10w Sol Clone
Discussion in 'Building the Classics' started by Timbo, Apr 18, 2019.
  1. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    Hi guys, There has been a fair bit of talk about the Soldano SLO around the local guys and all rave about them.
    Not that I NEED a 100w monster.
    So in my travels on the net this came up. [​IMG]
    http://diy-fever.com/amps/5-watt-slo/
    What a beast!!!!
    I quickly contacted my valve supplier and he's got hundreds of EL91s, great.
    As you can see Gary Moore is at the top of the list of my favourites and I was unaware that he played SLO's. [​IMG]
    This one always makes me CRY [​IMG] [​IMG]
    So a tribute the greatest blues guitarist.
    Because the EL91 are plentiful I'm going up the output to about 10w, if I'm lucky
    The VVR will keep the EL91s happy and the preamp, PI will get the full treatment
    The schematics will be updated as we go along.
  2. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    This one always makes me cry
    The clips didn't attach on the first post
    tce63 likes this.
  3. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
  4. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    A good day in the shed.....
  5. jensvonbustenskjol
    Feb 5, 2012
    611
    212
    Norway
    Hi Timbo
    What a great idea :applause:
    Good luck!
  6. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    Thanks
    Some progress...
    For what it worth I have included the active FX loop as per the SLO schematic.
    The reverb will remain. I'm haven't decided on a spring reverb or a Belton brick.
    jensvonbustenskjol likes this.
  7. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    Hi guys, Wiring is just about done.
    Reverb yet to be added.
    I'm also toying with adding a small choke to the preamp power supply. Thoughts.....
    The relays will be switched via a foot switch only for the moment.
    No "bright caps" added, play with that bit later.
    royslead likes this.
  8. jensvonbustenskjol
    Feb 5, 2012
    611
    212
    Norway
    Looking good!
    I'm curious towards your relays. What type are you using?
  9. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    I don't think they are anything special, I get them from a local electronics part store.
    I have used them many times before as they are quite when switching.
    they run on 12vdc, so I have wired the heaters on 12.6vdc.
    There is a dropping resistor on the supply that sets the voltage around 12.6 and when all relays are engaged the voltage drops to about 12.4V
    https://www.jaycar.com.au/12v-dpdt-special-pc-mount-relay/p/SY4052
    Guys, We have success [​IMG]
    No problems with startup, just a couple questions.
    The depth control doesn't do a lot [​IMG]
    The original schematic has a 39k resistor in the FB circuit and connected to the 4ohm speaker tap.
    I don't have a 4ohm tap only 8, does the resistor need to be halved??
    It goes from zero to flat out in in a small rotation of the gain/volume controls. Reduce the volume controls to 500k?
    I post voltage after I roll some more EL91 to get a closer matched quad. [​IMG]
  10. jensvonbustenskjol
    Feb 5, 2012
    611
    212
    Norway
    Cool! Congratulations!
    I'm looking forward to your report on any pops when operating relays
  11. Thiez
    Thiez Well-Known Member
    May 9, 2012
    501
    267
    Netherlands
    I build myself a 100w SLO. The amps really have a sound on its own. I love the clean/crunch channel. The lead is a bit of love/hate... its amazing for smooth singing saturated leads, but not as good for face ripping raw shred solo's i think.
    Does the low output still make it sound like an slo? Guess it does, since the slo is mainly preamp focused sound.
    I did a dual eq, and have to say its amazing. Gives you a lot more control over the sound of the two channels. As well and a switchable brightcap on both channels.
    Warren haynes is also a knows SLO player with an amazing sound. Even SRV had played SLO somewhere in time.
  12. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    The relays work great , no pops.
    Hey Thiez, Got a few little problems to sort out.
    I think the little output valves are getting a bit of a hammering.
    It also has some hum I want to track down.
    I'm putting a 1x12 combo cab together so I can get a better idea of sound.
    Sounds pretty good so far.
  13. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    Hi guys, The SLO CLONE is just about done.
    Hunted down a small hum, turned out to be a dodgy pot and a couple of resistors. :bat
    Working on a 1x10 cab. :thumbup:
  14. jensvonbustenskjol
    Feb 5, 2012
    611
    212
    Norway
  15. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    Thanks mate, Got a bit adventurous with the tolex.
    The purple snake skin doesn't show up well in the photo's, very happy with the end result.
    pulsonicsound likes this.
  16. pulsonicsound
    pulsonicsound Active Member
    Apr 6, 2019
    89
    123
    one of the guys I use for my amp servicing had a Soldano in today from 1989, its the first time I'd heard one in person and it did sound great!
    its just annoying when stuff thats super expensive sounds great..
  17. Amadeus91
    Amadeus91 Member
    Apr 9, 2019
    42
    39
    That is truly a first class build inside and out.Respect.
  18. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
  19. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    Hi guys, My stunt guitarist has put the amp through some awesome pickin.
    Mixed results...
    With the chassis in it's new box the hum still persists.
    Removed V3 the hum becomes very faint.(controls at 0)
    Removed phase inverter hum still remains.
    When adjusting the bias the hum almost disappears.
    Valves replaced and hum is loud and gets louder with volume controls turned up.
    Whilst playing slow and cleanish overall sound was great.
    Kicking into overdrive also sounded great when strumming and lightly picking but digging in things started mushing together.
    At this point I not sure if this was some blocking distorting.
    Even with the split plate resistors on the phase inverter and the 10k grid stoppers I think the grids are still getting a hammering.
    My next thought is to add a PPIMV to help tame the drive????
  20. Timbo
    Timbo Active Member
    Oct 29, 2009
    102
    103
    Hi guys, some more testing has been done...
    Haven't been able to track down the hum....
    I added a PPIMV and lowering the gain to the EL91s gave better control over the gain/volume pots.
    I replaced the pot with resistors and was able to dial in some great drive.
    But there is still a little too much drive when the lower notes are played.(notes get a bit flabby)
    So my next job will be to replace the .047 coupling caps to the power valves with either .022 or .01
    Hopefully this will help the flab.....
