MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 10-15-2009, 10:12 AM   #1
Reginald
Senior Member
Reginald's Avatar
Exclamation which of both runn the amp to work less hard?
which of both will running the amp to work much less hard?
and What's the difference ? both are 16ohms?
them look wiring in different way...I don't know
I think that one is a vintage wiring and that one is a modern wiring......does they run the amp in different way or not?
Reginald is offline   Reply With Quote
Old 10-15-2009, 11:33 AM   #2
T-Bird
Senior Member
Re: which of both runn the amp to work less hard?
Hi.
Looks a lot like a normal series/parallel wiring on both to me.
Regards
Sam
T-Bird is offline   Reply With Quote
Old 10-15-2009, 12:14 PM   #3
Reginald
Senior Member
Reginald's Avatar
Quote:
Originally Posted by T-Bird View Post
Hi.
Regards
Sam
they are both 16+16 parallel 16+16=32parallel32=16ohms
or they are 16 parallel 16+16 parallel 16 = 8+8=16ohms ?
they look the same ,,but they're not the same.....look
Old 10-17-2009, 10:40 PM   #4
Wilder Amplification
Senior Member
Wilder Amplification's Avatar
The second pic is hard to tell what it is cause I can't tell whether it's full parallel or if it's parallel series. But the first cab is wired series parallel, which with four 16 ohm speakers will be a total 16 ohm load. This is because for each pair that's in series, the impedance is additive so you end up with 32 ohms for each pair. Then when you place the pairs in parallel with each other, that cuts the 32 ohms in half back to 16 ohms.
As far as which one "works the amp harder"...neither. This is what the ohms selector switch is for...to ensure that your valves always see the same load and the speakers consume the same amount of power no matter which speaker config you're running. The ratio between voltage and current will differ from one load value to the next, but the power out will be the same.
On a 50 watt amp assuming you're running at max clean power at one frequency -
4 Ohm Load - 50 Watts = 14.14 Volts @ 3.54 Amps
8 Ohm Load - 50 Watts = 20 Volts @ 2.5 Amps
16 Ohm Load - 50 Watts = 28.28 Volts @ 1.77 Amps
On a 100 watt amp assuming you're running at max clean power at one frequency -
4 Ohm Load - 100 Watts = 20 Volts @ 5 Amps
8 Ohm Load - 100 Watts = 28,28 Volts @ 3.53 Amps
16 Ohm Load - 100 Watts = 40 Volts @ 2.5 Amps
As you can see, as the load impedance increases, the voltage drop across the speaker also increases while current draw decreases. Also, if you look at the 4 and 8 ohm values for the 100 watt and compare them to the 8 and 16 ohm values for the 50 watt, you'll see that the voltages are the same on these loads with double the current on the 100 watt. You'll also notice that the 8 ohm load on the 100 watt is the same current draw as the current draw through a 4 ohm load on a 50 watt, but double the voltage on the 100 watt. The 100 watt produces double the voltage on the bigger load because the 8 ohm speaker on a 100 watt can pull more current than it can from a 50 watt simply because the current is there to pull. The more current flowing through a given resistance/impedance (i.e. the speaker), the higher the voltage drop across it (resistance to current flow creates voltage, just as resistance to water flow creates pressure).
__________________
Jon Wilder
http://www.wilderamps.com
Old 10-19-2009, 10:15 AM   #5
Reginald
Senior Member
Reginald's Avatar
So,if a 100W amp will run to 16ohm ,it will work much more hard because it produce much more Volts ,while 4ohms makes it work much less hard because the amp will produce less Volt...
I think about the Output Transformer ....it will work much less hard to 4ohms.
it's correct? or it's the opposite?
Old 10-19-2009, 12:04 PM   #6
Senior Member
NO!
Read the post again...NEITHER WILL MAKE IT WORK HARDER! Higher voltage/lower current doesn't make it work any harder than lower voltage/higher current. It's all about POWER, which is voltage and current combined.
POWER is a measurement of WORK PERFORMED, so since you're putting out the same power in every configuration, your amp is not working any harder with a 16 ohm load than it would with a 4 ohm load. A 4 ohm load isn't gonna make the transformer live any longer than a 16 ohm load. When the impedance selector is set accordingly and you're running a matched load, the valves see the same load regardless of speaker cab impedance and will pull the same amount of current through the primary side of the transformer. Only the voltage/current ratio will be different on the secondary side.
