1960 Slant Cab Question
Discussion in 'Cabinets & Speakers' started by PrimitiveFuture, Feb 24, 2020.
  1. PrimitiveFuture
    PrimitiveFuture New Member
    Feb 24, 2020
    5
    4
    Okay, so I got this cab and on the back the ohms switch has been taken out. What ohms is this running on now? 4, 8, or 16? Need to know so I don't blow my head up.
  2. BygoneTones
    BygoneTones Well-Known Member
    Aug 27, 2013
    1,172
    696
    Do you have a multimeter? just attach your speaker lead and measure the end of it. The very tip is positive, the shaft is negative.
    Lance Chambers, tce63 and FracStrat like this.
  3. Ken Underwood
    Oct 16, 2013
    468
    1,231
    Annesley North Notts UK
    Will not make any difference which way round you have your multi-meter probes
  4. Scumback Speakers
    Sep 16, 2016
    759
    1,030
    Los Angeles, Ca
    If your reading is from 6 -7.2 ohms, that's an 8 ohm cab. From 12-14 ohms is a 16 ohm cab.
    They don't read exactly at 8 or 16 when cold.
    Lance Chambers and tce63 like this.
  5. metromutt
    metromutt Well-Known Member
    Jul 15, 2009
    688
    275
    England
    First thing I'd do is take the back off the cab and check everything. Check the speakers all tally, I've seen a lot of replaced spks some even different ohms to the rest, more importantly check the wiring and how they are wired. Seen some monster wiring jobs were people have cut the wires on those switch sockets and just taped the wires up with insulating tape.
    tce63 likes this.
  6. Ken Underwood
    Oct 16, 2013
    468
    1,231
    There is a difference between resistance and impedance guys.
    Matt_Krush, tce63 and marshalltsl like this.
  7. PrimitiveFuture
    Feb 24, 2020
    5
    4
    Thank you everyone for your replies. So what should I check for? As far as resistance goes I don't know much, and I get impedance, I just need to check the speaker outlets with a multimeter to see that? How do I check resistance?
    tce63 likes this.
  8. Ken Underwood
    Oct 16, 2013
    468
    1,231
    If you dont know the basics i would suggest that you find some that can do it for you, a decent tech will check it for you
    Mr. Natural and tce63 like this.
  9. Sustainium
    Sustainium Well-Known Member
    Oct 4, 2019
    452
    880
    Resistance is measured in ohms. Use the ohms setting on a multimeter.
    Will not make any difference which way you have your multi-meter probes.
    You can do No harm measuring resistance on a speaker so no worries there.
    Lance Chambers likes this.
  10. Ken Underwood
    Oct 16, 2013
    468
    1,231
    Thats all very well but do you understand what you are doing.
  11. Sustainium
    Oct 4, 2019
    452
    880
    Schooled, licensed and worked in the automotive electric field.
    Helping a member out, ohms law is basic electricity.
  12. Ken Underwood
    Oct 16, 2013
    468
    1,231
    Electrics/Electronics needs different knowledge, similar but not the same but dont get me going here
