1970 100watt Tremolo Mess...
Discussion in 'Let's Talk Vintage' started by pleximaster, Nov 25, 2017.
  1. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,483
    1,530
    7064091D-AB29-4CDA-874D-E4CC204367A9.jpeg here is a 1959T model thatneeds ❤️Some love... where to start...?
    Probably an inventory of parts and check up on transformers...
    Then part inventory in my parts stash to find a match
    And tubes... for testing... I only have old unused glass at home right now...
    Let’s see how this progress
    Going to the city with oldest daughter today to look at some potent Christmas gifts...
    Plexi
  2. neikeel
    3,680
    2,091
    Looks like a Scandinavian model that has had a transformer replacement and some caps replaced? The selectors flapping and floating wires make it look worse.
    Yes I would do a static test of all of the passives, clean the pots and jacks, make sure fuses are of correct value and depending on the filter caps (original or replaced) do a reform in situ or a recap (bias caps look original 47 year old ones?). Drop in some 'testing' tubes etc and see how she goes.
    liontato likes this.
  3. Trapland
    Trapland Well-Known Member
    Dec 5, 2013
    1,175
    1,007
    Minneapolis
    It looks easily within your ability. Not saying it looks easy, but easier for you than me.
    I definately will follow this one. Thanks,for the ‘before’ photo.
  4. pleximaster
    Feb 6, 2012
    1,483
    1,530
    0D8EE346-335E-443E-AC86-59369D957BA6.jpeg A6057514-911B-4A37-AA83-0CB58965C5E2.jpeg The diode bridge seems to have burned up at some point and is replaced with a homemade one. Should I replace it
    I got these box bridge rectifier but I don’t know how to read the specs from these. Anyone knows?
    Best plexi
  5. TAZIN
    TAZIN Active Member
    Mar 18, 2013
    496
    169
    5SB100 is a 5amp/1000V.
    3SB100 is a 3amp/1000V.
    liontato and pleximaster like this.
  6. pleximaster
    Feb 6, 2012
    1,483
    1,530
    Thanks Tazin!
    plexi
  7. neikeel
    3,680
    2,091
    If if I read the date codes correctly the 5A is correct for the age of the amp!
    I have seen some with a small turret board for the diodes and the blocks around 69 ( maybe Tazin can tell us when?)
  8. pleximaster
    Feb 6, 2012
    1,483
    1,530
    Neil Do you think this diodes on the small board are original? There are 8 diods total I have never seen that before only 4 on slightly bigger boards. By 1970 the block bridge rectifiers were more common AFAIK
    best regards plexi
  9. pleximaster
    Feb 6, 2012
    1,483
    1,530
    Tazin
    I just noticed that the small block bridge rectifier I got reads 3SB60 not 3SB100 would that make it 3 Amp 600 volts?
    I got a 50 watt Marhall with a block rectifier stamped 1 V R GB256/PA 69 13
    What does that mean?
    Best plexi
  10. danfrank
    danfrank Well-Known Member
    Mar 5, 2015
    972
    503
    Hi Pleximaster!
    3SB60 is 3 amps 600 volts.
  11. neikeel
    3,680
    2,091
    No definitely not like that.
    They are a small piece of perforated paxolin, just the same type as the main boards with the standard turrets. They are wired just like you see the 68 era amps with crossed diodes in the middle. Can't remember where I have a pic of one. I fixed a very late plexi SB just like that a couple of years ago.
  12. TAZIN
    TAZIN Active Member
    Mar 18, 2013
    496
    169
    The 3SB60 is a 3amp/600V bridge just like danfrank mentioned. There should be additional writing on that 50 watt block rectifier that states its rating.
    The transition from individual diodes on a small perforated board to the block type IR bridge rectifier started in early 1969 and really takes a foot hold with the introduction of the standup mains transformer.
  13. danfrank
    Mar 5, 2015
    972
    503
    If find it interesting that Marshall used such overrated bridge rectifiers in these amps. Maybe because they had many failures with the earlier individual diodes? Does anyone know? They went with 1N4007s later on, in the 50 watt models... correct?
    neikeel likes this.
  14. TAZIN
    TAZIN Active Member
    Mar 18, 2013
    496
    169
    The switch to the block type rectifier probably had to due with failures and to simplify assembly.
  15. ampmadscientist
    14,948
    8,778
    In earlier days, Marshalls blew fuses quite a bit...due to wrong speaker impedance or newer output tubes which draw more current.
    (until the screen grid resistors were added)
    It was better to blow that fuse, than the diodes.
    grainman likes this.
  16. pleximaster
    Feb 6, 2012
    1,483
    1,530
    11258A2D-BE8F-4982-990C-879DE790230C.jpeg 45BBB508-F78B-4D05-A1D4-C3608759D1D1.jpeg 216B0D61-8949-4C17-B750-8107A4AB4D47.jpeg Fixing the leads on the output transformer (they were cut and had shrinking tubing on a them)
    Before and after pics...
    BadgerO, hazmat7719 and liontato like this.
  17. pleximaster
    Feb 6, 2012
    1,483
    1,530
    I started to tidy up some of the wiring. The mains transformer was for some reason turned the wrong way and all wires were extended... I turned it back again... see if it works this way later...
  18. pleximaster
    Feb 6, 2012
    1,483
    1,530
    0FB823A5-69D4-4E75-A694-CA7BD7982CE1.jpeg After I had fixed with the transformers and wiring and doubled checked it I tried to fire up the amp but no sound what so ever...
  19. pleximaster
    Feb 6, 2012
    1,483
    1,530
    0D683D72-9535-4C31-9E5F-C387737DE638.jpeg After about 20 minutes... I found out why I didn’t get ant sound....
    Forgot to put in the tubes... :)
    Time for a break! Right?!
  20. pleximaster
    Feb 6, 2012
    1,483
    1,530
    I put in tubes and there was sound but I´ll need to rebuild the bias circuitry but not today... :)
    plexi
