MarshallForum.com
Reply
Thread Tools Display Modes
Old 02-29-2008, 05:19 PM   #1
GrampaBob
Junior Member
How do you setup a full stack from half stack?
Simple question but I'm kinda wondering more about how the head acts differently between 1 or 2 cabs plugged in.
I have a VS100 head and cab. Now does the head work at 100watts thru the single cab right now....and if I get another cab, does the power switch to 50watts to each cab or...?
I have a buddy selling his Valvestate 1 Head and 4x10 cab and I wanna just use the cab and make mine a full stack.....possible or do I have to worry about ohms and all this?
Maybe its best to use both heads and cabs in a stereo effect? I'm not sure what to do.
GrampaBob is offline   Reply With Quote
Old 02-29-2008, 11:06 PM   #2
2001rt
Junior Member
Re: How do you setup a full stack from half stack?
I have an MG100HDFX full stack. The DFX has one speaker output and my HDFX has two. The Manual for my amp simply says that it puts out 100w RMS where the total load impedance is 4 ohms or more. It looks to me like even though it's two cables into two cabs, it gets treated like a single 8-speaker cab.
This page has all of the Marshall amp user manuals. Marshall Amps :: Downloads
Good luck!
2001rt is offline   Reply With Quote
Old 10-28-2011, 09:40 PM   #3
Johnny Blade
Johnny Blade's Avatar
I have the exact full stack as you. with one cab ie halfstack you are running at 8 ohms, therefore only 50 watts. still a loud ************, but plug in the second 4x12 and now you are 4 ohms at 100watts RMS (keep it on mono,) it is a beast, and you will know where that extra money went to when you hear the difference in fullness and increas in bass, and the extra volume from doubling the wattage. It screams, no need for any pedals, just plug in and turn gain to 7 and master to like 6 or higher (i like 10) so I hoped that answered your question. PS, make sure you are using 1960 300 watt cabs for maximum effect.
Johnny Blade is offline   Reply With Quote
Old 10-29-2011, 08:55 AM   #4
TPR
Senior Member
TPR's Avatar
Quote:
Just wanted to mention that the output change that happens on solid state power amps does not happen on tube power sections. With tubes, the power rating is the same regardless of the impedance. Just something to keep in mind if you ever get an all tube amp.
Grampa, yes, you have to worry about the ohms (impedance), so check the marshall handbook for your amp and search the cabinet and speaker section of this forum if you still have questions. Post questions if you still need to. Keep these things in mind:
- If you have two 8 ohm cabs, the impedance will halve whether you plug each cab into inputs on the back (generally understood) or from one output > cab > cab (not generally understood).
__________________
'07 VM 2466
'89 JCM 800 2205
'68 Bassman Head- Blackfaced
DSL401 - Headified
1965 Stack
Hand Built 2x12
Classic 30
Gibson LP Studio w/ PAFs
Epi LP Standard w/ G 57s
The usual assortment of pedals and stuff
TPR is offline   Reply With Quote
Old 10-29-2011, 09:54 AM   #5
Adwex
Super Moderator
Adwex's Avatar
You can use both cabs, but the power output of the amp will increase, not deacrease. You must understand though, how impedance works, and that solid state amps are different than tube amps.
As TPR mentioned, when you plug two cabs into an amp, they are connected in parallel, If each cab has the same impedance (ohms), then the total impedance will be cut in half. So if you have two 8 ohm cabs, the amp will behave as if you have one 4 ohm cab.
SS amps also have a minimum allowable impedance (probably 4 ohms, but it should be labeled on the back of the amp. Don't go below this.
And both heads and cabs will sound cool, but it won't be "stereo", unless you use them with a stereo effect, like chorus or something like that.
Old 10-29-2011, 10:00 AM   #6
Adwex
Super Moderator
Adwex's Avatar
And what TPR also said about tube amps is true, different impedances will not change the output. They have an impedance selector switch that must be set to match the total impedance of the cabs, or you could damage the amp.
Old 11-01-2011, 09:29 PM   #7
Johnny Blade
Quote:
no the speakers that came with mine have no impedance switch, they are basically MG series quality rated at 8 ohms each. I was just saying, for maximum results, this head screams when I use my 1960s, and your right, those do have a selector, but the VS-8100 has no switch for ohms. It has 2 outputs, and says "100 watts RMS at 4 ohms", and seeing as how both the cabs are mono, unswitchable 8 ohm cabs that the head came with, you need both 8 ohm cabs to make it into 4 ohms.
