1960 cabs recover and retro conversion
Discussion in 'Cabinets & Speakers' started by Matthews Guitars, Oct 24, 2019.
  1. Matthews Guitars
    904
    1,199
    I've been sort of busy in the garage the last two days. I'm recovering and retro styling my 80s JCM800 1960A and 1960B. The A is basically done, and I start on the B tomorrow.
    I'm liking it!!
  2. tce63
    Aug 6, 2018
    1,138
    2,800
    Sweden
    Looks fantastic :applause:
    MK333 and steveb63 like this.
  3. Filipe Soares
    Mar 8, 2019
    662
    1,021
    I LOVE IT!!!
    tce63 likes this.
  4. Rotorcraft230
    Rotorcraft230 Active Member
    Aug 15, 2019
    262
    180
    Brazoria County Texas
    Looks good and nice attention to detail.
    tce63 likes this.
  5. Matthews Guitars
    904
    1,199
    Thank you! I'm doing my best! I can say I've never had so many corners come out so good before on any previous project. I've learned the trick...and it's super glue and painter's blue tape.
    I've started work on the bottom cabinet, too. After taking the baffle out I discovered that all the cabinet glue joints had failed. I don't know what this white crunchy type of dried glue is, but it's definitely turned to sand. I took everything apart, cleaned the joints out, and reglued it. It's coming out of clamps after dinner and then I continue on as normal.
    There's a warning there. Old Marshall cabinets may be susceptible to glue joint failure. If in doubt, remove the back panel and the baffle board. If the cabinet is a bit floppy after you do that, the joints have failed and the proper fix is to strip the cabinet, take it apart, clean the joints, reglue it, and apply new tolex. You're just not going to get away with trying to squeeze glue into the failed joints and call it a day.
    This cabinet had also taken enough of a fall to crush one lower plastic corner and there's some damage beneath that corner. And nearly all the screws holding the baffle to the cabinet are bent, probably from the same fall.
    It'll be fine. In fact, being freshly repaired, I have great confidence in it.
    jmp45, tce63, Mr. Natural and 2 others like this.
  6. Exotic
    Exotic Active Member
    Sep 3, 2018
    333
    149
    wow that is really amazing ,if u were to retolex a cab for someone else how much would u charge?
  7. Matthews Guitars
    904
    1,199
    A basic retolex job on a Marshall 4x12 with no changes and there are no complications? I'm going to throw out a guess of 150 bucks plus tolex and materials. If there are "issues" to deal with then the price goes up some. If you want to do cosmetic changes like add the gold strings and you need new handles and hardware, that's extra, too. And then there's shipping to consider. Fedex ground is going to be your best bet. Even better, have a music store in your area do the shipping for you, because they probably have a pretty good rate with Fedex.
    tce63 likes this.
  8. Matthews Guitars
    904
    1,199
    And the whole stack is done. Just waiting to get the chassis back into operation and installed.
  9. mAx___
    mAx___ Active Member
    Apr 3, 2012
    452
    171
    What a beauty!! Awesome job.
    steveb63 and tce63 like this.
  10. Drinkingdeath01
    Drinkingdeath01 Well-Known Member
    Feb 1, 2010
    383
    842
    Minneapolis Minnesota
    Looks fantastic. Nice work.
    tce63 likes this.
  11. South Park
    1,275
    954
    Great job
    tce63 likes this.
  12. bfglp
    bfglp Member
    Jul 30, 2009
    123
    Looks awesome. What type of glue did you use?
  13. jmp45
    jmp45 Well-Known Member
    May 5, 2016
    2,003
    2,522
    Amazing, looks great!
  14. Matthews Guitars
    904
    1,199
    I use a commercial grade contact cement. I don't know who makes it but it beats the pants off of Weldwood contact cement. I get it in gallon cans from my local commerical wood and cabinetry shop. I'm not one of those people who has any affection for or use for hide glue. I've used that stuff before, and its only reason for existence is to build and repair stringed instruments in the violin family.
  15. Fret-Shredder
    Fret-Shredder Member
    Jul 29, 2019
    36
    41
    Beautifully done. They look absolutely amazing. I'm partial to Purple.
