MarshallForum.com
Go Back   MarshallForum.com > Music Gear > Guitars
Reply
Thread Tools Display Modes
Old 03-15-2013, 10:57 PM   #1
axe4me
Senior Member
Gibson Tim Shaw Humbuckers
What's the big deal with them?
axe4me is offline   Reply With Quote
Old 03-16-2013, 12:11 AM   #2
stax
V.I.P. Member
stax's Avatar
Re: Gibson Tim Shaw Humbuckers
Gibsons first attempt at reproducing a PAF voiced pickup, they sound great (and were pretty close sounding) and they later officially became the 57 Classic we now all know and love.
stax is offline   Reply With Quote
Old 03-16-2013, 02:37 AM   #3
tazzboy
Senior Member
tazzboy's Avatar
Yeah Mr Shaw had to do with Poly Wire and not Plain Enamel Wire cause Gibson at the Time would go the extra buck to get Plain Enamel Wire.
__________________
tazzboy is offline   Reply With Quote
Old 03-16-2013, 08:30 AM   #4
^AXE^
Senior Member
^AXE^'s Avatar
Quote:
What?
^AXE^ is offline   Reply With Quote
Old 03-16-2013, 10:49 AM   #5
axe4me
Senior Member
According to my searches, Gibson stopped using Tim Shaw humbuckers in 335's in 1987.
More valuable?
Old 03-16-2013, 04:00 PM   #6
stax
V.I.P. Member
stax's Avatar
Quote:
More valuable?
A Tim Shaw era pickup commands a premium, but as I stated they became the 57 Classic.
Old 03-16-2013, 05:10 PM   #7
tazzboy
Senior Member
tazzboy's Avatar
Quote:
Originally Posted by ^AXE^ View Post
What?
I was talking about how Mr Shaw went about making his version of the PAF
in fact here is story
Quote:
Whether it was rivalry between plants or increased market awareness, the Nashville plant jumped into the reissue action in 1980. By this time, one of the most glaring deficiencies of new Les Pauls (compared to the originals) was the humbucking pickup. In preparation for its first attempt at a reissue, Gibson assigned engineer Tim Shaw the job of designing a reissue of the original Patent-Applied-For humbucking pickup-within certain restrictions. "This was 1980 and Norlin was already feeling the pinch," Shaw said, referring to Gibson's long decline through the 1970s and early '80s. "We weren't allowed to do much retooling. We redid the bobbin because it was worn out. We got some old bobbins and put the square hole back in. We did it without the T-hole, which stood for Treble."
To replicate the magnets, Shaw gathered up magnets from original PAFs and sent them to a lab to be analyzed. "Most were Alnico 2's," he said, "but some were 5's. In the process of making an Alnico 5, they stick a magnet in a huge coil for orientation, but an unoriented 5 sounds a lot like a 2. They started with Alnico 2 and then switched to Alnico 5."
Shaw discovered that the original magnets were a little thicker than 1980 production magnets. "Magnetic strength is largely a function of the area of the polarized face; increasing the face size gives you more power," he explained. So he specified the thicker magnet for the new PAF.
Wiring on the originals was #42 gauge, which Gibson still used. However, the original wire had an enamel coating and the current wire had a polyurethane coat, which also was of a different thickness or "buildup" than that of the original, which affected capacitance. Norlin refused to go the extra mile-or extra buck, as it were. Enamel-coated wire cost a dollar more per pound than poly-coated. Shaw could change the spec on the buildup without additional expense, so the thickness of the coating was the same as on the original wire, but he was forced to use the poly coat. The difference is easy to see: purple wire on the originals, orange on the reissues.
Shaw later found a spec for the number of turns on a spec sheet for a 1957 ES-175. "It specified 5,000 turns because a P-90 had 10,000 turns and they cut it in half," Shaw said. In reality, however, originals had anywhere from 5,000 to 6,000 turns, depending on how tight the coil was wound. Shaw later met Seth Lover, who designed and patented Gibson's humbucker, at a NAMM show. Lover laughed when asked about a spec for windings, and he told Shaw, "We wound them until they were full."
The spec for resistance was even less exact, Shaw said. The old ohmeter was graduated in increments of .5 (500 ohms). Anywhere between 3.5 and 4 on the meter (3,500 to 4,000 ohms) met the spec. Consequently, Shaw pointed out, there is no such thing as an exact reissue or replica of the 1959 PAF pickup. There can only be a replica of one original PAF, or an average PAF. As Gibson would find out in the early 1990s, the same could be said about the entire guitar.
Shaw's PAF reissue debuted on Gibson's new Nashville-made Les Paul Heritage 80 in 1980. Compared to anything Gibson had previously made (which is to say, compared to nothing), it was an excellent reissue of a sunburst Les Paul Standard. It had a nice top, thin binding in the cutaway, nickel-plated parts, more accurate sunburst finish and smaller headstock, but the body shape, body size and three-piece neck, among other details, were just regular production. It appears that Gibson still didn't understand the demand for an accurate reissue, because Gibson accompanied the Heritage 80 with fancier versions: the Heritage 80 Elite, with an ebony fingerboard that had no relevance to the reissue market (although it did have a one-piece neck) and the Heritage 80 Award, with gold plated hardware that also had no relevance to the reissue market.
__________________
Old 03-16-2013, 05:24 PM   #8
axe4me
Senior Member
IMO, they're good.
I'm glad that guitars with these may have a higher price tag but, to me, it's another conversation piece.
Thank you for the info.
Old 03-16-2013, 06:07 PM   #9
sccloser
Senior Member
sccloser's Avatar
I do not see what the big deal is about them. I had them in my 1985 Les Paul Standard. They sounded good, but not enough that I would pay $300 for them, which is what a pair seem to go for on ebay. I think the 57's sound just as good IMO. I have a BB1 in the neck and a bb2 in the bridge of my LP and I actually like those better than the Tim Shaw's that I have. I think they are more of a conversation piece...something cool and not very common, but no holy grail or anything like that. If you can get a pair for $100 or so, I'd say go for it. $200 or more I would pass if all you are interested in is sound.
__________________
1983 Marshall JCM 800 4210 modified
1986 Marshall JCM 800 2205
1991 Marshall JCM 900 Mkiii 2500
2010 Marshall Class 5 Combo
JCM 800 Lead Series 1960b cab
JCM 900 Lead Series 1960a cab
1960 ax cab (greenbacks)
sccloser is offline   Reply With Quote
Old 03-21-2013, 08:27 AM   #10
axe4me
Senior Member
TS P/U's are one of those things like an 808 overdrive.
They're good but doesn't make me do back flips.
I guess with the right buyer, these toys make or break a deal.
To me, they're no biggie.
Old 03-21-2013, 02:51 PM   #11
stax
V.I.P. Member
stax's Avatar
Yeah, but in 1981 when I bought my first brand new Les Paul, these pickups were a pretty big deal! I think they are a much more convincing voiced PAF than BurstBuckers and a lot of other "PAF" replacement pickups. I'd rather have TS's or 57 Classics than just about any other pickup out there.
Old 03-21-2013, 05:34 PM   #12
axe4me
Senior Member
IMO, it like the emperor's new clothes.
Embossed T or dirty finger p/u's have a following too.
Just not me.
All my Norlin LP Std;s had stock p/u's replaced with Duncans.
At this stage of my life, I go with my ears and not with the new re-issue of an Edsel or the "find another" deals.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
