MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 08-21-2009, 04:32 AM   #1
American Viking
Senior Member
American Viking's Avatar
Cliff Jack terminals? + - ???
On a mono type Cliff 4 prong jack is there any designation between positive and neutral? I've rewired an old cab and there are cliff jacks on a PCB that I can reuse but I can't tell which one is + or - or does it even matter? I've always used regular input jacks before so this is my first time repairing with a Cliff type jack.
American Viking is offline   Reply With Quote
Old 08-21-2009, 02:19 PM   #2
MajorNut1967
Senior Member
MajorNut1967's Avatar
Re: Cliff Jack terminals? + - ???
Quote:
A Cliff mono jack is switched but that really doesnt matter for speaker jacks. Also so do you have Genuince Cliff S4? Or like a Neutrik copy? look at the pic see it that helps? In the case of wiring speaker cabs you can run the wire through both the constant post & the switched post.
I know To much Bandwidth but I want you to see!
Old 08-21-2009, 04:39 PM   #3
American Viking
Senior Member
Large pictures are great, thanks.
I'm not sure that it's a genuine Cliff jack but it's of similar type. It came off of a Crate cabinet and I don't feel like waiting around to order a new jack so I figured I would just take this one off the PCB and trash the board.
What exactly does the "switched" part mean? Is that if you had different wiring configurations going to each side and a separate toggle switch to control it?
Old 08-21-2009, 05:33 PM   #4
MajorNut1967
Senior Member
On a S4 when there is nothing plugged into the jack, the "switched terminal" and the "constant terminal" are shorted. This is true for the TIP (+) & Sleeve (-) in other words pin1 & pin 4 are shorted and pin2 & pin3 are shorted when nothing is plugged in the jack.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
