1969 with low plate voltage. Help needed
Discussion in 'Building the Classics' started by Chris4189, Nov 5, 2019.
  1. mickeydg5
    22,371
    9,780
    No. I said voltage AC, VAC.
    Tubes in and play. We are measuring incoming signal level to pins #5 or the power tubes.
  2. Chris4189
    Chris4189 Well-Known Member
    Jul 10, 2018
    203
    266
    V4:13.6 VAC
    V5: 13.4 VAC
    V6: 14.3 VAC
    V7: 14.9 VAC
    VOL I on 10
    VOL II is dead.
  3. Chris4189
    Jul 10, 2018
    203
    266
    May have figured this out a bit more. When I bought the amp it had a master volume installed. I removed the MV completely. Well I went back and looked at a diagram and noticed there should be a wire running thru the center treble pot to the .022 cap. Can I use 22 AWG top coat wire for this connection?
    After a double shot of Crown, just discovered V2 was bad. Think I found the missing link in sound.
  4. mickeydg5
    22,371
    9,780
    That 22 AWG works fine.
    I have to ask, how did the power tubes get signal without a connection from the TREBLE center lug to the .022uF coupler to the phase inverter?
    And why is VOLUME II dead? Was that used for the MASTER VOLUME?
    Was the first two tube stages modified, maybe cascaded?
  5. Chris4189
    Jul 10, 2018
    203
    266
    That I don’t know. I’m still learning. I’d have to defer to you guys for that answer.
    literally as soon as I soldered the wire from PI input cap to the treble middle lug, VOL II worked as normal. They had the master on the back panel. Once I discovered the bad V2 tube and replaced it, everything was back to normal and loud.
    cascade I’m unsure of what that is or how to tell.
  6. mickeydg5
    22,371
    9,780
    A stock model 1959 has a Normal and Bright channel both of which tie in before V2. V2 drives the tone stack and form the TREBLE potentiometer the signal is passed to the PI (phase inverter).
    But you said Volume I worked, Volume II did not untill connecting TREBLE to PI. So that would mean something would be wired differently.
    Does the tone stack work for both channels?
  7. ampmadscientist
    13,811
    7,657
    "...everything was back to normal and loud...."
    Progress.....progress.....
    Chris4189 likes this.
  8. Chris4189
    Jul 10, 2018
    203
    266
    The MV they had in this was wired like this: one wire from the MV pot to the the PI cap and then a wire from the MV pot to the treble wiper lug in question. That’s it.
    All the other wiper lugs still have the original red lay out fluid on them. There are no added resistors, wires, pre amp sockets or anything that I see that what indicate any mod being done other then the MV as described above.
  9. ampmadscientist
    13,811
    7,657
    Keep going you're going to get it.
  10. ampmadscientist
    13,811
    7,657
    Let's see some pictures of the input jacks and input side circuit board.
  11. neikeel
    3,446
    1,890
    He said it is working now.
    mickeydg5 and Chris4189 like this.
  12. ampmadscientist
    13,811
    7,657
    I thought he said vol ii was not working?
  13. mickeydg5
    22,371
    9,780
    Everything so far points to working normally. If all the controls work as they should, it is biased correctly and is loud then its done. :fingersx:
  14. mickeydg5
    22,371
    9,780
    Last thing from me for now is see the resistor lead in this picture, upper left capacitor. Make sure it is not to close to the chassis. You do not want shorting. It would be best to have leads as short as possible there.
    Check around for stuff like that. :thumb:
    neikeel and Chris4189 like this.
  15. ampmadscientist
    13,811
    7,657
    He could put some tubing over that lead...
  16. mickeydg5
    22,371
    9,780
    I think short and sweet would be best. He has enough wire jackets in there.
  17. Chris4189
    Jul 10, 2018
    203
    266
    The resistors were/are no where near touching the chassis. The photo makes it appear that way.
    Since the OT is original and original to the amp I’m thinking of daisy chaining three 1N4007 diodes together as fly backs. Shouldn’t they go on tubes V4 and V7? From the diagram it looks like the go to pin 1 or 7 and then simply to ground.
  18. ampmadscientist
    13,811
    7,657
    What diagram are you talking about?
    This amp should not need those diodes.
  19. Chris4189
    Jul 10, 2018
    203
    266
    I can’t seem to find it now but it was a generic diagram for adding fly back diodes to protect the OT in the event something wonky happens.
  20. ampmadscientist
    13,811
    7,657
    I have never seen anybody install diodes like that in this type amp.
    Doesn't need it.