The ponit is, you have to run a matched load, i.e. set the selector to 16 ohms for a 16 ohm load and set it to 4 ohms for a 4 ohm load.
Voltage is just the force created by a charge difference between two points when you have more electrons available on one side of a circuit than the other. Current is the actual flow of electrons. Combine the two and you have Power.
Make sense?
Besides...treated right and ran with a matched load at all times an output transformer will virtually last forever. A lot of vintage amplifiers are still running their original output transformers they came with over 40 years ago and believe me, every one of them you can pretty much guarantee back then was being ran flat out cranked so that should tell you something about how well they hold up under proper operating conditions.
__________________
Jon Wilder
Old 10-20-2009, 02:56 AM   #7
thrawn86
Senior Member
NO!
Make sense?
Jon, I think Reggie's asked this question like a billion times already.
__________________
-Martimus Maximus Tone Packs - MHD Pickups - OFA Pedals-
thrawn86 is offline   Reply With Quote
Old 10-20-2009, 03:28 AM   #8
Senior Member
Quote:
Wow...that's one of my biggest pet peeves is when person A asks a question, person B who has the knowledge takes the time to type something out that took him time to learn in very simple terms, and then person A responds and it's evident that person A didn't read 1 word that person B just took the time out of his day to figure out how to relate it in simple terms and type it out. If you're not even gonna take the time to read the answers to your question, why even post the question?
Furthermore...valve amps have gotten a very bad rep over the years. Misconceptions about them being fragile and finicky and blowing up all the time. This is not the case...there are just some simple rules you have to follow with them. As long as you're running matched or close to matched loads, the bias is adjusted properly and the tubes aren't worn out, these things can more than handle being pushed to the absolute limit and live to do it repeatedly. I ran my Super Lead clones weekend after weekend flat out cranked through a Power Brake for 3 years straight...transformers so hot you couldn't comfortably place your hand on them for a good 20 minutes after a 4 hour gig...and never once did I have a failure. I even had a backup Super Lead clone head on the ready in case of one, but I never had to use it. As long as you replace your tubes when the amp starts "losing its tone", the bias is set properly, and your matching your loads properly and not running the amp without a speaker hooked up to it, these things are a lot more durable than you think...a lot more than solid state amps IMHO. Try running a solid state amp like this and see how long it lives.
__________________
Jon Wilder
Old 10-20-2009, 05:50 AM   #9
Reginald
Senior Member
Reginald's Avatar
well,I'm afraid
the fact is that I've got my first vintage amp and I've fear to damage it.
I'm a unknowing boy ,so I make many questions for surely,you know.
listen this:
Is the filter caps value correct here?Or is it possible to upgrading it?
A repairman has replaced filter caps.
About tubes....theese ugly,smaller,lower Sovtek tubes will the amp work good? or the Output Transformer would work less hard with the NOS GEC KT88? the same question is also about the filter caps...May I let on theese
or better repalce them with upgrading ones? you consider this question also about Sprague Atom black caps into circuit....thanks so much
Old 10-20-2009, 05:55 AM   #10
Reginald
Senior Member
Reginald's Avatar
well,I'm afraid
listen this:
theese others are some shots after the replacement ...
Old 10-20-2009, 05:59 AM   #11
Reginald
Senior Member
Reginald's Avatar
black Sparague Atom caps into the preamp-circuit...is it possible upgrading all theese caps and filter caps...or I should leave the world for itself?
sorry if some shots are unfocused...but two blue F&T filter caps are 100+100uF and the third (near power tubes) is only 50+50uF....the two black Epcos near the Mains Transformer are both 470uF ...and about into the preamp-circuit the Sprague Atom are 50 it seems ..instead the two into the power circuit are only
10.................what,which of all them should I upgrading? about to replace theese ugly tubes?does the Output trans. would work worse with theese ugly Sovtek tubes instead NOS GEC?
