1969 Marshall Red 50 watt Plexi
Discussion in 'Let's Talk Vintage' started by khingpynn, Oct 22, 2014.
  1. khingpynn
    khingpynn New Member
    Dec 9, 2010
    23
    9
    Hi guys and gals.
    I recently purchased a 1969 Marshall JMP 50 watt Plexi with Red tolex. It is a low serial number for 69 and has actual plexiglass face plates.
    Overal condition is good and it's about 98% original.
    I purchased the amp at Long and McQuade south Calgary. A local guy ( drummer ) inherited many things from his Uncle ( guitarist ) and he found the amp in his bedroom closet. On the advice of a friend he brought it to
    L&M to sell it. I showed up 2 hours later and as they say "timing is everything".
    I know this forum is a great resource for all things Marshall and would like to open up a discussion about this and other amps like it.
    What I would like to discuss most is, authenticity, current market value, how rare is it, where to buy parts for maintenance/repair, the pros and cons of screen grid resisters, significant players who used 50 watt plexis, significant recordings using 50 watt plexis, and other interesting stuff about plexis.
    Cheers to all.
    Craig
    Photos
    http://i164.photobucket.com/albums/u8/khingpynn/Plexifront.jpg
    http://i164.photobucket.com/albums/u8/khingpynn/plexiserialnumber.jpg
    HAmmer, Oatie, smallaxe and 2 others like this.
  2. george76
    george76 New Member
    Aug 5, 2009
    1,106
    272
    Looks like a re-cover to me, but happy to be proved wrong...
    LAARS and Joshabr1 like this.
  3. danman
    danman Active Member
    Apr 27, 2014
    457
    149
    Richmond, Va
    Great find! I'm not sure that I have ever seen one of that year with the red tolex...very interesting! Has it been played regularly over the years? If not then you may want to look into freshening up the filter caps just to be safe. Playing the amp regularly helps keep them healthy but if the amp has sat unused for years they tend to dry out. Definitely a good idea to add some screen resistors especially if you will be running current production power tubes. It would be a shame to have a failed tube ruin the trannys in such a nice amp!
  4. Joshabr1
    Joshabr1 Well-Known Member
    Sep 2, 2013
    1,297
    616
    Ky
    Same thing I thought. Funny the way the pre amp filter is in there. Board does look original. The stuff that matters anyway. I see some snubbers replaced. Wiring looks a little ratty to me. Are the transformers original? For sure would add some resistors 1k 5 watt?? Over those power tubes. See some funny business around the mains transformer replaced diodes? Re wiring? Just looks sloppy on the inside for that time period to me. Not saying at all its not mostly all there it seems to be. Pics of transformers?
    sct13 likes this.
  5. soundboy57
    soundboy57 Well-Known Member
    Dec 27, 2009
    2,487
    1,965
    Oregon
    Looks great, but recovered. The gold piping and string aren't "gold" enough like the original stuff, and the red tolex is too bright, and the texture looks more modern, as well.
    Only saying this in case you paid a premium due to the red tolex.
    I hope I am wrong, too:D
    Still, a beautiful rare amp in great condition, great score!
    Oatie likes this.
  6. Joshabr1
    Sep 2, 2013
    1,297
    616
    Ky
    Edit. Good eye sound boy. For sure recover.
  7. yladrd61
    yladrd61 Well-Known Member
    Jun 20, 2010
    1,786
    649
    Seattle, WA
    Wouldn't you want 1K 5 Watt resistors with EL34s ?
  8. Joshabr1
    Sep 2, 2013
    1,297
    616
    Ky
    Edited.
  9. m1989jmp
    m1989jmp Active Member
    Apr 24, 2014
    844
    135
    I see there's an unused hole with a grommet in it next to that can cap to the right? Some of the pot wiring looks unusually sloppy for Marshall, but pots look stock. Also, someone messed with the speaker output ground reference, but that's a minor issue if done properly.
    I see the output sockets are bolted to the chassis, can someone elaborate why some have riveted sockets?
    Post some more chassis pics if you have em (transformers, filter caps, etc.)
    By the way, is that a custom shop Jackson you've got? Looks like a killer guitar...
    sct13 likes this.
  10. TAZIN
    TAZIN Active Member
    Mar 18, 2013
    406
    119
    The amp is not in that bad of shape considering its age....It looks to be from around April of '69, and of coarse is a Canadian export model. The main tag board looks untouched with the exception of the replaced bias filter caps. The other additional little tag board has had the H.T. fuse re-located to the rear panel and the snubber caps have been replaced.
    Other replaced parts include:
    The mains fuse holder.
    Power cord.
    Both switches.
    Indicator lamp.
    Filter caps.
    The good news is that the transformers appear to be original....Bad news is that it looks like someone drilled at least one additional hole on the top of the chassis.
    sct13 likes this.
  11. Joshabr1
    Sep 2, 2013
    1,297
    616
    Ky
    I only see 3 pics
  12. khingpynn
    Dec 9, 2010
    23
    9
    Hi Guys/Gals
    Thanx for all the replies. I'll take some more photos of the top of the chassis. It does not look like a re-tolex to me but that said I will take more photos of the inside of the box and see what you guys think.
    I see some changes to the wiring and the added fuse holder. Tranformers look original but there again more eyes the better.
    I'll post some photos this weekend sometime. I'm hitting the road for out of town gigs this weekend.
    Happy Playin
    Craig
  13. ampmadscientist
    7,325
    2,824
    You need to add the screen grid resistors.
    The amp will draw too much current without them.
  14. sct13
    sct13 Active Member
    Jun 7, 2009
    695
    129
    Mich
    Agreed, I have one that is very similar
  15. ampmadscientist
    7,325
    2,824
    Yes 1K 5W for EL34.
    470 ohm is for KT66.
  16. shredless
    shredless Well-Known Member
    Sep 15, 2010
    4,433
    2,504
    So the big question is....
    how much did you pay for it?
  17. khingpynn
    Dec 9, 2010
    23
    9
    The bigger question is what should I have paid? :)
    I know as little as possible but what is fair market value?
    I sent pictures to two reputable Gents who own several and have worked on several Plexi's and both said I was lucky to have a red one as it was the rarest of custom colors.
    It does not look re-tolexed as I can see no indication of it... no glue lines or unusual cut lines. The color in the photos here is brighter than it looks and effected by ambient light. I'm also lucky enough to have one of the best teks in western Canada to have gone through it and give it a good going over. He replaced the two bias caps. The power and standby switches are original. On the standby switch the nut was missing so a hexagonal nut has been installed there. The High Tension fuse was moved and yes a hole was drilled in the chassis and a different fuse holder that the original was used. I'm thinking this modification will not drop the value significantly.
    Had a busy weekend with out of town gigs... lots of fun had which is always good. More photos to come.
    Cheers
    Craig
  18. stratburst
    stratburst Active Member
    Jan 9, 2010
    124
    51
    Florida, USA
    Hard to tell without more pics in and out. It could also be a '71 or '72 box that was swapped out. Regardless, it looks great!
  19. Appetite4distortion
    Appetite4distortion Active Member
    Aug 10, 2011
    208
    95
    The box should be original plexi era seeing flat lip under controls. A Post 69 should have round lip.
    I believe too it's a recover (possibly old one) due to minor flaws here and there.
  20. stratburst
    Jan 9, 2010
    124
    51
    Florida, USA
    Your'e right, I spaced on the lip. Good call.
