That is one of the cleanest amps I have seen in a long time. I would buy that amp.
    It is normal for the 1959 to have 4 speaker jacks. This is stock.
    This is for 4X 16 ohm cabs.
  15. Dogs of Doom
    18,895
    18,326
    @ 4 ohms...
  16. ampmadscientist
    13,031
    6,902
    4 X 16 ohm cabs Yes 4 ohms.
    One time I dropped a box of 1 Meg resistors, spilled ohms everywhere. But there was no use crying over spilled resistance.
    Michael Roe and Dogs of Doom like this.
  17. scozz
    Jul 20, 2008
    1,491
    2,884
    Did you receive your Studio Vintage yet?
  18. Matthews Guitars
    Matthews Guitars Active Member
    184
    212
    That's a super clean unmodded amp. It's been maintained but otherwise left alone and kept in a clean environment.
    It's a fine example of its type.
    How to tell that it's unmodded: Every wire on the ST1 board goes where it's supposed to go, every component on the board
    is where it should be, none are changed, none are missing, none are lifted, none are added, none have extra wires going somewhere that isn't part of
    the stock wire dress. All four speaker jacks are wired together in parallel, no extra wiring going anywhere else.
    And it's NOT a plexi.
  19. pedecamp
    12,776
    8,288
    I wasnt really looking for one of these but I stumbled across it and the price I couldnt pass up, I would have bought it but you guys didnt tell me it was a good one in time...
    :sad:
  20. pedecamp
    12,776
    8,288
    Not here, been waiting almost 3 months!