Old 10-20-2009, 06:11 AM   #12
Senior Member
OK...just so you know -
Get the whole "what makes the output transformer work more/less hard" idea out of your head. This is simply not a problem unless you set the ohms selector on the back panel of the amp wrong for the cab you run. One tube doesn't work it harder than another, different cabinet configurations between 4, 8 and 16 ohms don't either. You just have to make sure you set the ohms selector to 4 Ohms if running a 4 ohm cab, 8 ohms when running an 8 ohm cab, and 16 ohms for running a 16 ohm cab.
When everything is set up properly, VOLUME is the only one thing that will work the transformer "harder". The more you crank up the amp/the louder you play, the harder you work the output transformer. But that goes for the valves, the power transformer...pretty much every component in the amp, not just the output transformer. And it doesn't matter what valves you have, what speakers you have, etc etc. The louder you play, the harder the amp has to work regardless of anything else. That is the ONLY thing that will work the amp harder is how loud you play it.
However, as I mentioned before, if the amp is set up correctly with good tubes, biased properly, and the ohms are matched to the cab you're running, this simply is not a problem. Transformers are a lot more durable and robust than most give them credit for. Unless you have something hooked up wrong between the amp and the speakers, or the ohms selector is set wrong, or the valves are biased too hot, this is just not a problem at all.
Also, if I were to buy any used amplifier, I would have the valves replaced with new ones and rebiased by a tech.
Those filter caps are not only not the original caps, but they're not even the same value. Electrically, this is fine, but if you want the early sound that that amp originally had, I would consider getting those replaced with ones that are the correct value. The ones inside of the amp are fine...you don't need to mess with those. But the ones on top of the amp chassis next to the tubes I would consider definitely replacing those with the correct value.
BTW, what country are you in?
__________________
Jon Wilder
Old 10-20-2009, 10:47 AM   #13
Reginald
Senior Member
Reginald's Avatar
Hi,I'm an italian boy..
listen...you wrote about I should replace the caps on the chassis.. in old blue filter caps ,I don't able to read the value ...now ,I've not more them,for permit to see their value..
You intend for all 5 caps on the chassis,or only that two near the Power Transf.?
could you write the original value of theese five caps and suggest me a very good(the best) quality brand of them?what's the name of the old gold filter caps brand?they seem lower value compare theese ones black Epcos....previewusly you wrote about filter caps that if they are bigger value they are good....old gold caps were only 200uF ,while theese ones are 470uF..I don't understand because I should put in a smaller value.....yes,if I would the same original sound it would be so,but the ones bigger caps value is better for the best amp working.....isn't it?or not?
original gold filter caps are only 200uF,while the present ones are 470
so,they can fill more stored electrons compare the old ones
about others three near Output Transf. i don't know the old caps value because I don't wasn't able to read it for cause of a masking,scotch-tape covering them.
What's the old all filter caps value on the chassis in this amp? you know also the original caps value into circuit boards?
Old 10-20-2009, 12:33 PM   #14
Senior Member
Ok, I don't speak Italian, but I used a translator program to translate what I want to say hoping that it will be easier for you to understand so here goes.
Bene, senza sa che l'anno che l'amp era fatto io non può dirla. Hanno usato dei valori diversi da ‘62 -' 68. Da ciò che vedo in uno delle sue immagini, il pannello per circuito somiglia a un prima modello.
Per quanto "i cappucci di valore più grandi sono migliori" ...that è all'altezza di ciò che sembra lei ama. Il più grande il valore di cappuccio di filtro, il più "stretto" l'amp sembrerà. Il più basso il valore, il più "sciolto" sembrerà. Dipende da appena che le sue orecchie amano.
__________________
Jon Wilder
Old 10-20-2009, 09:38 PM   #15
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
Wow, something about Ohm's Law and a cup of coffee in Italian.
__________________
Old 10-21-2009, 06:08 AM   #16
Reginald
Senior Member
Reginald's Avatar
Wow,thank you ,for your italian translation,but it don't necessary you translate in italian your answers...don't matter.I speak english very bad,but if when I read english of yours,slowly,I understand enough...the problem is that I've no a computer with Internet,so,I use that one of council library.
they leave me to use it for only 30 minuts at day....so ,I can't read all things of yours.
