MarshallForum.com
Reply
Thread Tools Display Modes
Old 04-08-2009, 04:08 AM   #1
VintageTone
Epiphone So Cal 50w Vs Blackstar HT5-5w
i found these two amps, both in my price range
i like the epi because you can switch from 50 to 25 watts
but the blackstar sounds real good, whats your views??
Blackstar HT5-H - 5 Watt 2 Channel Valve Head Specifications:
* Innovative 5 Watt valve head
* 1xECC83 and 1x12BH7
* Unique push pull power amp design
* Award winning HT Pedal preamp
* Two footswitchable channels
* Enhanced tone controls
* Patent-Applied-For Infinite Shape Feature (ISF)
* Fully equipped for studio or practice
* Speaker emulated output with 1x12 or 4x12 voicing
* Effects loop with effects level switch
* Footswitch included
* Cool vintage styling
Epiphone So Cal 50 Guitar Head Specifications:
* Designed and engineered in the USA by Gibson
* 50W or 25W Class AB switchable
* All-tube circuitry
* 2 channels
* Solid state rectifier
* Presence control
* Contour knob and gain control for channel 2
* Tube-powered reverb
* Independent/interactive EQ switch
* Standby switch
* Shared 3-band EQ
* Master volume
* Dual 4 ohm, dual 8 ohm, and 16 ohm speaker outs
* 12AX7 preamp tubes with DC powered filaments
* EL34 power tubes
* Footswitch jack (switch not included)
* High-tension fuse
* 16-gauge bent and spot-welded chassis
* 11-ply plywood cab construction
* 26"W x 10-3/4"D x 10-3/4"H
* 42 lbs.
VintageTone is offline   Reply With Quote
Old 04-08-2009, 06:37 AM   #2
steelhorse
Senior Member
steelhorse's Avatar
Re: Epiphone So Cal 50w Vs Blackstar HT5-5w
Maybe this thread should be re-located in the other amps part of the forum?
__________________
www.ricojronline.com
760-956-6619
Garmopat Pedal Mods
I wouldn't mind hearing your head smash through a glass door. That would be cool..." luekmeyer
steelhorse is offline   Reply With Quote
Old 04-08-2009, 06:42 AM   #3
VintageTone
well i was going to but you get wayy
more responses on this part of the forum
compared to the other amps section
Old 04-08-2009, 06:53 AM   #4
Metallon
Senior Member
Metallon's Avatar
Send a message via MSN to Metallon Send a message via Skype™ to Metallon
Still doesn't belong here
Anyway, go with the amp that sounds the best. Also, the first amp is 5W, the other 25W-50W. Might want to consider what wattage you need :P
Metallon is offline   Reply With Quote
Old 04-08-2009, 06:54 AM   #5
steelhorse
Senior Member
steelhorse's Avatar
Maybe you should try the forums that are applicable to those amps?
You might get an even better response from actual users of the amps you're wondering about.
Or try Harmony Central to see what others are saying.
I just don't want to see the main forum become inundated with questions about other amps that have nothing to do with Marshall's.
__________________
760-956-6619
Garmopat Pedal Mods
Old 04-08-2009, 07:00 AM   #6
VintageTone
Sorry people,
ill try out Harmony Central Thanks!
Old 04-08-2009, 07:49 AM   #7
Vintager12
Senior Member
Vintager12's Avatar
Try out the epiphone forum.
I think the epi is better but :
* 2 channels
* Presence control
* Standby switch
* Shared 3-band EQ
* Master volume
* EL34 power tubes
* High-tension fuse
* 42 lbs.
but... it has a solid state rectifier.
How old are you ? I need to know that because i need to know what tone you like.. but i think the so cal will be the best amp for you.
__________________
The Emperor of the Vintage Modern.
Vintager12 is offline   Reply With Quote
Old 04-08-2009, 01:48 PM   #8
VintageTone
Hey im 14 and play in a band
we play punky stuff
but at home i love to play
Good old G'n'R espically the
appetite stuff, but i also would
like good cleans, although there not a
priority i do like to change sounds abit
insted of sticking to the heavy stuff.
thanks!
Old 04-08-2009, 01:52 PM   #9
Vintager12
Senior Member
Vintager12's Avatar
Quote:
we play punky stuff
thanks!
Hmm... Well for your distortion tones the epi is good, and for your cleans and low dist's you need the blackstar.
__________________
Old 04-08-2009, 02:08 PM   #10
VintageTone
Well personally i think i can get
some nice cleans out of my mg
espically with my epi Lp with seymour duncs
so which amp would be favoirte for me
tone wise
and prtaciality (ie, volume, size)
Old 04-08-2009, 04:07 PM   #11
Vintager12
Senior Member
Vintager12's Avatar
tone wise
Well then go for the Epiphone.. that's more all round. The blackstar has better sound quality, but it's for good lower gain sound's , not for higher gain sound's
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
