MarshallForum.com
Go Back   MarshallForum.com > Music Gear > Guitars
Reply
Thread Tools Display Modes
Old 02-11-2014, 03:06 PM   #1
SonVolt
V.I.P. Member
SonVolt's Avatar
Setting Intonation on a Fender Stratocaster
So I'm following Fender's official instructions on setting intonation on a 25.5" scale-length strat. What does "center of bridge saddle" mean exactly? I thought it meant the very center of the saddle where the string would feed through. Is that not the center? Because measuring from the inside of the nut 25.5" leaves me hovering right behind one of the bridge-plate screws, there's no way the bridge saddle can move forward enough for the center of it to reach exactly 25.5" from the inside-edge of the nut.
Quote:
INTONATION (ROUGHING IT OUT)
You can preset the basic intonation of your guitar by taking a tape measure and measuring from the inside of the nut to the center of the 12th fret (the fret wire itself; not the fingerboard). Double that measurement to find the scale length of your guitar. Adjust the first-string bridge saddle to this scale length, measuring from the inside of the nut to the center of the bridge saddle. Now adjust the distance of the second-string saddle back from the first saddle, using the gauge of the second string as a measurement. For example, If the second string is .011" (0.3 mm), you would move the second-string saddle back .011" (0.3 mm) from the first saddle. Move the third saddle back from the second saddle using the gauge of the third string as a measurement. The fourth-string saddle should be set parallel with the second-string saddle. Proceed with the fifth and sixth saddles with the same method used for strings two and three.
__________________
In memory of Grunch. Who hated this forum, and everyone in it.
SonVolt is online now   Reply With Quote
Old 02-11-2014, 03:10 PM   #2
scat7s
V.I.P. Member
scat7s's Avatar
Re: Setting Intonation on a Fender Stratocaster
the center of the saddles travel...within its adjustment range.
thats how i would interpret it anyway.
edit: at 25.5, it looks like you need to slide your saddle forward, so that where the string actually makes contact with the saddle is 25.5. it appears you have room to get there in the pic. right now your at 25 and 5/8. see what i mean?
ps, your definitely measuring from the neck side of the nut, correct? not the headstock side?
__________________
We're listening, and we're watching.
scat7s is offline   Reply With Quote
Old 02-11-2014, 03:15 PM   #3
SonVolt
V.I.P. Member
SonVolt's Avatar
What does that mean exactly?
__________________
Old 02-11-2014, 03:19 PM   #4
66 galaxie
V.I.P. Member
66 galaxie's Avatar
I think they mean the hump of the saddle that the string rests on.
Edit, scat edited while I posted, lol.
66 galaxie is offline   Reply With Quote
Old 02-11-2014, 03:20 PM   #5
poeman33
Super Moderator
poeman33's Avatar
To be honest I have never once used a ruler to preset the saddles. Yours look close enough to get out your tuner and start fine tuning. There is a basic three-three pattern (which I have no idea how to describe in typing) that I start with...but it all just comes down to making fine adjusments later...even if that first fine adjustment is a BIG one.
Just make sure you get the action th way you want it first.
__________________
CSA (Certified Strat Addict)
Quote:
Originally Posted by EL 34 View Post
poeman33 is a midget busker champion of ****-town ontario so he knows everything.
https://soundcloud.com/poe-man-1/king-bee-no-eq
poeman33 is offline   Reply With Quote
Old 02-11-2014, 03:20 PM   #6
scat7s
V.I.P. Member
scat7s's Avatar
sorry i keep editing, read it again.
__________________
Old 02-11-2014, 03:23 PM   #7
66 galaxie
V.I.P. Member
66 galaxie's Avatar
Oh, and like Poeman said, that is kind of a ballpark. Use your tuner to get it right.
Old 02-11-2014, 03:26 PM   #8
SonVolt
V.I.P. Member
SonVolt's Avatar
Ok, so "center of saddle" should have read "center of saddle where string rests". Yes, I'm measuring from inside the nut.
__________________
Old 02-11-2014, 03:30 PM   #9
scat7s
V.I.P. Member
scat7s's Avatar
once you get it all strung up and at proper tension, that dimension may shrink on you slightly as the neck gets pulled "in" AND your bridge potentially lifts, though i dont know how much. keep that in mind.
__________________
Old 02-11-2014, 03:32 PM   #10
DirtySteve
V.I.P. Member
DirtySteve's Avatar
I always thought that where the string rests is the saddle...not the whole part.
__________________
I wish I could give you a '****' for that...
Quote:
Originally Posted by Swede View Post
Lot of very NOT rock n roll folks here....
