MarshallForum.com
Reply
Thread Tools Display Modes
Old 07-31-2013, 10:25 AM   #1
dexter74
Senior Member
Tung Sol 12AX7 vs JJ ECC83S preamp tubes
What are the main differences between these two brands? Now does each rate as far as having better headroom, smoothness, gain and longevity?
Want to replace my Egnater Tweaker 15 watt head preamp tubes, and I am "dazed and confused" over everything I have read. Play mostly classic rock but like the tone from players like Beck and EJ, too. Only play at home these days and not at very loud volumes. Opinions and suggestions wanted.
Cheers.
dexter74 is offline   Reply With Quote
Old 07-31-2013, 11:05 AM   #2
bvoris
Senior Member
bvoris's Avatar
Re: Tung Sol 12AX7 vs JJ ECC83S preamp tubes
Cheers.
Hope that helps.
I use the JJs and have been pretty satisfied. I have one spare Tung-Sol 12AX7 that I have used off and on in my VS65R and that amp didn't like it much. In Tung-Sols defense, that amp is picky as **** when it comes to tubes.
__________________
http://www.youtube.com/user/BVoris6977/videos
http://soundcloud.com/brad-voris
Quote:
Originally Posted by Quasar-Kid View Post
Houston Jedi mind trick mother ****ers...
(and that's all I have to say about that)
bvoris is offline   Reply With Quote
Old 07-31-2013, 12:02 PM   #3
chee16
Senior Member
Why not get one of each and try them both out? Not trying trying to be a smart ass. But I really disliked the Tungsol, bright and punchy, not defined, but that could be my ears. 1 JJ in either v1 or v2 wasn't bad, but 2 get muddy. compromise for me was the jj in v1 and the tungsol in v2, if I had to use those 2. If not then I would not use the Tungsol, but again that is me with my amp and my ears. So I say try them and don't rely on youtube vids
chee16 is offline   Reply With Quote
Old 07-31-2013, 06:34 PM   #4
johnfv
Senior Member
johnfv's Avatar
Funny, I really like the Tung Sol in V1. Nothing against the JJ but it's a little dull for me. I've mentioned recently that the Mullard RI is probably my favorite current production 12AX7 tube. I'm not saying it's like a vintage Mullard but it's a good tube.
__________________
My Amps: Marshall: '68 1959T, JVM410HJS, Class 5; Fender '65 Showman, '80s Hiwatt 50, '90s Dual Rec, Ceriatone: 18W TMB, 2204HW, DZ30, Liverpool, Express, Prinzetone; GR amps 18W; Jet City: JCA20H/HV, PicoValve; Egnater Tweaker15, BadCat Cougar15, Fractal AxeFX II. Various cabs: 4x12, 2x12, 1x12
Strats: '62 RI, '87 Strat plus, '10 EJ maple; too many partscasters; Gibson: '08 Firebird V, '11 SG, '66 Melody Maker, '81 ES-347, '04 ES-335, '05 LP Std DC; and more...
johnfv is online now   Reply With Quote
Old 08-01-2013, 01:44 AM   #5
Rahlstin
Senior Member
Rahlstin's Avatar
I tried the tungs in a DSL100 and something was just different to me so I went back to a set of "special" "matched" "select" ...... what ever, just great sounding 7025's with cool paint.... I really think is depends on Player - guitar - amp - cab - speakers.... ask 8 players get 10 answers sort of thing
__________________
2014-Marshall DSL100H
2005-Marshall JCM2000 DSL100 head-modified
1990-Marshall JCM900 1960A-G12M65
2013-Marshall DSL40C - G12M65
2013 Fender Deluxe Reverb 65 Reissue
19??-Garnet 1x12 Cab-G12M25
2011-LesPaul Traditional-Black-Stock
1976-Gibson LesPaul Custom-natural-Stock
2001-Am Fender Strat-modified
1984-Washburn G4 - SD-JB
1994-LTD ED Ovation
2015 Ibanez Exotic Wood Acoustic
2010-Epiphone Sheraton II 57 & 57+
2013-Fender Road Worn Telecaster
Line6 G50 Wireless
Rahlstin is offline   Reply With Quote
Old 08-01-2013, 01:31 PM   #6
customjoe
in my experience the Tung Sol is a more detailed sounding tube. High gain and very articulate compared to the JJ which I agree was a little dull. I have heard a few guys who really like the reissue Mullards describe the TungSol as similar tone to the Mullard but the high gain of a chinese tube but without the boomy bass of the chinese tubes.
customjoe is offline   Reply With Quote
Old 08-02-2013, 01:59 AM   #7
MonstersOfTheMidway
Senior Member
Send a message via ICQ to MonstersOfTheMidway
I think that the gain is pretty much the same (at least to my ears), but the JJ ecc83s preamp tube seems to cut highs/treble off, yielding a not too bright tone. The JJ ecc83s is still a pretty aggressive preamp tube, and may help a guitar with bright/treble-ish pups, a cab with speakers that accentuate higher frequencies, etc.
