MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 12-23-2013, 02:57 AM   #1
Gene Ballzz
Senior Member
Glue For Tolex? & Other Questions
Hey All,
I know this has been asked and answered, but search was not my friend today. I realize that I can get "genuine" Tolex glue form suppliers and wait for it after paying a semi premium $$ for it claiming to be "Tolex" glue, but I kinda have to believe that other products readily available at Blowes or Home Cheapo are similar enough to be suitable? What works best and is easiest to work with? Spray, roll/brush-on, contact style? Also, any tips on how to do a cab with front to rear seam piping? I understand the concept, I'm simply looking for practical advice and procedural sequence. In this case I'm doing a head cab but have a few speakers to tackle also. Am I correct in the assumption that the Tolex does not need to be cut/seamed at each piping and that the only actual seam required is where the 2 ends of the Tolex meet?
Thanx For All Replies,
Gene
__________________
rocknblues.org
Tweed Deluxe
"THE BALLZZ" 10 Watt
DSL5/Mildly Modded
JVM1H
Class5 Head
JTM30 1X12 Combo
Laney AOR Pro Tube Lead 100
Trinity Tramp 6/12 Watt
MG100HDFX
2-OLD Straight Greenback 4x12 Cabinets
1965B 4X10
Peavey 412MS 4x12
MG412A RatBox
80-LP Firebrand
82-LP Firebrand
88-Studio Dot Neck/Black
97-Studio P-94/White/Ebony Fretboard
06-Classic 60's Player Stratocaster
79-ish Epiphone Genesis/Red
Yamaha Thin Body Acoustic
Jackson "Dinky" Junker
Squier "TORCHY" Strat
Gene Ballzz is online now   Reply With Quote
Old 12-23-2013, 03:13 AM   #2
blues_n_cues
V.I.P. Member
blues_n_cues's Avatar
Re: Glue For Tolex? & Other Questions
either of these should work-
3M General Purpose Spray Adhesive, 10.25 oz: Office : Walmart.com
**3M
__________________
LIFE,LIBERTY,& the pursuit of TONE.
2007 Epi LP Custom LTD.
1991 Jackson DK-2 HSS
2010 Austin LP GT w/ P90s
custom rebuilt Washburn BT-2 Maverick
Marshall JMP-1 (rack)
Marshall CODE 100 (eventually) lol
a bunch of other carp
my music,sounds,samples,& snippets-
http://www.reverbnation.com/rlcltd
https://soundcloud.com/rlc-ltd
Stratisfied
https://soundcloud.com/rlc-ltd/stratisfied
just riffing
https://soundcloud.com/rlc-ltd/just-riffage
blues_n_cues is offline   Reply With Quote
Old 12-23-2013, 03:38 AM   #3
Gene Ballzz
Senior Member
blues-n-cues,
Yep, that's kinda what I figured. Still looking' for tips on technique, procedure, etc. on the piping seams?
Gene
__________________
rocknblues.org
Tweed Deluxe
DSL5/Mildly Modded
JVM1H
Class5 Head
JTM30 1X12 Combo
MG100HDFX
1965B 4X10
Peavey 412MS 4x12
MG412A RatBox
80-LP Firebrand
82-LP Firebrand
Old 12-23-2013, 05:44 AM   #4
Georgiatec
V.I.P. Member
Georgiatec's Avatar
I've never done one but, on a head box with with the piping on top, I would be tempted to start at the right hand piping groove go all the way around the bottom of the box and up the other side finishing at the left hand groove. Cut with slight overlap at each groove. Then cut a piece to do the top between the piping again with slight overlap. Once it's all stuck down and secure, run some glue into the groove, tap the piping into place and you should have a finish with no visible joins / overlaps.
__________________
JCM2000 DSL100
VINTAGE MODERN 2466 WITH 425 A & B CABS
2061x
SL-5, CLASS 5 Mk 1.
JMP1c & JCM1H.....BADCAT UNLEASH
JMD50
1960B, MX212, 1922 & VS112 CABS
1983 FENDER TWIN REVERB II
1978 PEAVEY CLASSIC 212 COMBO
GIBSON LES PAULS....R7, R8, R9, R0, '04 CLASSIC & '12 TRAD. PREMIUM
'00 FENDER USA STANDARD TELECASTER
FENDER MODERN PLAYER TELE+
'94 FENDER MIJ '62 RI FOTOFLAME STRAT.
'99 FENDER USA STANDARD STRATOCASTER
Georgiatec is offline   Reply With Quote
Old 12-23-2013, 06:33 AM   #5
blues_n_cues
V.I.P. Member
Quote:
Originally Posted by Gene Ballzz View Post
blues-n-cues,
Gene
ya got me.not one of my talents,I just play 'em.
