MarshallForum.com
Go Back   MarshallForum.com > The Amps > Other Amps
Reply
Thread Tools Display Modes
Old 09-30-2013, 08:21 AM   #1
Vinsanitizer
V.I.P. Member
Vinsanitizer's Avatar
Yamaha THR10 portable/desktop amp
- I just bought one the other day.
- Here's a link to Sweetwater, with vids and info.
- Price $299 US
- Here's my review:
I bought this solely as a late night desktop amp for practicing solos and to mp3's from my iPhone. Also back porch use and carrying around in the car with a cheap Strat.
Upon unboxing it I found it very compact and lightweight. Metal housing, plastic knobs and a metal handle. My very first thought was, "this things is gonna buzz and rattle and clank all day". However, that turned out not to be the case.
10 solid state watts. It comes with an AC power supply, 12" cable with 1/8" stereo tips for plugging an mp3 player to jam along to. For that feature the amp has two master Output controls which allow you to blend the mp3 and guitar volumes separately. Also comes with a USB cable and a copy of Cubase for deep editing via PC. The amp has a built-in tuner, 5 user-preset locations, and also takes 8 AA alkaline batteries for portable use.* A stereo headphone out, and some orange interior LEDs for a faux tube glow. Rubber feet, won't scratch surfaces.
I set it out on my outdoor deck, popped in a new pack of batteries and plugged in my Les Paul. I played through each of the amp sims; Clean, Crunch, Lead, Brit Hi and Modern. They all sounded great and were very easy to get good tones with. One thing I noticed is that, like a real tube amp, the controls do seem somewhat interactive, which is a nice touch. The Gain and Master work together as preamp and poweramp gain controls, and then you set the amp Output control for actual loudness. It's very cool to be able to jam at night to mp3's with great tone, at a volume only slightly louder than the sound of the strings being plucked. On the other end of the spectrum, it can get very loud!
It's modeling, which is going to be bright, but yet it's very warm, much richer and dynamic than other modeling amps I've used (Boss, Digitech, Line 6). It does a good job of getting clean and high gain, plus all the stuff in between. Good for Jazz, Blues, Hard Rock and some Metal. It's interesting how loud and how large this amp sounds for a table top amp, with lots of punch and width from the stereo speakers. It's like the Bose of guitar amps. Each preset can also be set to "Extended" mode, which seems to widen the stereo spectrum for effects.
THR10 version also has three additional sims for Bass, Acoustic and Flat. Flat can be used for any external input type, such as mp3 (using mp3 player in this mode will give you the added use of the tone controls). I plugged my Gibson Hummingbird into the Acoustic channel and was really blown away at how large, full and pretty it sounded with a touch of reverb. Sparkling beauty! I haven't tried a bass guitar yet.
The effects are pretty good, a little better than what I expected. Dual control layout: one for chorus, flange, tremolo, etc, and another for delay & reverbs. They work similar to the way Line 6 uses FX.
The amp is very loud, full and bright. It's by far the best sounding portable I've played to date. My Mustang Mini battery amp is a literally a POS compared to this thing, as my Mustang Mini buzzed and farted anywhere above 3 on the master- simply unusable.
*There is a known and widely reported design issue when running batteries: even with a brand new set of alkalines, if you run the volumes up past 12:00/1:00 the amp will suddenly shut off as soon as the batteries have been under enough strain to drop their voltage to a certain point (some speculate 9.6 or something). So be warned that if you want to crank it at camp or in the park, or the subway all day at near max volume, it's not going to work for you. Yamaha has acknowledges this problem and has not issued a fix. For me this is not a deal breaker, as I wouldn't be cranking this that loud in a park and I don't use a subway, but YMMV. Battery life under normal conditions is reported to be roughly 8 hrs. That's plenty of time to get through a gig or two, should you decide to mic it or run it direct into a mixing board.
Good price, great quality, great sound, no speaker distortion or farting out at near max volumes. Great for electric, acoustic and even bass, jazz, Blues, Rock, Metal. Great sounding effects, mp3 in, headphone out, Output mix for balancing guitar and mp3 separately, lightweight, portable, user presets, built-in tuner. Very nice for the price!
