1959HW problems
Discussion in 'Marshall Amps' started by farshad salamat, Apr 6, 2020.
  1. farshad salamat
    farshad salamat New Member
    Apr 6, 2020
    6
    6
    my amps has gone from a very loud amp into a very quiet one and the sound that's coming from the amp is distorted.
    so I'm looking to the wise people of the forums for advice and help
  2. South Park
    2,206
    1,793
    Did you check the tubes
  3. ampmadscientist
    17,948
    11,977
    Because the speaker is bad?
    Because the HT fuse is blown?
  4. EADGBE
    EADGBE Well-Known Member
    Dec 13, 2009
    524
    410
    Yes check the tubes.
    tce63 and South Park like this.
  5. Matthews Guitars
    1,813
    2,400
    You should have a full set of good spare tubes. If not, WHY NOT? If you do, swap them all in and see how it goes.
    tce63 likes this.
  6. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    1,862
    1,840
    Shakedown Street
    I am not well versed in all aspects of the tubes , I do know it is easy to swap the pre amp tubes no problem . When it comes to power tubes that's where the bias issue comes into play and that is a foreign land for me ? Please enlighten me ?
    tce63 likes this.
  7. neikeel
    4,221
    2,676
    Always try tubes first, pre then output, but (as mentioned) you will need to check/adjust the bias for the output tubes to work properly and safely.
    There are things to check first. For example the speaker jacks and connections, speaker cab, input jacks are clean and making good contact, similarly the output selector switch (flick it back and forth a few times).
    Then take a brand new ECC83/12AX7 or 7025 and replace each preamp tube one at a time and retest. If that does not do the trick you are going to have to go to a tech to test the output tubes (and from your description worryingly) the output transformer.
    Gives us some more info and we can help.
  8. Bull Rock
    Bull Rock Well-Known Member
    Aug 27, 2015
    1,652
    2,348
    Canada Eh
    Any Sound coming from speaker... Prob just a tube issue. My CR40 worked great for two weeks... Then was super quiet... Like barely audible at full blast. Put a known good 12ax7 in each slot until BAM, back to life. Probably tubes bro.
    tce63 and Kinkless Tetrode like this.
  9. Bull Rock
    Aug 27, 2015
    1,652
    2,348
    Canada Eh
    tce63 likes this.
  10. farshad salamat
    Apr 6, 2020
    6
    6
    So i had a set of pre amp tubes and switched them out and nothing changed. I then did what you told checked the rest and it was all working properly, now i don't have a set of power tubes at hand. I'm waiting for those to arrive and swap them, I have had the amp for 9 years and never changed the tubes so i have never biased an amp
    tce63 likes this.
  11. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,018
    718
    Just swap in the new power tubes and see if it works, the bias can be adjusted later. Btw, do you use an attenuator? They can go bad, try running straight into the speakers to rule out a bad attenuator.
    tce63 and Bull Rock like this.
  12. Bull Rock
    Aug 27, 2015
    1,652
    2,348
    Canada Eh
    Not sure what exact amp you have, but someone here or Google it may have instructions to bias your amp make and model. Just be aware there is some potential serious risk involved with the process. Don't just monkey around haphazardly in there. If you are unsure please take it to a tech.
    tce63 likes this.
  13. Bull Rock
    Aug 27, 2015
    1,652
    2,348
    Canada Eh
    Safest direct problem checker.
    tce63 likes this.
  14. Chris-in-LA
    Jul 19, 2018
    1,018
    718
    Right straight into the amp with a good cable too. Eliminate everything else and work back from there.
  15. Bull Rock
    Aug 27, 2015
    1,652
    2,348
    Canada Eh
    Yah!
    tce63 likes this.
  16. farshad salamat
    Apr 6, 2020
    6
    6
    Update: i just swapped out all the pre-amp tubes and power tubes. It sounded normal for like 4 seconds and then back to low volume and crossover distortion
    tce63 likes this.
  17. Bull Rock
    Aug 27, 2015
    1,652
    2,348
    Canada Eh
    I'm afraid I cannot help you man, sounds like a power issue.... but someone else will probably be along with the knowledge you need. Lots of techy guys in here. Sorry bro. Message ampmadscientist from the above post. That's a good start.
    tce63 likes this.
  18. ampmadscientist
    17,948
    11,977
    Step One
    Test Speakers
    This problem may not be an amp problem, it may be a speaker issue.
    Are you able to test the speakers?
    Do you have a 9 volt battery?
    Plug a cable into the speaker cabinet.
    Always use a real speaker cable, not a guitar lead.
    Touch the 9 volt battery to the free and of the speaker cable.
    There should be a loud POP when you touch the battery to the cable plug.
    If the sound is weak, instead of a loud POP, there could be a speaker problem.
    Touch the battery over and over to make sure that the speaker makes a loud POP every time.
    tce63 likes this.
  19. Chris-in-LA
    Jul 19, 2018
    1,018
    718
    Check your attenuator.
    tce63 likes this.
  20. farshad salamat
    Apr 6, 2020
    6
    6
    tce63 likes this.
