MarshallForum.com
Reply
Thread Tools Display Modes
Old 10-20-2009, 01:54 PM   #1
Mike_j
Senior Member
Mike_j's Avatar
DSL 50 C12 mod advice please
Hi,
I been reading a fair bit about the C12 mod on DSL 50 heads and have 2 questions:
1. Does it add more "body" to the red channel bringing it a bit closer to the fullness of the green channel, and take out some of the thin high end fizz?
2. Realistically, how hard is it for a complete beginner to do? Is it just a case of unsoldering the capaciter?
Any help/comments appreciated. Thanks.
__________________
"...the world is your oyster but your future's a clam..."
Mike_j is offline   Reply With Quote
Old 10-20-2009, 02:31 PM   #2
Wilder Amplification
Senior Member
Wilder Amplification's Avatar
Re: DSL 50 C12 mod advice please
Quote:
Originally Posted by Mike_j View Post
Hi,
Unless you have a solid grasp on basic electronics, I advise against attempting anything inside of a valve amp simply due to the high voltages that exist inside of them (up around 400-500 volts...much higher than what comes out of your wall). I suggest you take it to a reputable tech who's familiar with valve amps.
As far as the mod, I have no idea since I've never played much through a DSL amp other than to test one out after fixing it.
__________________
Jon Wilder
http://www.wilderamps.com
Old 10-22-2009, 05:10 AM   #3
Mike_j
Senior Member
Mike_j's Avatar
Awesome. Thanks for that.
__________________
Old 10-22-2009, 08:44 AM   #4
jcmjmp
Senior Member
C12 is a relative to a specific given set of board revision/issue numbers. It should be pretty simple to do but unless you know what the cap is supposed to do, it will be hard to determine if you're removing the correct component.
what is it that you're trying to fix? You want more bass on the Red Channel? Beware - too much bass on a high gain channel can lead to flubbyness.
jcmjmp is offline   Reply With Quote
Old 10-22-2009, 12:50 PM   #5
Mike_j
Senior Member
Mike_j's Avatar
jcmjmp
I'm finding the red channel too "thin". I'd like to get it a bit more full sounding.
I'm taking it to my tech guy tonite but I'd like to be able to offer up some suggestions to him.
__________________
Old 10-22-2009, 12:55 PM   #6
jcmjmp
Senior Member
jcmjmp
Maybe your tubes need changing?
I can't describe the lead channel as "thin". Do you have an eq pedal or rack mount? If so, experiment with it in the loop and try to figure out which frequencies fill the sound up and take it from there.
"Thin" sounding is highly subjective.
Old 10-22-2009, 01:49 PM   #7
Senior Member
Not knowing much about the DSLs having never owned one, according to the schematic for the DSL50, from what I can see C12 is a 470pF cap in the reverb recovery stage. If that's the case, I doubt a mod having anything to do with that cap will help you.
__________________
Jon Wilder
Old 10-22-2009, 02:06 PM   #8
jcmjmp
Senior Member
Quote:
Wilder: As I've already stated in an earlier post, C12's location and function is different depending on the board you're looking at and the issue/rev you have...
He's probably referring to the treble bleed cap on VR3, on the control board.
Old 10-22-2009, 02:18 PM   #9
Senior Member
Based on this, am I to assume the component IDs on the master schematics mean nothing due to the few board revisions they've had on these amps over the years?
Or do they come up with updated schematics with revised component IDs everytime they revise a board?
__________________
Jon Wilder
Old 10-22-2009, 04:52 PM   #10
jcmjmp
Senior Member
1) There's the HW board rev - JCM2-60-00 where the "00" is the rev number. This is a different physical board and layout, which also means different component IDs.
2) There's the Issue number. This is a "soft" change where certain component values might change, but its essentially the same board.
Schematics for the DSL specify which HW board and issue number they are for.
I'm actually working on a DSL info page that will contain some of this info, along with upgrade components and tips/tricks.
www.lydian.ca
If just have to get over my chronic insomnia and get some energy back before I can start putting some real time on the page. I also want to get my PT/OT protos tested.
Old 10-22-2009, 05:03 PM   #11
Mike_j
Senior Member
Mike_j's Avatar
Thin, fizzy, no body of fullness to the tone. I want the red channel a little closer to the tone of the green but still retain some overdrive. Sorry, I can't be any clearer.
__________________
Old 10-22-2009, 05:32 PM   #12
jcmjmp
Senior Member
A bad tube could cause that, which is why I suggested a tube swap.
