18 Watt TMB clone as small as I could make it.
Discussion in 'Building the Classics' started by spin, Dec 29, 2019.
  1. spin
    spin New Member
    Dec 25, 2019
    9
    13
    Delaware
    New guy here, I finished this amp over the summer. It's my first marshall build as well as my first amp layout. I built it on plywood first to work out the kinks.
    Back Open 02.jpg Front 03.jpg PCB 01.jpg JLC PCB (low).jpg Populated PCB.jpg Post Paint Chassis.jpg Turret Proto 2 (low).jpg
  2. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,020
    5,061
    Montreal
    Gotta admit that is pretty cool.
    A summer well spent.
    Congrats.
    BP
    AND :welcome:
  3. South Park
    1,232
    927
    Nice job the boards look great
  4. scott-colorado2016
    scott-colorado2016 Active Member
    Jan 7, 2017
    189
    221
    Colorado, USA
    So, why did you make it so small?
    Looks pretty cool. :coffee:
  5. spin
    spin New Member
    Dec 25, 2019
    9
    13
    Delaware
    I picked up the shell first on a pedal building forum with no idea what to do with it. I've already built a couple champs, and not really hyped on single ended stuff anyway. Decided on a stripped down TMB. The tighter the build got, the more determined I was to make it work.
    scott-colorado2016 likes this.
  6. scott-colorado2016
    Jan 7, 2017
    189
    221
    Colorado, USA
    So you're like that guy trying to pick up 10 lbs of junk and put it in a 5 lb sack... I gotcha bound and determined to make it happen. Looks like some quality workmanship there. How does it sound? You say stripped down, guess it has no tremolo circuit? How stripped down is it?
  7. spin
    spin New Member
    Dec 25, 2019
    9
    13
    Delaware
    It sounds pretty good, I wish I had some clips. Took me some time to dial in the power nodes, ended up changing the power transformer for some extra volts. No trem. Single or parallel triode input into the TMB. Let me see if I can find a schematic, forgive it's drawn weird and may have errors, I never redrew it after the tweaking phase.
  8. neikeel
    3,654
    2,077
    Looks very nice - presume the green board was protoype/development?
    Are you getting noise issues with proximity of transformers?
  9. DonP
    DonP Active Member
    Jan 28, 2009
    116
    55
    Cincinnati, OH
    What are the specs on the output tranny?