About theese caps....you wrote smaller (as in old amps) you obtain a 'free' ,loose sound ,while bigger filter caps is equal to a tight sound....it's right?
I think I understand.....a bigger filter caps are a short of rectifier valve,is it so?
I think I should have get for english lessons,soon.
don't worry to reply in italian ,reply in english....I can use a on-line dictionary....and if you write in italian ,others people will don't understand nothing........and I woldn't learn ever the Enghlish as well
Old 10-21-2009, 01:27 PM   #17
Senior Member
No problem, you're doing fine.
As far as filter caps, no they're not a rectifier valve. They're a reserve of electrons. When the amp is being driven hard, it will have to draw a lot of current. The lower the filtering you have, the less electrons you have in reserve for the amp to draw when the amp needs them. Eventually the amp reaches a point where it's drawing enough current to load the power supply down and the power supply voltage will drop because it can't supply the current that the amplifier is trying to draw, dropping the headroom of the amp, and causing the amp to sound and feel "looser".
The higher the filtering, the more electrons available to draw when the amplifier needs them. Thus, the amplifier will not load the power supply as much, causing less of a power supply voltage drop, resulting in more headroom and a "tighter" sounding/feeling amp simply because more electrons are available to draw when the amp starts drawing them.
In other words, it's about supply & demand. When the amp DEMANDS the current, the power supply has to SUPPLY it. When the DEMAND exceeds the SUPPLY due to low filtering, the amp will sound and feel "loose". When the SUPPLY exceeds the DEMAND, it will sound/feel "tighter".
__________________
Jon Wilder
Old 10-22-2009, 12:28 PM   #18
Reginald
Senior Member
Reginald's Avatar
in another thread by MajorNut 1967 on 'Blackmore tone?'thread(let's talk vintage) ..he say that Majors tend to be like a bomb and break down their OT because have a sh*t OT....is it true?
Old 10-22-2009, 05:05 PM   #19
MartyStrat54
V.I.P. Member
This doesn't have a thing to do with your amp. Did you understand that? Your amp is not a Marshall Major. Your amp does not use an ultra-linear output transformer. You are taking bits and pieces from other posts and then you are asking questions that make no sense.
I don't think a boy should be working on a 220V amp in Italy. It sounds really risky.
__________________
Old 10-24-2009, 05:23 AM   #20
Reginald
Senior Member
Reginald's Avatar
In italy the standard voltage power line (from the wall ) is 220V....What's risky.....I'm obligated to set any amp so....220 is the voltage power line....do you think I could fry the amp? I set it at 220 because from the wall is 220.
About major of mine,
you're wrong....my amp is a Major....(sorry the unclean nail of mine...I was working?)
So,what's a ultra-linear OT and why is it 'crappy'?
what's the difference between a 100W OT and a ultra-linear Major OT?
I own this Major but I not play it because I haven't time...
supposing I set to 10 of volume and I play a '70 100 Superlead and a '70 Major (like of mine) for 10 consecutive hours ....which of their OTs will blow up,break down at first...and why?
Old 10-24-2009, 04:22 PM   #21
Senior Member
Jesus...NEITHER one will blow if everything is right.
Ultra-linear transformers were intended for hi-fi (pro-audio, home stereo, etc) applications. Guitar amps are not hi-fi and for tone reasons you do not want them to be. They would have too clean of a sound and wouldn't sound like a normal valve guitar amp. An ultra-linear output transformer will not distort as much as a non-ultra linear and some people like output transformer distortion, and those people are the ones who say that ultra linear transformers are crappy.
What are you not understanding about this? Blowing output transformers is not as common as people would like you to think it is if you set everything up right, like set the amp impedance to the speaker cabinet impedance, run good valves (by good I mean valves that aren't old and about to fail) and get the bias adjusted right, and don't run it without a speaker cabinet connected to the amp. I ran my amplifiers every weekend for a 4 hour period fully cranked to the max for 3 years straight. After a show the transformers were hot enough to where you couldn't rest your hand on them for longer than 5 seconds comfortably. The ONLY time I EVER blew an output transformer was because a bartender spilled a drink into my amp. Other than that, after 3 years of running flat out cranked to the max every weekend I've never had one blow.
