16ohms sound different than 4 ohms? Is it my ears ..or???
Discussion in 'Cabinets & Speakers' started by shawntmartin, Feb 23, 2011.
  1. shawntmartin
    shawntmartin New Member
    Feb 17, 2011
    20
    I have an amp that is advertised as 150 watts. It even has 150 in the Model of the amp TBX150H. It can be used at 8ohms (100W) or 4ohms (150W). I had my cabinet wired previously at 16 ohms. Sounded thick. Then I rewired it to 4 ohm to get that advertised 150W. Is there a reason that the sound (to my ears anyway) from the amp/speakers sounds better BEFORE wiring the 4ohms? It would seem that if the thing is advertised as 150W..that 4ohms would be the preferred setting. I thought it sounded fuller/thicker when wired at 16 ohm.
    Or is it just my ears tricking me?
  2. Ken
    Ken Well-Known Member
    Feb 24, 2009
    9,944
    3,135
    Arlington Heights, IL
    A SS amp will make a difference; a tube amp shouldn't. What kind of amp is that?
    Ken
  3. Rahlstin
    Rahlstin Well-Known Member
    Jan 10, 2011
    1,067
    504
    Lethbridge, Alberta
    My DSL sounds different between 16-4. Quite a difference actually. Same with my 1959.
  4. chuckharmonjr
    Mar 26, 2010
    8,808
    4,281
    Oh hell...here we go again...where's Jon?
  5. T-Bird
    T-Bird New Member
    Jul 4, 2009
    518
    11
    Finland (Northern Europe)
    Hi.
    IME there's two possible explanations.
    Your amps output section handles the 16Ohm load better than 4Ohm. Very common thing with budget SS amps.
    Or, one or more of the speakers are out of phase with the other(s).
    If a regular tube amp sounds audibly different with different OT taps, there's usually something wrong with the circuit or OT. IME anyway.
    Regards
    Sam
  6. MartyStrat54
    Feb 21, 2009
    26,009
    9,510
    Licksville
    We're talking about a budget IBANEZ guitar amp that cost around $250.
  7. MartyStrat54
    Feb 21, 2009
    26,009
    9,510
    Licksville
    Tube amps make the same power regardless of load.
    SS amps output power depends on the load impedance. So a SS amp will put out a lot less power into 16 ohms versus 4 ohms. You are also more prone to clipping the signal to the speakers using a 16 ohm load. This is because your headroom all but goes away. If the four ohm load makes 150W and the eight ohm load only makes 100, what is the 16 ohm making? 50 watt or so? Then if you are cranking this 50 watts, the power section is prone to clipping or at least going into distortion.
    This will alter the overall tone of the amp.
  8. demonufo
    demonufo New Member
    Oct 23, 2010
    2,211
    256
    defunctprofilesville
    That's mainly because of the difference in negative feedback between the 16ohm setting and the 4ohm setting, rather than the difference in the impedance itself. The amount of negative feedback changes when you move taps, unless you have moved the NFB lead from whichever tap it is attached to, and attached it to the speaker jack tip instead.
    Because of the way that these tube marshalls are wired, this will also make a difference as well as the massive difference that it makes with Solid State amps.
  9. shawntmartin
    Feb 17, 2011
    20
    I didn't think we had to have a certain price tag amount to ask a question. I'm not some 15 yr old kid with his first head. If you spend some time with the head and an EQ through the effects loop.. and you know what your doing.. this cheap head can sound MEAN! If I want that "Meshuggah tone".. thats the head I'll play. If I want want blues//Classic rock I'll plug into another head. I'm 39 and I have owned a buffet of heads in my days. And I've played through a million more. Mesa's, Marshall's, Ampegs, Randall's, Laney, Peavy's, etc, etc, etc.. That Ibanez sounds way better for metal than my Marshall 8200 ever could regardless of the price tag. And I have the sound clips to prove it.;) For a thick, deep, hi gain head with Mesuggah tone.. the only thing that I've heard that sounds better is the Rectifer which is 4X as much. If anyone would like to give me a video clip of their amp that sounds better for newer metal, I would love to hear it.