__________________
Stratisfied
just riffing
Old 12-23-2013, 07:02 AM   #6
Hillcountry
Senior Member
Hillcountry's Avatar
Piping can be a pain - the trick is to make sure the tolex covers the channel that the piping goes in. So I would often rout a 1/8 inch channel for the piping and then make sure the piece of tolex covers to the far edge of the gap for both pieces. When you push or tap the piping into place the pressure should hold it in place. I wait until the glue dries to do this - sometimes a bulge can occur next to the piping of you do not.
I tried spray adhesives and rubber cement. I have found that you need to wait and really let those glues dry before you attach them to each other - sometimes they end up gummy and not really sticky. This depends on your location and relative humidity.
I, most often, use hot hide glue. It is a pain to mix, but is the most reliable for me in the long run.
-Hillcountry
__________________
Amps:
Matchless Clone with KT66
Matchless Clone with 6V6
36 watt TMB clone EL34
Guitars:
Custom 59 LP Copy
1984 Les Paul Studio
Custom Tele Jr. Single P90
Current board:
Germanuim Fuzz Clone
Germanium Rangemaster Clone
Hillcountry is offline   Reply With Quote
Old 12-23-2013, 08:16 AM   #7
george76
Senior Member
george76's Avatar
any contact adhesive will work. but dont go for the highest strength you can find, because there are areas where you need to glue down the tolex and then pull it back off to cut the seam. if you use a high strength glue it will pull all your wood filler off with it and possibly bits of wood too.
also it needs to go on very smoothly & thinly so you dont get any lumps.
the stuff advertised as tolex glue is good but way too expensive. find a cheaper alternative, look for low viscosity (runny) neoprene based adhesive and it should do the trick. use a roller and a couple of disposable paint brushes for the awkward areas.
make sure it has gone completely touch dry before bringing the surfaces together.
i found this stuff, which i havent tried yet, but think should work fine:
http://www.screwfix.com/p/no-nonsens...ive-1ltr/34758
its only 7.59 per litre.
i would not recommend spray adhesive.
george76 is offline   Reply With Quote
Old 12-23-2013, 01:54 PM   #8
jut
I usually use contact cement. It's been the most reliable for me. Hot hide glue is also awesome, but a little more involved as far as mixing and heating- I would use this all the time if I had a good setup for it.
I've also used pressure sensitive glue which worked fairly well, but was a little more messy. That stuff is nice though becuase you can reposition it fairly easy. Then you can just roll it really heavily and it will hold very strongly.
jut is offline   Reply With Quote
Old 12-26-2013, 04:30 AM   #9
HOT TUBES 70
Senior Member
HOT TUBES 70's Avatar
This ****s unreal !!!
The best imo ....
Aerosol Adhesive :3M US
__________________
Building great sounding pedals one at a time the old fashion way
Contact me direct : Onflooraudio@hotmail.com
OFA Tube Boost Plus Overdrive Demo's
http://www.youtube.com/watch?v=p4hTV5ieJAk
https://www.youtube.com/watch?v=wVuX_PJ3YBk
HOT TUBES 70 is offline   Reply With Quote
Old 03-04-2014, 11:14 AM   #10
jgab
Senior Member
jgab's Avatar
I know this is an old thread but I thought I would post my findings as nothing is more frustrating about tolexing than using a glue that doesn't work worth a crap. I have tried most everything only to settle on one type of contact cement. I tried the 3M stuff. 3M 90 works good but super expensive, plus I wouldn't use a spray adhesive. Although it sound great, you always get patchy overloaded areas that tend to bubble; especially when using the heavy duty stuff like 3M 90 or Lepage blue can spray. They have a thicker spray which is good for avoiding over spray, but bad for even spray patterns.
Use LePage blue can "brush on" contact cement. It is solvent based but the fumes are not that bad, especially when using it in open areas. It also doesn't harm the tolex. It is also available almost everywhere. It also has a nice setup time at 15 mins. It is also super strong and your tolex will not lift or loosen over time. It is the strongest stuff I have used to date and I have used a lot of different stuff.
http://dashboard.lepageproducts.com/...-Cement%20.jpg
jgab is offline   Reply With Quote
Old 03-04-2014, 12:59 PM   #11
george76
Senior Member
george76's Avatar
as mentioned in my previous post, you dont want mega high strength glue for tolexing. you will get into trouble when you have to re-lift the tolex for the corner seams, especially if you have used wood filler on those areas. because it will just come off when you lift the tolex up with that high strength glue on it, and may bring some wood off too.
the expensive white glue sold by most places as "tolex glue" is actually not very strong at all, but works fine. you are only sticking tolex to wood, not sticking combine harvesters together.
use the best glue for the job, not the strongest you can find.
Old 03-05-2014, 12:24 AM   #12
dash8311
Senior Member
dash8311's Avatar
lol, well said.
dash8311 is offline   Reply With Quote
Old 03-05-2014, 09:32 AM   #13
jgab
Senior Member
jgab's Avatar
Really? I have been using this stuff for a long time and never had problems with lifting back tolex for the seams. Maybe you are waiting too long before doing the seams. No need to wait for the adhesive to fully cure before doing seams.