DirtySteve is offline   Reply With Quote
Old 02-11-2014, 03:57 PM   #11
johnfv
Senior Member
johnfv's Avatar
Where the string rests. I usually just eyeball it and then adjust with my Korg tuner in "strobe" mode, you can get pretty close with a little practice.
__________________
My Amps: Marshall: '68 1959T, JVM410HJS, Class 5; Fender '65 Showman, '80s Hiwatt 50, '90s Dual Rec, Ceriatone: 18W TMB, 2204HW, DZ30, Liverpool, Express, Prinzetone; GR amps 18W; Jet City: JCA20H/HV, PicoValve; Egnater Tweaker15, BadCat Cougar15, Fractal AxeFX II. Various cabs: 4x12, 2x12, 1x12
Strats: '62 RI, '87 Strat plus, '10 EJ maple; too many partscasters; Gibson: '08 Firebird V, '11 SG, '66 Melody Maker, '81 ES-347, '04 ES-335, '05 LP Std DC; and more...
johnfv is online now   Reply With Quote
Old 02-11-2014, 04:07 PM   #12
SonVolt
V.I.P. Member
SonVolt's Avatar
Thanks everyone. I guess either I'm dumb or it was a poor choice of words on Fenders part, probably both.
All is good... i can't believe how amazing this Fender Blacktop Strat sounds. So beefy...
__________________
Old 02-11-2014, 04:09 PM   #13
scat7s
V.I.P. Member
scat7s's Avatar
the wording confused me too.
as soon as you posted the pic, it all made more sense.
__________________
Old 02-11-2014, 04:58 PM   #14
BlackSG91
Banned
Here's a video that might help a member with the most succulent and most flavourful avatar ever on this fine forum.
BlackSG91 is offline   Reply With Quote
Old 02-11-2014, 06:06 PM   #15
1neeto
Senior Member
1neeto's Avatar
Don't bother measuring. Just use a good tuner and make sure the open, harmonic and fretted 12 are on pitch.
__________________
www.soundcloud.com/1neeto
"Personally, I find martial arts and music are connected in that they are not a means to an end, rather are a means unto themselves."
zachman
1neeto is offline   Reply With Quote
Old 02-11-2014, 06:16 PM   #16
peterichardz
Senior Member
peterichardz's Avatar
Quote:
Originally Posted by 66 galaxie View Post
i think they mean the hump of the saddle that the string rests on.
Edit, scat edited while i posted, lol.
this!
__________________
The Sneaky Pete Band
www.sneakypeteband.info
Loud and Proud for 40 + years
2 '77 JMP 50 watt MV's
1 JCM 2000 DSL 50 Head
1 1960AX W G12M's
1 1960A W/ EVM12L's
1 Laney Straight cab W/ G12M-70's
1 1965A Modded & Loaded with 2 EVM12L's
1 112AVT Loaded with EVM12L
Seymore Duncan Convertible 100 watt
2 Gibson Les Paul Jr.s STOLEN
Gibson Les Paul Special
Gibson Firebird
Epi. Custom Shop Les Paul Jr.
Epi. Les Paul Classic Quilt Top
Epi. Korina Explorer
Epi. Les Paul Chamilien
peterichardz is offline   Reply With Quote
Old 02-11-2014, 06:26 PM   #17
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
I agree with the guys that say use your tuner. If you get your open, fretted (12th) and 5th and 12th fret harmonics nailed then you can't do any better.
One thing I have always owned is a top notched tuner.
__________________
Old 02-11-2014, 06:40 PM   #18
BlackSG91
Banned
Quote:
Originally Posted by peterichardz View Post
this!
that!
Old 02-11-2014, 09:48 PM   #19
1neeto
Senior Member
1neeto's Avatar
5th fret harmonics only if you have a 24 fret guitar IIRC. I might be very wrong though.
__________________
zachman
Old 02-11-2014, 10:35 PM   #20
dr-schecter
Junior Member
dr-schecter's Avatar
Measuring from the nut to 12th fret and repeating that measurement from the 12th to the center of the allen screws has always gotten the first string nearly dead on for me. One way to do it. Tweak the others from there of course. A 24' Machinist rule comes in handy.
dr-schecter is offline   Reply With Quote
Old 02-11-2014, 11:02 PM   #21
mickeydg5
V.I.P. Member
mickeydg5's Avatar
I think a tuner is best for setting intonation.
I like to ride the notes up the fretboard while watching the tuner and find a happy median for saddle setting with all notes within a few cents of center.
__________________
Tweak until pleased.
WARNING!
I have not a clue and no one should take advice from me especially regarding repairs and/or modifications.
mickeydg5 is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
