10 Watt Plexi / JTM45 Tribute amp build
Discussion in 'Building the Classics' started by Guitar-Rocker, Oct 9, 2019.
  1. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    Indianapolis, Indiana
    Here is an amp that I built for myself, a Tribute to the early days of Marshall. It's a 10 Watt 6AQ5 power section dual channel amp.
    Flip the left switch to the right and the preamp is a JTM45 Normal channel Hi or Low, and toggle the right hand switch up and it's a JTM45 Bright channel Hi or low input. Flip the left switch to the left and it's a Bright channel Plexi Hi or Low input.
    The power section is cathode bias, built with all of the good parts, ClassicTone PT, MPS OT, ClassicTone choke, pec pots, mustard caps, Draloric resistors, Cliff jacks.
    For the record, I've never put another makers badge on an amp, but since this is a tribute to the glory days, I allowed myself that one time. And the amp stays here for my personal use.
    Sustainium, pedecamp, tce63 and 11 others like this.
  2. South Park
    1,232
    927
    Nice build what size choke do you have.how Much voltage sag do you get.
    Guitar-Rocker likes this.
  3. Ken Underwood
    Oct 16, 2013
    373
    1,030
    It would be nice to tribute this to the late Dudley Craven who without him there would not have been a JTM45, also its so nice to see the most basic detail of the red and black twisted pair on the heater wiring which is always a good pointer to proving that it is a genuine original and not a fake as there are many that claim to be but in fact not so.
    Well done and i know that Dudley would be impressed.
  4. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    Thank you Ken, I am most honored. A nod to Dudley Craven will be added to the chassis.
    4Horseman and NewReligion like this.
  5. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    The choke is a 4 Henry, 50mA, 150 ohm.
  6. Ken Underwood
    Oct 16, 2013
    373
    1,030
    Thanks mate, i will send the pictures to Dudley`s wife in BC Canada, send me a picture with his name on it if you could as i know she will be made up.
  7. lespaul339
    lespaul339 Well-Known Member
    Dec 28, 2010
    393
    297
    Iowa
    Nice build!
  8. South Park
    1,232
    927
    I like the idea of the use of the 5aq5. Nice over drive tones
  9. Ken Underwood
    Oct 16, 2013
    373
    1,030
    Thats a new one on me lol
  10. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    With all due respect to the legends of "Loud".
  11. Far Rider
    Far Rider Hendrixian VIP Member
    Apr 11, 2011
    6,986
    8,165
    Delaware
    Like all of your builds, a true masterpiece.
  12. NewReligion
    Nov 17, 2009
    11,011
    7,847
    Paradise
    Beyond Bad Ass Boss!
    Terry, I am really impressed as all of your work & teachings are & have been above reproach. This Amp goes over the top my friend. I am delighted to call you friend and Mentor. No doubt Ken Underwood is pleased with this work. Very professional. I love the ceramic capacitors.
    David Hopkins...♫
  13. Ken Underwood
    Oct 16, 2013
    373
    1,030
  14. Amadeus91
    Amadeus91 Active Member
    Apr 9, 2019
    115
    159
    A work of art, in the truest sense.
    Sir Dudley Craven RIP.
  15. neikeel
    3,654
    2,077
    Very nice indeed.
    How do you find the preamp options in use? Do you switch around much?
    How did you decide on those output valves?
    Sorry if too many questions!
  16. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    7,060
    4,662
    North
    Very nice GR ! I finally got a different chassis for my build . I don’t have even 1/100 the skill. I really like the JTM/Plexi idea. I was just going to do the 4 input 2 volume but mine is more on a budget and some of the stuff you have is hard to find. I will try but mine will not compare. I am just trying to copy the circuit only.
    Great work as always.
  17. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    I like that it gives me two distinct options to use, depending on what I may like to use on any given day, and yes I flip back and forth depending on the mood.
    I stumbled across the 6AQ5 several years ago and find it has an amazing ability to sound like a "Big Bottle power tube". The 6AQ5 was designed as an audio power tube and is a alternative in most respects for the 6V6, only in a smaller glass package (7 pin) and less wattage. However it is a loud 10watts at full bore.
    I should note that the 6AQ5 has plate voltage limitations as the plate is next to the outside edge of the glass, and maximum over voltage can burn a hole through the glass.
    www.r-type.org/pdfs/6aq5-2.pdf
    Far Rider, ibmorjamn and NewReligion like this.
  18. Ken Underwood
    Oct 16, 2013
    373
    1,030
    Just had a mail back from Barbara Craven who is made up with what you have done and she would like to contact you personally. If you contact me direct on keng3sdw@gmail.com i will then give here your email address, if that is OK with you of course.
  19. NewReligion
    Nov 17, 2009
    11,011
    7,847
    Paradise
    Very Sweet indeed. God Bless you all.
    David...♫
  20. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    D
    Done, thank you Ken.