__________________
Jon Wilder
Old 10-26-2009, 12:52 PM   #22
Reginald
Senior Member
Reginald's Avatar
well,thatnk so much
I think the same...but those people on other forum sustain the 'crappy OT' theory....instead I think is good....now,I havn't other question...but in future,when I will have get,I would like listen again you,ok?
ciao friend and thanks for your support...your articles on amp working,amp help,etc.. are beautifull. un ciao anche a tutti quelli su questo bellissimo forum
(translation: also a 'bye' at all people of this great forum)
Old 10-27-2009, 12:30 PM   #23
Reginald
Senior Member
Reginald's Avatar
Hey Jon,
I've ring a bell,I have in mind that one thing that I forgot to ask you,listen this..
it's about the chewy,magic rub which there's on old Marshalls...when you hit a chord,a note you feel as a short of magic rub,chewy feeling....you don't feel the steel of the chord but you feel like as a 'magic rub' feeling ,you know
...what's that and what is it caused by?What's the cause of its? from the OT? What's the secret of this 'magic rub', 'magic chewy' feeling ?What's the componrnt that create it?
Thanks
Old 10-27-2009, 09:46 PM   #24
MartyStrat54
V.I.P. Member
I think it's 1970 and I just ate a tab of acid.
__________________
Old 10-27-2009, 09:59 PM   #25
solarburnDSL50
Senior Member
solarburnDSL50's Avatar
Leave my chewy mids alone man!!!
I'll see ya when you get back from your trip...
__________________
Joey Voltage 2203 JMP on a stack of GB's=Panty dropping tone
DSL40C
Orange OR15
1990 Infinium
1960 Infinium
Hit the front end man. Your amp sauce is weak.
Thor's Hammer
Quote:
Originally Posted by Rockin_Lisa View Post
Where the hell is dirty ole Joe at?
Its "Boo-tique" fellas cause that price scares the tone out of my fingers...
solarburnDSL50 is online now   Reply With Quote
Old 10-27-2009, 10:19 PM   #26
MartyStrat54
V.I.P. Member
That's the beauty of this chewy rub...stuff. You take some and it's like taking a trip without ever leaving the front porch. Magical chewy rub...stuff.
__________________
Old 10-28-2009, 09:50 AM   #27
Reginald
Senior Member
Reginald's Avatar
none 'trips' ...I don't understand your 'slang'...maybe you not understood my question.
I talk about that unique feeling there's in old amps....it's like a short of chewy touch when you hit the chord...magical chewy rub ....it's strange and great,you know.....what's the cause of this magical chewy touch?
Old 10-28-2009, 10:04 AM   #28
Senior Member
Some of that is the OT, some of it is the fact that some amps used lower value filter caps in the power supply, which caused the amp circuit to "load" the power supply too much when the amp is fully cranked and the power supply voltage would drop quite a bit, causing that "spongy" sound you refer to (also known as "sag"). On your amp, your filter caps are a rather high value...higher than what they came stock with so you've probably noticed that yours doesn't do it nearly as much as some of the earlier Marshalls do.
This is the main reason why some people say that ultra linear OTs are crappy. They're made NOT to saturate, and OT saturation is a part of this "spongy" sound/feel as well. On top of that, EL34 valves have lots less headroom and distort a LOT more than KT88s, which also adds to it. Power supply voltage also plays a part somewhat along with bias setting.
__________________
Jon Wilder
Old 10-29-2009, 07:57 AM   #29
Reginald
Senior Member
Reginald's Avatar
Hi Jon,
about that spongy sound I think it is the result of a lower response than a faster response in newer Marshalls...
about filter caps I remember you told me about bigger value is more tight sound,smaller is more 'free' sound...so,bigger it should has get more saturation than smaller,not?
Major of mine is very 'spongy' and very slow response
Old 10-29-2009, 12:53 PM   #30
Senior Member
Hi Jon,
Yes, the "spongy" sound is a slower response. The bigger value filter caps should have more electrons in reserve to supply when the amp demands them, which makes the amp respond faster.
However, what channel are you plugging into when you play through it? If you're plugging into Channel II, try plugging into Channel I instead and crank Channel 1.
__________________
Jon Wilder
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