George76, strong glue is important because the strong stuff will still be holding after 40+ years whereas the water based crap they sell now a days will probably be lifting and bubbling. Water based stuff, that never seems to fully dry, is good for working on your kids Halloween costumes; not for tolexing a road worthy amplifier capable of outliving the guy who built it. Experience is pretty important when tolexing too. If you have to reposition tolex after you applied it to the amplifier then you need a lot more practice before you should attempt an amp with the real stuff...
Edit: Oh and just to throw this out there, Marshall and Fender either used solvent based high strength glue or animal glue.
Old 03-05-2014, 09:53 AM   #14
Ken
Senior Member
Ken's Avatar
I used the same spray adhesive I used to re-carpet my Lotus to re-glue long tattered pieces on my B cabinet. It's like liquid chewing gum when it comes out of the can and gives you a few minutes to arrange your piece before it dries too much.
It's great for delicate work where you need to be sure everything is straight before it dries. I'm quite sure it won't remove the wood grain if it gets peeled off, and it's resistant to high heat and bitter cold. It may be the same 3-M product Blues-n-cues mentioned; read the can and see if it's for automotive carpeting.
Ken
__________________
1999 Marshall DSL 50
Late 1970's (?) Fender Champ
Marshall battery amp
PRO 4x12 from the 1970's
Woodson 2x12
1976 Les Paul Standard
Epiphone Les Paul knockoff
ESP Lawsuit Explorer
1979 Chiquita Travel Guitar
1995 Taylor 310
Ken is offline   Reply With Quote
Old 02-12-2015, 09:30 PM   #15
2x4x12
Junior Member
How about plain 'ol Elmer's glue-all?
I have a cab w/ lots of peeled sections (along the back edges of the sides) and several small rips w/tolex still intact.
I don't wanna spend a fortune on glue since I only need a couple of tablespoons worth...
Has anybody tried this?
2x4x12 is offline   Reply With Quote
Old 02-12-2015, 09:57 PM   #16
Micky
V.I.P. Member
Micky's Avatar
Elmer's glue is water based, and may not work well for the long term...
But in a pinch I would use it for small rips or tears. It dries clear.
__________________
Stupidity should be painful...
Marshall MHZ15, DSL40c, DSL5c, M4, 4X12 full stack, Gibson LP, VOX, Eminence, Celestion, Ovation, Fender & more...
Micky is online now   Reply With Quote
Old 02-13-2015, 08:32 AM   #17
jgab
Senior Member
jgab's Avatar
For small rips and tears I find super glue works the best for the long term touch-ups. It dries in seconds so you have to be super fast.
Just ask this guy: http://www.chm.bris.ac.uk/motm/super...ue-shaming.gif
Old 02-13-2015, 08:39 AM   #18
blues_n_cues
V.I.P. Member
Bwahaha
__________________
Stratisfied
just riffing
Old 02-13-2015, 01:12 PM   #19
sgstratdude
Senior Member
sgstratdude's Avatar
contact cement > 3m spray on
I used 3m spray on for the first 2 cabinets i retolexed and I didn't enjoy that at all. The tolex wouldn't stay flat and the edges always seem to bubble up. It seemed I had to check on the cabinet every 10 minutes for 3 hours or so to reflatten the tolex until dried. The dry time is awful. Once dried though it held just fine.
Contact cement is awesome. Line it up and put it on right and your done. Lots of time saved.
edit
holy necro thread....
__________________
Les Pauls and Strats
JVM 210h
Avatar Vintage 2x12 - Creamback 75s
sgstratdude is offline   Reply With Quote
Old 02-19-2015, 06:40 AM   #20
maui
Junior Member
I used this low order contact cement by lapage the green stuff worked out really well
maui is offline   Reply With Quote
Old 02-19-2015, 12:21 PM   #21
pedecamp
Senior Member
pedecamp's Avatar
Gene be careful you dont glue your Ballzz to the head cab!
__________________
JCM800 2204
pedecamp is online now   Reply With Quote
Old 02-19-2015, 07:54 PM   #22
SG~GUY
Senior Member
SG~GUY's Avatar
the best contact cement you can buy,...
...prefit everything before hand,..then prefit it again!!!
having it come out looking good is like painting a car,..it's all in the prep work,..i posted how I did the 8x12 cab in my profile awhile ago...if you wanna know how I did it search the archives,..if you want more pics let me know
SG~GUY is offline   Reply With Quote
Old 02-21-2015, 08:19 PM   #23
jgab
Senior Member
jgab's Avatar
Quote:
If you prefit, and use solvent based contact cement. You will have minimal to no problems. I don't see an advantage to using water based over solvent based cement if you have good ventilation.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