4/5 (-1 for sudden battery shutdown at high volumes)
Vinsanitizer is offline   Reply With Quote
Old 09-30-2013, 08:51 AM   #2
pedecamp
Senior Member
pedecamp's Avatar
Re: Yamaha THR10 portable/desktop amp
Thats a great review exactly what I was expecting to hear. I've played around with a couple of the models and agree with everything you say. They have a few different models, what made you choose this one over the others? One thing I was wondering, are the amp sims footswitchable, can you switch between clean and crunch for example? Never mind, I just read on the spec theres no footswitch I/O. I guess you could use pedals on it for that.
__________________
JCM800 2204
pedecamp is offline   Reply With Quote
Old 09-30-2013, 09:44 AM   #3
Vinsanitizer
V.I.P. Member
Quote:
It works well with the guitar's volume control, but of course that's not the same as switching presets.
I am wondering if it's possible to connect any kind of USB foot controller to switch channels. I'm thinking it might be feasible with a laptop and a foot controller, but that's a lot of outboard gear to be able to switch between presets, it would seem.
Old 09-30-2013, 10:24 AM   #4
Rocktane
Senior Member
Rocktane's Avatar
Do a search... there are mods for these amps. Line/speaker outs, footwitches, etc. Personally , I don't see the need to mod my 10X, it's does what it does perfectly!
Rocktane is offline   Reply With Quote
Old 09-30-2013, 01:08 PM   #5
HeHasTheJazzHands
Senior Member
HeHasTheJazzHands's Avatar
A THR with a footswitch and a speaker out sounds awesome.
__________________
Djong
HeHasTheJazzHands is offline   Reply With Quote
Old 09-30-2013, 01:55 PM   #6
scat7s
V.I.P. Member
scat7s's Avatar
interesting. i was offered a THR5 in partial trade for an amp i sold. i passed on it, but was a little tempted.
__________________
We're listening, and we're watching.
scat7s is offline   Reply With Quote
Old 09-30-2013, 03:36 PM   #7
wakjob
Senior Member
wakjob's Avatar
Told ya!
Of all the BS gear I have/had laying around, I play that stupid little space heater the most.
I can't wait for Yamaha to up the game with some 1x12 combos and such.
Because I will admit to one thing, the 2" speakers wear on my after awhile.
wakjob is online now   Reply With Quote
Old 09-30-2013, 08:48 PM   #8
HeHasTheJazzHands
Senior Member
Would love to see a THR line. Would be like the old DG line.
__________________
Djong
Old 01-17-2015, 04:25 PM   #9
GibsonKramer
Senior Member
GibsonKramer's Avatar
Surprised these don't get more love around here.
I've owned all 3 of the 10 line, settling on the X... But all are superb amps. The only reason, I was lucky enough to score my little Marshall was because the THR made everything else, obsolete. It's the most well-rounded, versatile amp, I've owned.
And straight out of the box, just leveling everything out, cranking up gain... it was the best sounding.
Granted, now I've had some time with the Marshall and dialed in the tone, I want... for speaker use, I'll go to it. But for something to grab, move around, plug into your computer, tweak the characteristics/presets... I think Yamaha is sitting atop that mountain.
GibsonKramer is offline   Reply With Quote
Old 01-18-2015, 02:41 PM   #10
Jethro Rocker
Senior Member
Jethro Rocker's Avatar
Agreed, great review! I have a 10X and it is superb. Want to run a speaker out, might try to rig it to the existing headphone out jack. Just for ****s and giggles, really. Great little practice amp, doubles as a wired speaker for mp3 or phone, portable!
__________________
TSL 122 '87 Silver Jube 2558 DSL 40C 6101 30th anniversay
6912 cabinet Mesa Mini recto 25 Yamaha THR10x
Ibanez Prestige, Artist Epi Prophecy (Explorer) ESP LTD MH-400
Ibanez artist Yamaha RGX612 Epi doubleneck Etc
Jethro Rocker is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
