MarshallForum.com
Reply
Thread Tools Display Modes
Old 04-21-2013, 09:10 PM   #1
keennay
Senior Member
keennay's Avatar
Cranking Your Amps All the Way...
For those with master volume amps, I have to ask do you really think your amps sound that great cranked all the way, or is that just the general saying around here?
Both my JMP 2203's, one with EL-34's & other with 6550's, sound glorious with the MV from 2.5 to 4, then exponentially worse from 5 to 10 (the EL-34 version not as bad as the 6550 version). I just never see a reason to push the master volume past 4 seeing as I'm already reaching power tube breakup by then (or at least I'd like to think I am). I can crank the volume all the way to 10 without running the risk of bothering neighbors due to my location, but I just see (or hear) no reason to.
I've run them on 4x12's loaded with either G12M-25 (Pre-Rola Greenbacks from '69), G12T-75's, or Vintage 30's. Perhaps I need to try other speaker configs, because at a MV of 5 these cab speakers aren't sounding all too happy.
Just curious and would like folks' opinions, not meaning to insult or flame. I couldn't imagine pushing a non-Master Volume amp and expecting a decent tone while heavily pushing any of those speakers without an attenuator. Perhaps there's something wrong with my amps, or ears?
keennay is offline   Reply With Quote
Old 04-21-2013, 09:27 PM   #2
maxime1122
Senior Member
maxime1122's Avatar
Re: Cranking Your Amps All the Way...
I found that on every marshall I had, the sweet spot was around 6-7 on the master, except the plexi which I prefer dimed.
I had a JMP 2203 with EL34 and the sweet spot was at 6 for me.
__________________
"The only way you're going to get the 'dimed Marshall Plexi' sound is with a dimed Marshall Plexi."
maxime1122 is offline   Reply With Quote
Old 04-21-2013, 09:32 PM   #3
Grogshla
Senior Member
I normally run my gain at 3/4 and my volume at 1/2. Gives sweet tones
Grogshla is offline   Reply With Quote
Old 04-21-2013, 09:34 PM   #4
allstar100595
Senior Member
Yeah, anything above 6-7 for my 2203 is just too much. However, it is a balancing act; gotta play with the pre volume as well.
__________________
Marshall JMP 2203
Marshall JMP-1C
Avatar 4x12 Bass Cab w/ V 30's
Gibson LP Trad Iced Tea w/ Bare Knuckle Rebel Yells
Gibson Explorer w/ Duncan JB and '59
PRS SE One w/ Dimarzio Tone Zone P90
Trailer Trash Pedalboard
Way Huge Green Rhino
ISP Decimator G String
Korg Pitchblack
EB Volume
EVH Phase 90
EVH Flanger
allstar100595 is offline   Reply With Quote
Old 04-21-2013, 09:41 PM   #5
keennay
Senior Member
keennay's Avatar
I usually keep my pre-amp on 10 & boost it more with an Analogman modded Maxon OD-9.
Master Volume on 4 is the sweet spot for me when working with a crunch/overdrive tone.
Old 04-21-2013, 10:02 PM   #6
drgordonfreeman
Senior Member
drgordonfreeman's Avatar
I have a JVM, and it sounds like dog **** with the MV past 5. 4 is really the sweet spot, if you ask me.
On the MVAs I've played, 4-5 seems to be the sweet spot.
Also, I've always used Celestion G12K-100 speakers since forever. They've always kept their composure, regardless of how much juice I've put through them.
drgordonfreeman is offline   Reply With Quote
Old 04-21-2013, 11:16 PM   #7
EndGame00
Senior Member
EndGame00's Avatar
On my Mesa, I set it on Tweed and the Master Vol @ 5.5... I usually fiddle the channel volumes to find that sweet spot.
EndGame00 is online now   Reply With Quote
Old 04-21-2013, 11:20 PM   #8
CaptainZero
Senior Member
CaptainZero's Avatar
I have an AFD and my master rarely leaves 10. BUT, if I also crank the attenuator, I get a ton of almost uncontollable feedback. I don't really even need to turn it past 5, even at stage volume.
__________________
Quote:
Originally Posted by Grunch View Post
Everytime I get a like, Santa Claus kills a kitten, and I masterbate furiously.
CaptainZero is offline   Reply With Quote
Old 04-21-2013, 11:25 PM   #9
Gblev
Senior Member
Gblev's Avatar
With the EPA on the AFD, this is where it shines. It is easy to get output tube distortion at low volumes. But it is really cool when your moving some air and you get the speakers more involved. I like the Master around 7.5 and the gain around 4 to 5, Then I adjust the EPA for the loudness. If I want it really quiet with tubes screamin, like late at night when everyone else is sleeping, I'll engage the FX loop and have it attenuate some more. This is the most amazing amp I've ever played, any level of preamp or output distortion at any volume level. Marshall should put this on every amp.
