MarshallForum.com
Reply
Thread Tools Display Modes
Old 06-30-2013, 10:10 PM   #1
Vinsanitizer
V.I.P. Member
Vinsanitizer's Avatar
Slash SL5 - a review about this
FWiW, here's my prelim review after spending hours and hours with it (about 4 or 5):
The Good:
  • It sounds like a great 80s amp, and is the closest I've gotten to my mid-80s 2205 and 2210. Sounds nothing like DSL/JVM.
  • It has all the mids that Marshalls have lacked in recent years.
  • The bottom is tight and adequate.
  • I doesn't make me sound anything like Splash
  • The gain channel is very responsive in the way you'd expect a tube amp to react, in both playing dynamics and your guitar's volume control. It cleans up nicely, but not too pristine.
  • Clean channel is very nice; lots of top-end sparkle. It's very clean up until maybe 12:00 and then it goes to a nice grind by the time you get to max volume.
  • Reverb is nice; plenty of it. It doesn't get in the way.
  • The amp is quiet, though it has normal hiss when gain and volume is high and you're not playing.
  • More features and versatility, better build, higher gain than Class 5.
The Bad:
  • It lacks FX loop, independent channel EQ.
  • It's heavy - about 50 whopping lbs.
  • It's largid - larger than it seems. However, its taller design makes it easily double as a stool.
  • Overpriced but not by too much when you compare it to the Class 5 ($500) which had less features.
Other Commentium:
  • The overall voicing of the amp is bright and tight. Plenty of treble and mids, very clear. The bottom end is very tight. This makes neck pickups sound woody and clear.
  • There is plenty of gain for hard rock and early 80's metal without a pedal. Pre-Rectifier tones only - not for scooped mids.
  • Can't figure why a 5 watt amp needs to have power attenuation to 1 watt; why not just turn the Volume down? The sound is different of course, 1 watt mode is squishier as you'd expect and has less treble. Either mode sounds great. I like the 5w tones but I like the squishiness of the 1 watt. In 1 watt mode you can crank the clean channel while remaining quieter.
  • What is the need for a low sensitivity input?
  • I don't get the need for footswitchable reverb; who the heck switches reverb on & off? Get rid of the 1 watt mode, low-sensitivity input jack and the reverb switching, and add an FX loop.
  • What's with the power switch going from Standby to Off to On?
  • 50lbs. is bestial, considering a whole Vintage 30 4x12 cab weighs only 50% more (80lbs.) It's a 1x12 amp with one EL34 - how heavy could the transformer, speaker and box weigh?
That's all I can think of right now.
__________________
I changed my mind.
(The power of Teh compels you.)
Vinsanitizer is offline   Reply With Quote
Old 06-30-2013, 10:31 PM   #2
hidetox
Senior Member
hidetox's Avatar
Re: Slash SL5 - a review about this
thanks for the review! great read. I was seriously considering getting one.. but... ended up getting other stuff. ... enjoy the SL5!
__________________
2011 AFD100
2011 1936 with V30s
2013 AXE FX II
hidetox is offline   Reply With Quote
Old 06-30-2013, 10:46 PM   #3
Groovejunkie
Senior Member
Groovejunkie's Avatar
Yes. Crank it!
Groovejunkie is offline   Reply With Quote
Old 06-30-2013, 10:48 PM   #4
S÷ulcaster
V.I.P. Member
S÷ulcaster's Avatar
HNAD....congrats
I don't mind having foot switchable reverb tbh....it's not essential but, comes in handy in some situations.
Rock out
Peace
__________________
"weight of my heart...not the size"
Quote:
Originally Posted by bulldozer1984 View Post
there is something about the raunchy n sexy sounding AFD that makes me tingle !
S÷ulcaster is offline   Reply With Quote
Old 07-01-2013, 09:26 AM   #5
PBGas
Senior Member
PBGas's Avatar
Fantastic little amp! I love mine!