  10. Clammy
    Clammy Well-Known Member
    Feb 24, 2010
    2,247
    1,614
    I thought it was the other way around: if the NFB wire is attached to the speaker outputs, the negative feedback changes with the impedance selected, whereas if it's attached to a specific OT tap, the negative feedback remains constant regardless of impedance chosen.
    Cheers!
    :dude::dude::dude:
  11. MartyStrat54
    Feb 21, 2009
    26,009
    9,510
    Licksville
    I called it a budget amp and that is what it is. It makes sense to point this out, because it really tells a lot about "how the amp is built." Some 150 watt solid state guitar amps have a solid power supply. Some of the cheaper ones are built with substandard components. I wasn't bashing you for owning this amp. You obviously have it dialed in to your sound.
  12. demonufo
    demonufo New Member
    Oct 23, 2010
    2,211
    256
    Nope. With it connected directly, the transformer can have NO bearing on it. With it connected to a tap, it is feeding through the transformer, and depending on the setting, through one quarter, one half, or the whole of the secondaries, which affects the level of NFB.
  13. shawntmartin
    Feb 17, 2011
    20
    Sorry man.. I didn't catch what you were saying the first time. Yea, I'm fully aware this is a budget head. A $250 price tag basically insures that no experienced guitar player can even try and take this head seriously. For that price..its basically a disposable head. I only bought it for one purpose. As wierd as it sounds... with a BBE Sonic Maximizer through the effects loop, the gain on only 5.5-6.. and a week of fine tuning...this thing isn't too different to the Red Channel on the Rectifer I had. :lol: Very Meshuggah like. And thats with bland G12M-70's. For fun I'll post some vids comparing it to my Marshall 8200 once I get the Man O Wars installed.
  14. Clammy
    Feb 24, 2010
    2,247
    1,614
    Hmmm... I don't know, man. Everything I've read says that if it's attached to the speaker output, it's variable, whereas when it's connected to a specific tap, it's constant... :hmm:
    Check out this thread over at the MetroAmp forum:
    MetroAmp.com Forum • View topic - Negative feedback wire connected to speaker output jack?
    Cheers!
    :dude::dude::dude:
  15. demonufo
    demonufo New Member
    Oct 23, 2010
    2,211
    256
    Actually that thread doesn't even go it it, really. The closest is the first reply, mentioning that on the jack the NFB is "on" regardless of the tap, which is pretty much what I've said in less detail.
    The NFB cannot change with the settings when wired directly to the speaker jack tip.
  16. Clammy
    Feb 24, 2010
    2,247
    1,614
    In the post that has
    "Marshall 101
    From "Clay's" x web site.
    Negative Feedback Circuit"
    at the top, it states this:
    "On some older Marshall’s (like my '69) the negative feedback (purple) wire was connected to the speaker jacks, so the feedback varies depending on which speaker impedance is selected."
    This jives with most things I've read regarding negative feedback, specifically regarding Marshall circuits and the purple feedback wire connection.
    Cheers!
    :dude::dude::dude:
    jcmjmp likes this.
  17. chuckharmonjr
    Mar 26, 2010
    8,808
    4,281
    The Marshalls that have the selector for impedance, with a speaker jack wired NFB it would HAVE to change. Set the jack for 8 ohms, the NFB would be off the 8 ohm middle tap of the transformer, set it for 16 ohms the NFB would see the full secondary.
  18. chuckharmonjr
    Mar 26, 2010
    8,808
    4,281
    An amp with dedicated jacks and no selector like the DSL, yeah it would be the same regardless and wouldnt change, but the selector changes the whole ballgame.
  19. demonufo
    demonufo New Member
    Oct 23, 2010
    2,211
    256
    :confused:
    Gonna have to start looking at schems and layouts now.
    Have I been confused all this time?
  20. dread1
    dread1 Well-Known Member
    Sep 29, 2008
    1,072
    56
    Northern New Jersey
    I know exactly what he's saying. In one band that I was in, the other guitarist and I had 2210's with 1960 cab's. His cab was wired for 8 ohm's, while mine was wired for 16. I noticed that his amp had a more up front and in your face sound. It just cut through the mix better. I also had no idea you were supposed to change those glass bottle's that get hot in there either! :lol: I really didn't do any investigation, but always thought from then on that it had something to do with the sound.