I use the Tung Sol 12ax7 in the V1 position, and the JJ ecc83s in the V2 position. I like the mix of these two preamp tubes. I've experimented with JJ 3cc83s in V1 and V2, which produced a gain quality that was throaty with a bit of a boost in the mids.
@OP: you're rig will have a big influence on how you hear these two preamp tubes, so don't be surprised if you get some differing results when you mix things up. Good luck.
MonstersOfTheMidway is offline   Reply With Quote
Old 08-02-2013, 02:17 AM   #8
John 14:6
Senior Member
John 14:6's Avatar
JJ's are warmer sounding and a lot of amp builders at least stick them in the V1 first gain stage position, if not in all the preamp spots. Most high end Marshall amps ship with a JJ 12AX7 under the can. Tung Sols have more gain and they are very bright sounding. They can make an already bright amp like a Marshall sound shrill and thin in my experience with them. Some guys love them though. Let your ears be the judge. Preamp tubes are pretty cheap so buy a few and play around with them some.
__________________
Friedman Smallbox 50, Marshall DSL40CST, Fender Yngwie Malmsteen Strat, Fender Jeff Beck Strat, Fender 56 Heavy Relic Strat and a bunch of pedals.
http://www.youtube.com/watch?v=jVaUdKQsq-s
http://www.creationworldview.org/aboutus.asp
http://www.answersingenesis.org/
http://www.genesispark.org/
John 14:6 is offline   Reply With Quote
Old 08-02-2013, 07:27 AM   #9
50WPLEXI
Senior Member
50WPLEXI's Avatar
I used Tung Sol 12ax7's in both of my Marshall V1 slots until I could afford great NOS tubes. They did a admiral job, and lasted long. The JJ's just were dull, and lifeless sounding to me.
Tone is very subjective as you know, and they might work great in some amps. The good thing is that both tubes are inexpensive, so try both.
50WPLEXI is offline   Reply With Quote
Old 08-02-2013, 09:29 AM   #10
johnfv
Senior Member
johnfv's Avatar
Quote:
Originally Posted by 50WPLEXI View Post
...Tone is very subjective...try both...
+1 Tung Sol was never bright or harsh for me, and I play mostly bright guitars. To my ear they have a lot of mids (which I like) and good gain. Clearly we are deep into the subjective territory so as others have said, try a few and trust your ears.
__________________
Old 08-02-2013, 09:57 AM   #11
pedecamp
Senior Member
pedecamp's Avatar
Tungsol is brighter, JJ is darker. Depends on the amp which to go with. My DSL is bright so the JJ worked better than Tungsol in my case, but I did buy them both to try out I suggest you do the same they are cheap enough.
__________________
JCM800 2204
pedecamp is offline   Reply With Quote
Old 08-02-2013, 10:50 AM   #12
zenfly
Senior Member
zenfly's Avatar
Quote:
Ditto.. rolling tubes is fun if your geeky enough like many of us to hear and notice the difference.. Real nut cases like me roll $$$ stuff from the 50s and 60s that are in a different class altogether.. For a NOS deal I don't think you can beat having a RFT 21ax7.. I have one in V1 of one of my JTM45 with a nos GE V2 and really like the Marshall attitude it added.. Before it was really kind of 59 bassman-ish to me.. The other thing is the RFT will likely last for as long as you own that amp.. I just checked ebay and they're $20-30 .. That's a great deal my tube rolling friends ..
edit: I don't sell tubes.. ebay note:buy only w/guaranty tested & return policy and that seller is 100%
__________________
Marshall JTM45 Mk2/GEC KT66
Mojotone JTM45/Siemens NOS el34,
Marshall Mosfet 100 / 1965a
Marshall MG15dfx,
Marshall 2045(Sourmash Clone)1973 Creamback
Fender 59 5f1 Champ,
Fender 57 5e3 Deluxe,
Fender 63 Vibroverb,
Fender 67 Super Rev
Fender 91 Vibroking.
Dr.Z Maz18
too many guitars..
Jim Marshall 1923-2012 "Leo" Fender 1909 1991
zenfly is offline   Reply With Quote
Old 08-02-2013, 11:15 AM   #13
johnfv
Senior Member
johnfv's Avatar
Tungsol is brighter, JJ is darker...
I don't know that I've tried any 12AX7 that was darker than the JJ, so from that perspective any tube you compare will be "brighter". I'm not knocking the JJ, particularly if you are trying to tame a bright amp. For most applications I prefer a little more punch. Of course YMMV...
__________________
Old 08-02-2013, 11:51 AM   #14
diesect20022000
V.I.P. Member
diesect20022000's Avatar
sonically the tung sol's higher gain than the standard JJ and it's brighter. it also doesn't take high PV's as well as the JJ and isn't as rugged but tonaly they're superior imo as they have much more top end and brighter mids. they take a few hours of constant use to burn in before they don't sound and feel stiff but once they burn in they're great tonaly.
of course it depends on the amp you're running as well. Marshalls can sometimes eat them in the gain position of the preamp.
Old 08-02-2013, 12:10 PM   #15
johnfv
Senior Member
johnfv's Avatar
I'm curious. Does anyone have a tube they consider to have a darker tone than the JJ? RFT is one I have not tried, might need to give that a go...