A very accurate review!
well done!
PBGas is offline   Reply With Quote
Old 07-01-2013, 02:47 PM   #6
duncan11
Senior Member
duncan11's Avatar
Quote:
The Good:
The Bad:
Other Commentium:
The #1 reason why I didn't buy one. Thanks for the writeup though.
__________________
"Well, it's one louder, isn't it? It's not ten. You see, most blokes, you know, will be playing at ten. You're on ten here, all the way up, all the way up, all the way up, you're on ten on your guitar. Where can you go from there? Where? NOWHERE!!!"
AFD100
YJM100
Class 5 combo
1986 Lead 12 Microstack
1960A
JCM900 1960A V30's
JCM900 1936
duncan11 is offline   Reply With Quote
Old 07-01-2013, 03:00 PM   #7
tarznamps
Senior Member
tarznamps's Avatar
I second the review.
As far as an FX loop. I'm not sure how many 5w/1w practice amps will come
with a loop. I assume Marshall/Slash figured this as a practice amp and not
a giging or recording amp.
If it is a really big deal, there are work-arounds, I know a lot of players that use hihg-end amps with NO FX LOOP.
That certainly didn't stop me from getting one.
__________________
Tarz-N-Amps
MARSHALLS
Heads - 6100LM, DSL15H, JVM410JS, 2555SL, JVM1, DSL1, JCM1, JMP1, JTM1, JMD1, YJM100, AFD100, JVM210, JTM45, DSL100, JCM800 2203 & 2205, JCM900 4100, VM2466, 1974, 1987x, Haze15, C5H
Cabs - 1960AX/BX, 1960A/B, 1960AV/BV, 425A/B, 1965B, 1936, Haze A/B, C5 A/B
Combos - SL5, Class5, JMP4140 Club & Country, DSL401, JCM900 4501, JTM615
tarznamps is offline   Reply With Quote
Old 07-01-2013, 03:20 PM   #8
duncan11
Senior Member
duncan11's Avatar
I know, but still at the price point this is, kinda silly to have to jump thru more hoops! Tonewise they don't sound bad imho I didn't know they were that heavy!! That'd be an eye opener!
__________________
AFD100
YJM100
Class 5 combo
1960A
JCM900 1960A V30's
JCM900 1936
Old 07-01-2013, 03:22 PM   #9
Sournote
Senior Member
What makes the thing weigh 50 pounds?
Sournote is online now   Reply With Quote
Old 07-01-2013, 03:50 PM   #10
duncan11
Senior Member
duncan11's Avatar
Quote:
slastone.....it weighs a ton......
__________________
AFD100
YJM100
Class 5 combo
1960A
JCM900 1960A V30's
JCM900 1936
Old 07-01-2013, 07:38 PM   #11
Vinsanitizer
V.I.P. Member
Quote:
I honestly have no idea. There's a speaker, a transformer and a wooden box, not much more than that.
__________________
I changed my mind.
Old 07-01-2013, 10:21 PM   #12
SRT2011
Senior Member
Great review Vinsanitizer!
For the most part I agree with your review, but here are some of my thoughts that are a bit different than yours.
1. Heavy, yeah it is for a 5W amp, but the larger cabinet with 12" V30 speaker is why, and is also why it sounds so good.
2. I like the footswitchable reverb because it sounds great on or off in both channels depending on the needs.
3. I also like the dual input option....I am still not sure which I like better on any given guitar. There again more versatility.
4. I also like the 1W option. Yes, it will sound darker in that setting. No problem, use the very effective EQ and Presence controls to brighten it up to your liking.
5. I am really impressed with how effective the EQ and Presence knobs work for a wide variety of great sounds using many different type guitars.
I have owned my SL-5 for about a month now, and am truly enjoying the great sounds that I am achieving in both channels with multiple guitars!
Great job Marshall!!