Gblev is offline   Reply With Quote
Old 04-21-2013, 11:28 PM   #10
Gblev
Senior Member
Gblev's Avatar
Quote:
Are you talking about the EPA? I have never experienced any feedback that I didn't initiate first, at any setting.
Old 04-22-2013, 03:02 AM   #11
MonstersOfTheMidway
Senior Member
Send a message via ICQ to MonstersOfTheMidway
Nah, I never dime the master volume (I have a stock JVM 410H).
I use a 2X12 with two Celestion 90 watt speakers wired in series (180 watts total), and I never got a "I can't hear you...turn it up" complaint. Thick, powerful, clear projection of clean, crunchy, moderate gain, and high gain tones at almost any volume. I feel spoiled.
MonstersOfTheMidway is offline   Reply With Quote
Old 04-22-2013, 06:30 AM   #12
blues_n_cues
V.I.P. Member
blues_n_cues's Avatar
preamp around 7 or 8 for LP,6 for strat,Master no more than 7 but by then it's usually killing coyotes in the next county.
__________________
LIFE,LIBERTY,& the pursuit of TONE.
2007 Epi LP Custom LTD.
1991 Jackson DK-2 HSS
2010 Austin LP GT w/ P90s
custom rebuilt Washburn BT-2 Maverick
Marshall JMP-1 (rack)
Marshall CODE 100 (eventually) lol
a bunch of other carp
my music,sounds,samples,& snippets-
http://www.reverbnation.com/rlcltd
https://soundcloud.com/rlc-ltd
Stratisfied
https://soundcloud.com/rlc-ltd/stratisfied
just riffing
https://soundcloud.com/rlc-ltd/just-riffage
blues_n_cues is offline   Reply With Quote
Old 04-22-2013, 07:47 AM   #13
S÷ulcaster
V.I.P. Member
S÷ulcaster's Avatar
I've dimed my 1959 a few times and can't really say it sounded any better on 10 than it does on 7. I've never dimed my AFD, that mofo us just too ****in loud. It does sound better the more you crank it though.
Peace
__________________
"weight of my heart...not the size"
Quote:
Originally Posted by bulldozer1984 View Post
there is something about the raunchy n sexy sounding AFD that makes me tingle !
S÷ulcaster is offline   Reply With Quote
Old 04-22-2013, 09:09 AM   #14
anitoli
Senior Member
anitoli's Avatar
With my 6100 it really depends on the size of the room. The bigger the room the more MV it can take and still doesnt give you too much eardrum compression. I always have to fine tune whenever i move it to a new location. Its all relative.
__________________
6100 MIDI Support
http://home.myfairpoint.net/vze1u14s...supportservice
anitoli is offline   Reply With Quote
Old 04-22-2013, 12:11 PM   #15
spiritdave
Senior Member
2.5 on the master volume on every Marshall amp sounds like utter ass ... you need to get into the realms of 7 - 8 and 9 ... My JMP 2104 sings like you have no idea when you get to those volumes on the Master, and Pre ... sounds incredible. JMP's are the worst sounding low volume amps ... lol
__________________
Gibson Les Paul Standard (1989, Seymour Duncan '59 Neck and JB Bridge)
Gibson Les Paul Standard (2013, Burstbuckers)
Marshall 1978 MkII JMP 2104
spiritdave is offline   Reply With Quote
Old 04-22-2013, 12:40 PM   #16
pleximaster
Senior Member
pleximaster's Avatar
Plexis sounds best around 8-10 in my opinion.
Plexi
pleximaster is offline   Reply With Quote
Old 04-22-2013, 12:58 PM   #17
wulfgar1976
I never turn a 50W head all the way up as the power valves distort too much.
I like my 6100s at full volume with high gain - the EH6CA7s and JJ 6L6GCs have enough headroom for that. I wouldn't do the same with EL34s.
wulfgar1976 is offline   Reply With Quote
Old 04-22-2013, 01:35 PM   #18
XxIPxX
Senior Member
XxIPxX's Avatar
I can hit 8-9 on my clean or dirty channel with no problems at all
XxIPxX is offline   Reply With Quote
Old 04-22-2013, 02:19 PM   #19
charveldan
Banned
Location: Somewhere with a Friedman Marshall & Les Paul.
