MarshallForum.com
Reply
Thread Tools Display Modes
Old 05-05-2009, 05:02 PM   #1
ironlung40
Senior Member
ironlung40's Avatar
200 watt solid state bass amp enough???
Will a 200 watt solid state bass amp be enough to play with a 50 watt all tube marshall head with a 2x12 cab?
I guessing maybe with the right speaker setup, but not with a combo 1x15?
Any suggestions on a cheap bass rig that would be good for recording and sufficient for small gigs with a 50 watt marshall head?
Music style is hard rock.....
Thanks Marshallites
ironlung40 is offline   Reply With Quote
Old 05-05-2009, 05:12 PM   #2
Vintager12
Senior Member
Vintager12's Avatar
Re: 200 watt solid state bass amp enough???
Thanks Marshallites
Hmm... Probably Coldsteal2 can help you....
If you can get a cheap 200w SS bass combo it will be okeay...
__________________
The Emperor of the Vintage Modern.
Vintager12 is offline   Reply With Quote
Old 05-05-2009, 06:50 PM   #3
javier pintos
Senior Member
javier pintos's Avatar
our bass player has a 300w ss amp with a 2x15 and 2x10 cab and it is just freaking loud, we have gig with a DSL100, an AVT50 w/2x12 and an MG100 w/4x12and the bass amp had no issues to play as loud as required (neither the AVT or the MG) on a 250 people bar so i guess a 200 W with the proper cab can do the trick, just get the most efficient speakers you can
a 50 w amp with 100db speakers can sound as loud as a 100w amp with 97db speakers
javier pintos is offline   Reply With Quote
Old 05-05-2009, 06:58 PM   #4
coldsteal2
Senior Member
coldsteal2's Avatar
Depends on the gig, small gigs yea, but bigger auditoriums
no. I would go with at least a 2 15 cab, or 4 10 cab
but you can get 300 watt ss amps pretty cheap now
If its a 200 watt Tube amp though it will be loud enough
for some reason they pump out more power?
Not all SS amps are created equal though, get a
quality bass amp if you can like Galien Kruger
Really its more important to have more speaker
power than amp power though so you are pushing
more air, bass is all about pushing air
__________________
Playing Marshall's since 1969
Vintage Modern 2266, JCM-800, JCM-900,1960A(G12H's), DSL-401,AVT-50combo , CLASS 5 Head,Orange Rockerverb 50, and cab
My Youtubes......ColdSteal II on Soundclick.com
coldsteal2 is offline   Reply With Quote
Old 05-05-2009, 07:00 PM   #5
ironlung40
Senior Member
ironlung40's Avatar
thanks, I can only afford a cheapo right now, was looking at the 1x15 Acoustic 200watt combo, and then to use and extension cab with it when gigging. It sounds pretty good in the store as far as tone goes, so I think it would be a good recording amp for the money, but just curious about a live gig with it.
Old 05-05-2009, 07:03 PM   #6
coldsteal2
Senior Member
coldsteal2's Avatar
AH Acoustic is an excent bass amp
if thats all you can afford, that would be a good one.
if you can keep your guitarist at about half volume
it would help
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