SRT2011 is offline   Reply With Quote
Old 07-01-2013, 10:45 PM   #13
SwampThing
Senior Member
SwampThing's Avatar
The Good:
The Bad:
Other Commentium:
....And it's made by MOTHER-F@#%IN SAUL HUDSON!!!!!
__________________
Ultra Moderator
SwampThing is offline   Reply With Quote
Old 07-01-2013, 11:31 PM   #14
bulldozer1984
V.I.P. Member
bulldozer1984's Avatar
Its heavier because of the extra thick multi layered ink. The AFD100 suffered from insufficient ink that rubbed off too easily. Not the SL5 !
bulldozer1984 is offline   Reply With Quote
Old 07-01-2013, 11:32 PM   #15
SRT2011
Senior Member
SwampThing,
Beating a dead horse.....really??? Discussions of the SL-5 on this forum have been few and far between.....too few for that matter IMHO.
I am not one to be judgemental of an amp because of who signs it and/or where its made. I judge amps on how they sound and frankly, hope for reliability....which of course is an unknown for all tube amps no matter how expensive and where they are made IMO.
Hey, I understand...the SL-5 ain't your thing. No problem.
However, I love this amp for my needs and so may others for their needs!!
To each their own.
Old 07-01-2013, 11:53 PM   #16
Odin69
Senior Member
Odin69's Avatar
That's a nice little amp. I played one at GC a few weeks ago.
Odin69 is offline   Reply With Quote
Old 07-02-2013, 12:54 AM   #17
SwampThing
Senior Member
SwampThing's Avatar
Quote:
Originally Posted by SRT2011 View Post
SwampThing,
To each their own.
Says the guy with 42 posts.
__________________
Ultra Moderator
Old 07-02-2013, 12:55 AM   #18
SwampThing
Senior Member
SwampThing's Avatar
And I LAUGH OUT LOUD at "DA Slash TONEZ dont get talked about much here"
The sky is blue
Death and Taxes
Marshall Forum and Slash TOANZ
__________________
Ultra Moderator
Old 07-02-2013, 01:36 AM   #19
SRT2011
Senior Member
SwampThing,
No doubt...Slash tones are discussed forever on this forum! I definitely agree with that statement. My comments about the SL-5 amp have nothing to do with "Slash tones" at all.
I love the amp for the fantastic classic rock / hard rock and clean tones that it can provide. It is a simple as that. Others may too.
As far as the number of posts......yes you are very correct. I don't post often, but when I do.....I try to post with something meaningful based on my experiences with Marshall amps which is what I thought this forum was all about? Apparently, you do not...at least not this time.
Old 07-02-2013, 05:53 AM   #20
Sournote
Senior Member
Kinda defeats some of the attraction of a 5w amp for me.
Why lug a 50 pound 5 watter vs. a 50 pound 40 watter?
Old 07-02-2013, 07:34 AM   #21
Vinsanitizer
V.I.P. Member
It's not a deal breaker for me, though I'd certainly prefer 30lbs. You won't be using a 5 watter for many gigs, it's a home practice/recording amp. And if you were going to gig with it mic'd up, you'd still typically be using an amp of about equal or more weight otherwise.
__________________
I changed my mind.
Old 07-02-2013, 08:15 AM   #22
Micky
V.I.P. Member
Micky's Avatar
I wonder if I can get one without the fugly logo on it?
__________________
Stupidity should be painful...
Marshall MHZ15, DSL40c, DSL5c, M4, 4X12 full stack, Gibson LP, VOX, Eminence, Celestion, Ovation, Fender & more...
Micky is online now   Reply With Quote
Old 07-02-2013, 08:29 AM   #23
Sournote
Senior Member
Yeah, I'm not a gigging musician but I do go jam with friends from time to time. I've been thinking a small, lighter amp might be cool for that if it was loud enough and spared me hefting my larger amps around.