The sweet spot on my Friedman is about 4 or 5. It has resistors on the MV to tame down headroom, after 5 it goes back to fullblown JMP.
My stock 6550 JMP 2203 i sold, but was stupid LOUD. i think the most i could stand indoors was 4 on the MV.
Never got it outside, was a great sounding amp. At one point was going to have Friedman tweak that one too but sold it as is.
Never played a Marshall Major but the LOUDEST Marshall i ever played was a 67' SuperBass ... was scary LOUD !!!
charveldan is offline   Reply With Quote
Old 04-22-2013, 02:22 PM   #20
CaptainZero
Senior Member
Quote:
Yes I meant EPA. If I get it over 5, it's really easy to have it feedback. If I let go of the strings for even one second it starts. With both guitars.
__________________
Old 04-22-2013, 04:42 PM   #21
GIBSON67
Senior Member
GIBSON67's Avatar
I run my treble channel on max and bass channel on 6 and then run the PPIMV anywhere from on 4 to 8 depending on which guitar and how loud I want to be...
GIBSON67 is offline   Reply With Quote
Old 04-23-2013, 09:02 AM   #22
bdubbs
Senior Member
Probably your OT distorting when it starts losing it.
bdubbs is offline   Reply With Quote
Old 04-23-2013, 09:42 AM   #23
Ken
Senior Member
Ken's Avatar
You can put the MV on 10 on a DSL and it sings, but you have to keep the gain in check or it compresses too much for my taste.
Ken
__________________
1999 Marshall DSL 50
Late 1970's (?) Fender Champ
Marshall battery amp
PRO 4x12 from the 1970's
Woodson 2x12
1976 Les Paul Standard
Epiphone Les Paul knockoff
ESP Lawsuit Explorer
1979 Chiquita Travel Guitar
1995 Taylor 310
Ken is offline   Reply With Quote
Old 04-23-2013, 01:18 PM   #24
SkinnyJ
Senior Member
SkinnyJ's Avatar
On my 4104, I find that, after 4-5 on the Master, there doesn't seem to be a massive volume increase. 3-4 seems to be a good "sweet spot" on that amp.
__________________
'84 Marshall JCM800 4104
Blackstar HT-20
Marshall Class 5
ADA MP-1 (Version 1)
1987 Les Paul Standard
2009 American Standard Strat
Takamine EG531SC Acoustic
My Band: Fistful of Karma
SkinnyJ is offline   Reply With Quote
Old 04-23-2013, 01:38 PM   #25
Gblev
Senior Member
Gblev's Avatar
Hmm... That's never happened to me, how close are you in proximity when you are playing, and what kind of pickups do you have?
Old 04-23-2013, 01:39 PM   #26
Wiking
Senior Member
Wiking's Avatar
Depends on the music. Not every song needs the same overdrive. I prefer 6 on my plexi, for louder it gets into van halen territory. I dont play that. I like classic early 70's rock. Even then, on some songs I have to roll back the guitar volume to clear it up a bit.
On 4 however the plexi gets a little tiny and harsh. On 2 and lower it really sounds nice and clean, but I miss the roar. So 6 it is. The magic number.
__________________
Wiking is offline   Reply With Quote
Old 04-23-2013, 03:49 PM   #27
chee16
Senior Member
I have been doing a lot more playing lately, and my amp setup has gotten a ton of tweaking. My tsl602 as of right now (new speakers are on the way) definitely has a sweet spot between 5-7 on the master volume. That's not to say that it couldn't have good sounds over or under that but so far that is where it sounds best.
chee16 is offline   Reply With Quote
Old 04-23-2013, 04:12 PM   #28
Coronado
Senior Member
Coronado's Avatar
I'm embarrassed to say that I've never had my (relatively new) JCM 800 2203 beyond 4 yet. (I can see the heads shaking already... ). But I'm hoping to get the chance soon!
Any suggestions on where the 2203 sounds best (with 1960 A cab with 2 vintage 30's)?
Thanks!
Coronado is offline   Reply With Quote
Old 04-23-2013, 05:01 PM   #29
Kylelagz
My jmp 2204 sounds incredible at any volume past 5. i like being loud and i like moving air. The sound coming out of its not too bad either!
Kylelagz is offline   Reply With Quote
Old 04-23-2013, 06:27 PM   #30
40-haze-tone
40-haze-tone's Avatar
Strangely, my haze gets a little too toppy and irritating for my ears past 4... When I'm in the room with it. But on recordings, i find it sounds better the louder it gets. In person I play around 3 or 4 though, anyone else find this too or am I just being dumb?
40-haze-tone is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