Looking for more bass? Low Mids? High Mids? Does it sound like you want with the deep switch in?
Old 10-22-2009, 06:01 PM   #13
Mike_j
Senior Member
Mike_j's Avatar
No. The red channel still sounds pretty gutless. Yes, the tubes probably do need changing and I'll get tech guy to do that. I'm not sure that would explain the tone disparity between the 2 channels. Either my amp is ****ed or it is the way the amp is designed.
__________________
Old 10-23-2009, 03:58 PM   #14
Buggs.Crosby
Banned
Read this whole thread....there is lots of info and i'm sure you will find what your looking for in it....15 pages though
The Marshall Amp Forum: • View topic - DSL100 too bright compared to my 401, any ideas on modding?
Buggs.Crosby is offline   Reply With Quote
Old 10-24-2009, 04:13 AM   #15
Mike_j
Senior Member
Mike_j's Avatar
Got it sorted. Thanks all for the help.
Took it to my tech guy who suggested changing the capacitors (that he felt were low quality), test it out in a band and recording situation BEFORE deciding to start pulling things out.
I felt it was good advice so I'll go with that. He also thought the power transformer was pretty ****ty too and that could be in for a change a bit further down the track.
__________________
Old 10-24-2009, 10:58 AM   #16
jcmjmp
Senior Member
Good Idea.
Old 10-24-2009, 10:54 PM   #17
MaidenStrat02
Senior Member
MaidenStrat02's Avatar
The C12 mod is pretty much automatic these days. Some people swap out different values, I clipped it. Cuts down on that harsh treble in the Ultra channel
__________________
Jackson Soloist
Les Paul Standard Plus Desertburst
SG
wiring harnesses by Jonesy Blues
Dave Murray Strat
DSL40c w/Heyboer choke, Classic Tone O.T. & Celestion Creamback
Pedal Train boards w/Voodoo Labs Power Plus2's Pitchblack, Fulltone Fat Boost, Rat Dist., Ibanez SD9M, Boss SD-1 and DD-7,MXR EQ Phase90 Micro Flanger & Carbon Copy, F/X loop switcher, BYOC CE1 Clone, EH Electric Mistress and Soul Preacher, George Lynch Wah, and George L's & Monster Cables.
MaidenStrat02 is offline   Reply With Quote
Old 10-29-2009, 01:22 PM   #18
Ken
Senior Member
Ken's Avatar
Hmm...on my DSL 50 the ultra channel is noticable brighter than the green channel like everyone talks about but it's not "harsh" at all. With the added distortion I like that brightness; to my ears it enhances the tone just right. I wouldn't change it.
Frankly I don't see the point on having both channels sound the same except for overdrive; I've read complaints about the shared EQ meaning you can't make them similar and I have no problem with it. It IS a TWO channel amp after all, not a one channel with a massive gain knob. Both channels SHOULD sound different!
Ken
Ken is online now   Reply With Quote
Old 11-27-2009, 06:47 PM   #19
AdamR
Senior Member
AdamR's Avatar
This is the same issue Im having with my DSL50. The red channel just sounds think to me know matter how I EQ it.
AdamR is offline   Reply With Quote
Old 11-28-2009, 09:41 PM   #20
solarburnDSL50
Senior Member
solarburnDSL50's Avatar
Quote:
Try this. Put the red channel on lead 2(button in):
Presence-0 to 2 or 3
treble-4
mids-7
bass-4 or 5 bass boost in
Gain-3 or 4
volume-3
Toneshift button out
Clean boost lead 1 to warm it up. Tubes that are warm and dynamic help. Speakers and cab can warm it up. EQ in the loop may help. Guitar and pick ups can warm it up. Acoustic foam placed a certain way on the speaker cab can control ice pick frequencies.
I'd mod it last but that's me.
__________________
Joey Voltage 2203 JMP on a stack of GB's=Panty dropping tone
DSL40C
Orange OR15
1990 Infinium
1960 Infinium
Hit the front end man. Your amp sauce is weak.
Thor's Hammer
Quote:
Originally Posted by Rockin_Lisa View Post
Where the hell is dirty ole Joe at?
Its "Boo-tique" fellas cause that price scares the tone out of my fingers...
solarburnDSL50 is offline   Reply With Quote
Old 11-29-2009, 08:28 AM   #21
AdamR
Senior Member
AdamR's Avatar
Thanks, Ill give those a settings a shot.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