Old 07-02-2013, 03:00 PM   #24
Pete1983
Junior Member
So basically the differences between this and the class 5 are the extra effects And more distortion ? Any other differences i would be happy to hear them. I have the class 5 currently but very interested in giving the sl 5 a go. How does the sl 5 sound through headphones? I find the class 5 horrible through headphones which makes night time practicing impossible
Pete1983 is offline   Reply With Quote
Old 07-02-2013, 03:15 PM   #25
Rocktane
Senior Member
Rocktane's Avatar
Quote:
IMO, the similarities between the Class 5, and the SL-5, are limited to the 5 watt ratings, and the fact that they are both Marshalls. Speaker, tubes, circuit, features, are all different.
Rocktane is offline   Reply With Quote
Old 07-02-2013, 03:19 PM   #26
SonVolt
V.I.P. Member
SonVolt's Avatar
Let me get this straight - the SL-5 is made in China but the Class 5 is made in England?
__________________
In memory of Grunch. Who hated this forum, and everyone in it.
SonVolt is offline   Reply With Quote
Old 07-02-2013, 03:25 PM   #27
Micky
V.I.P. Member
Micky's Avatar
Those are 2 completely different beasts...
__________________
Old 07-02-2013, 04:03 PM   #28
PBGas
Senior Member
PBGas's Avatar
I had the class 5 previously. A nice little amp but I didn't like the dirty tones on it. The SL5 sounds to me what I have been looking for. With a smaller gig, I can run it through the Two-Notes Torpedo Live loadbox and it sounds amazing.
Very happy with it. The FX loop, I'll deal with at some point by getting one added in. I need that for my delay and some of my Fx to run through it. Not a dealbreaker though. The reverb does very nicely to help with that.
Old 07-02-2013, 04:49 PM   #29
Vinsanitizer
V.I.P. Member
The Class 5 is a one-channel no frills amp. It's a cool little box for people who want a low-powered non master volume "clip and rip" amp. Uses one EL84, two preamp tubes, 10" generic speaker, headphone out. It is currently discontinued.
The SL5 has two channels, Presence control low/high inputs, dual wattage selection, digital reverb, Vintage 30 12" speaker, single EL34, three preamp tubes and a proportionately large box to facilitate the speaker and enhance the tone.
Not to knock the Class 5, but I was an early adopter and had a lot of the problems that plagued the amp right out of the starting gate: mainly, the placement of the EL84 too close to the speaker spelled the future demise, as it caused irreparable rattle. The entire box rattled and buzzed as well. They ended up doing a redesign to address these issues, and subsequently raised the price from US $399 to $499. By then it was too expensive and was falling out of favor. Lack of sales left it in the dust.
I can't say for sure the SL5 will become overly popular; it's expensive and heavy for a 5 watter. The US $699 tag and Slash signature will likely further relegate this amp to "Limited Edition" status, and will probably be phased out by the next greatest release - personally, I'm expecting a reissue of the entire Silver Jubilee series, but I ain't holdin' my breasts.
For now, the SL5 is with us and will probably always remain a cool collectable. It's a great amp for the Jube sound, and a great amp for any collector.
__________________
I changed my mind.
Old 07-02-2013, 06:10 PM   #30
Australian
V.I.P. Member
Australian's Avatar
What if Marshall brought out a EVH5? There's one that every man and his dog would be lining up for.
__________________
Thank You
Marshall Heads
1971-JMP 1959
1977- JMP 1959
1982-JCM800 2203
1989-JCM800 2205
Silver Jub 2550
30th Ann-6100
2007-JVM410
Super JTM/100JH
2008-1959RR
JMD-1
Marshall cabs
1982AJH+1982BJH--White A/GT75's+B/V30's--30th Ann-B-G12T75's
JCM800 A+B/preRolas-- AHW+BHW-- AX+BXClassic/G12M's-- Classic/G12h30's
JCM800 B/G12-65's--1936/V30's --1936/G1265's
Australian is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