Old 11-02-2011, 08:06 AM   #8
TwinACStacks
Senior Member
TwinACStacks's Avatar
One less Cord?
TWIN
__________________
Quote:
Originally Posted by triftstrassa View Post
Are you retarted?
Quote: longfxukxnhair
I knew they were wrong. I can find my ass with both hands
Jm D1 Trusted by more musicians than Fed Ex
Want to make GOD laugh? Tell him about your plans.
TwinACStacks is offline   Reply With Quote
Old 09-10-2013, 02:43 PM   #9
Rushfan74
Junior Member
New to everything guitar related cause I drum.
Ok first of all I have no idea what I'm doing with a guitar anyways but felt as a drummer that I need to learn it to understand how the two mesh so to speak. I won a custom Les Paul with open coil albino pick ups and a MG100HDFX. My question is will the Marshall Mg play by just plugging it in or will I need another amp to plug that I to for it to work?
Rushfan74 is offline   Reply With Quote
Old 09-10-2013, 03:16 PM   #10
damienbeale
Senior Member
damienbeale's Avatar
Did you get a speaker cabinet with it? Or just the MF100HDFX head?
damienbeale is offline   Reply With Quote
Old 09-10-2013, 03:50 PM   #11
kamran
Senior Member
kamran's Avatar
You need a cab, just the head unit has no speaker. Unless you just wanted to jam through headphones, in which case you're good to go. But why revive a two year old thread just to ask this question?
__________________
____________________________________________
JVM210H
1959SLP Dookie mod
1985 Mosfet Lead 100
Marshall 1960A
Marshall 1960BX
Avatar G412B Vintage with Vintage 30's
Les Pauls n Strats
Victim of Society
http://www.facebook.com/pages/Victim...91497534209866
Quote:
Originally Posted by FFXIhealer View Post
That's why I didn't want to ask what tubes to get here. Everyone's biased.
kamran is offline   Reply With Quote
Old 09-10-2013, 04:20 PM   #12
Rushfan74
Junior Member
Dameinbeale, I only got the MFDX100. Thanks for the input. Kamran, threads don't die. Thanks for input guys.
Old 09-10-2013, 04:26 PM   #13
damienbeale
Senior Member
Yup, you'll need a cab. Headphones are not particularly satisfying when it comes to guitar.
Old 09-10-2013, 04:38 PM   #14
Rushfan74
Junior Member
Thanks again gentlemen.
Old 09-10-2013, 04:47 PM   #15
damienbeale
Senior Member
Oh, and a proper speaker lead too. DON'T use a guitar lead to connect between head and speaker cab, as it will not be able to handle the current, and add a lot of capacitance, which is not really what you want.
Old 09-10-2013, 06:23 PM   #16
Rushfan74
Junior Member
What do you recommend for a lead?
Old 09-11-2013, 01:57 AM   #17
damienbeale
Senior Member
Any half decent speaker cable will do (plenty available in music stores). No point wasting big bucks here.
Old 09-11-2013, 09:24 AM   #18
charveldan
Banned
Location: Somewhere with a Friedman Marshall & Les Paul.
Real men play with their Tewbs ...
charveldan is offline   Reply With Quote
Old 09-11-2013, 01:13 PM   #19
damienbeale
Senior Member
Well that was helpful, Dan...
Old 09-12-2013, 12:29 PM   #20
chuckharmonjr
Senior Member
chuckharmonjr's Avatar
Location: About as far south in Alabama as you can go without swimming
helpful AND amusing
__________________
JCM2000 DSL100
JMD-1 100 Watter
JMP800 2204
Hughes and Kettner 18w
JTM 50
1960A
1960B
2061BX Clone
(2)Seismic Audio 2-12
Avatar V30 1x12
Joe B Sig Goldtop
Tobacco Burst Les Paul
Black Les Paul Custom
Honey Burst Les Paul
R8 Les Paul in Tea Burst
ES-175 in Cherry
EDS-1275 in White
Fender Strat in Tobacco Burst
http://soundcloud.com/chuck-harmon-1/woman
http://soundcloud.com/chuck-harmon-1/webs-and-dust
chuckharmonjr is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