__________________
Old 08-02-2013, 05:01 PM   #16
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
An RFT is slightly darker than a JJ.
I also want to add that most of the guys here use and comment on just a few of the brands available. There are some other very good 12AX7's available and all of them are Chinese. The Chinese are getting very good at making tubes and I feel within the next two years they will be dominating the market.
Some of the "obscure" 12AX7's are:
Preferred Series 7025 ($24 each)
Any TAD, but mainly the 7025S ($25 each)
Ruby (Shuguang) 12AX7AC5 HG+ or 12AX7AC7 HG+ ($17.70 each)
Northern Electric 12AX7 (most expensive $58 each)
Most of these tubes are more expensive than the Tung-Sol's, Mullard RI's and JJ's, but you get what you pay for. The Ruby Shuguang's are the best bang for the buck. (Slightly cheaper than the Mullard RI.)
__________________
Old 08-02-2013, 10:25 PM   #17
Michael RT
V.I.P. Member
Michael RT's Avatar
I've always been a sucker for a JJ in V1 of my vintage Marshall's, more creamy sounding over the Tung Sol's bright top-end and mids.
__________________
Michael RT is offline   Reply With Quote
Old 08-02-2013, 10:58 PM   #18
Adrian R
Senior Member
Adrian R's Avatar
I agree man..the GEs, RFTs..etc... BLOW AWAY all of the CP tubes...both of my DSLs are loaded completely with vintage preamp tubes..probably never have to replace them either. The difference in feel and tone is very obvious...it just makes your Marshall sound more like the Marshalls you remember hearing as a kid...
__________________
99' Marshall JCM 2000 Dual Super Lead 100 w/mods
00' Marshall JCM 2000 DSL 100 w/mods
05' Marshall 1960 4x12 w/mods
85' Marshall 1960 4x12 w/mods
06' Marshall MG-15 microstack w/mods
95' Gibson LP Standard
00' Gibson Flying V98
01' Gibson Flying V98
01' Gibson 67' RI Flying V
06' Gibson 67'RI Flying V
00' Guild DV-6
*Some* hearing loss?
Adrian R is offline   Reply With Quote
Old 08-02-2013, 11:40 PM   #19
customjoe
I eventually settled on TungSol in my V1 with Ruby (Shuguang) 12AX7AC5 HG+ in V2. Good contrast but the TungSol gives that rich detail. I play a Bogner and JJ is just too dark for it. JJs sure are good tubes though
Old 08-03-2013, 12:49 AM   #20
diesect20022000
V.I.P. Member
Quote:
Yeah bogner's are way too dark as it is imo. great tone but i'm constantly working the presence or adding an eq to get the presence. well some of them anyway. The ecstacy's pretty bitchin' all around but my alchemist though I can get lush cleans and plexi like tone on the lead it's super dark.
Old 08-03-2013, 03:32 PM   #21
charveldan
Banned
Location: Somewhere with a Friedman Marshall & Les Paul.
Don't forget the KungPow 12AX7AGSEXBLZ&a$ for $32.50 or 3 for a dollar which ever comes first ...
charveldan is offline   Reply With Quote
Old 08-03-2013, 05:08 PM   #22
chee16
Senior Member
I honestly don't understand when people say that preamps don't make that much of a difference and switching them is for "cork sniffers". Is it our fault you can't hear the difference?
Old 08-03-2013, 07:39 PM   #23
Kunnz
Senior Member
Kunnz's Avatar
Quote:
Yip, subjectivism influences poison in the the pocket! and 'tube rollers' fall into a recalcitrant narrow bracket of nonsensical illogical idealism.
Transparency is free.
I agree with you.
__________________
'Sleeping is a waste of time'
Kunnz is offline   Reply With Quote
Old 08-03-2013, 08:06 PM   #24
Kunnz
Senior Member
Kunnz's Avatar
Hey person, who ever you are, let me tell you one thing.
JJ VALVES ARE JUNK
__________________
Old 08-03-2013, 08:12 PM   #25
charveldan
Banned
Quote:
JJ VALVES ARE JUNK
+1, Agreed.
Old 08-03-2013, 08:26 PM   #26
big dooley
V.I.P. Member
big dooley's Avatar
MY WORDS ARE JUNK
pathetic... fixed it...
__________________
JVM, the only marshall that's been modded to tame it, instead of hotrodding it
big dooley is offline   Reply With Quote
Old 08-03-2013, 08:34 PM   #27
Kunnz
Senior Member
Kunnz's Avatar
Hey boring Dutch Boy,
Why don't you get on your Dyke and cruise the canal of the ass.
Like you, like your country, flat as as pan cake.
__________________
Old 08-03-2013, 08:44 PM   #28
big dooley
V.I.P. Member
big dooley's Avatar
__________________
Old 08-03-2013, 08:46 PM   #29
Kunnz
Senior Member
Kunnz's Avatar
__________________
Old 08-03-2013, 08:56 PM   #30
MartyStrat54
V.I.P. Member
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
