MarshallForum.com
Go Back   MarshallForum.com > Music Gear > Guitars
Reply
Thread Tools Display Modes
Old 01-11-2013, 07:39 PM   #1
KISS NATION
Senior Member
KISS NATION's Avatar
Les Paul string height
can anyone tell me a reasonable string height for a Les Paul?
I found a guide that says the strings at the 12th fret should be 1.2mm on the high E and 2mm on the low E, currently my strings are 3.5mm on the high E and 3mm on the low E.
I know there is no such thing as a correct string height, but mine does feel a little on the high side.
would it be a good idea to lower the strings according to the guide I have found, or is there a better guide for string height?
__________________
There are only two tragedies in life. one is not getting what one wants, and the other is getting it.
KISS NATION is offline   Reply With Quote
Old 01-11-2013, 08:37 PM   #2
pedecamp
Senior Member
pedecamp's Avatar
Re: Les Paul string height
I set my LP and every other guitar 1/16" gap at the 12th fret.
__________________
JCM800 2204
pedecamp is offline   Reply With Quote
Old 01-11-2013, 10:27 PM   #3
mickeydg5
V.I.P. Member
mickeydg5's Avatar
I believe the 1.2mm high and 2.0mm low is typical specification for Les Pauls.
I do not even have 3.5mm on the low side of my acoustic.
mickeydg5 is offline   Reply With Quote
Old 01-11-2013, 11:15 PM   #4
GuitarBuilder
Senior Member
GuitarBuilder's Avatar
Straight from Gibson:
Hi I'm David the final inspector at Gibson Memphis. I can give you the factory spec info. on our setups. You will need a mechanics rule to do this properly.
To check neck relief: fret the low E at the first and 15th fret (not 12th) reach to the 7th fret and tap string. There should be a small space between string and fret - no thicker than a piece of paper. Do the same with the high E. ACTION: fret low E at first fret and measure the distance from the bottom of the to the top of the 15th fret. It should be 5/64". Do the same with the high E, measurement should be 3/64". Now measure the string height at the nut; underside of the string to the top of the fret. Low E and A should measure 2/64", D and G =1.5/64" and B and high E = 1/64". If string height at nut is correct, recheck string height at 12th fret with strings open. Measurement for low and high E's should be the same as measurement taken at the 15th.
Pickups: Fret low E at 22nd fret and measure pickup height from underside of string to point on pickup closest to string. Bridge pickup should be 3/64" (I think the 3/64" is a typo, it should be 3/32") , neck pickup should be 4/32". Fret high E at 22nd fret, distance for both pickups should be 3/32".
Play test: Play every string at every fret checking for buzzes. Bend High E string 1 and 1/2 steps, beginning at the sixth fret and ending at 22nd, checking for "choking" and to make sure string stays in nut notch.
__________________
Marshall 6100LM - 1960A/G12T-75
Marshall JVM205H - 1960A/G12T-75
Marshall Class 5 - 1965A/G10L-35
Marshall JTM-1H - 2061CX/G12H30
Marshall JMP-1H - 2061CX/G12M20
Marshall JCM-1H - 1936/Vintage 30
Marshall DSL-1H - 1936/G12T-75
Custom Rockman Stage Head with a Gazillion Rockmodules (I build these - PM me if you're interested)
Rockman Superhead 100W
Custom ADA MP-1, MP-1C, MP-2 Stage Head
Line 6 POD HD500
Roland GR-20
Lots of Les Paul's and Strats
GuitarBuilder is offline   Reply With Quote
Old 01-12-2013, 04:43 AM   #5
Roadburn
Senior Member
I do think it's about time companies like Gibson would start using the metric system....
Birma, Liberia and the U.S. are the only countries in the world who still use empiric
wtf is an inch???
__________________
"Hey Roadburn, you are out of tune"
"No way, I' m playing micro-tones!!!"
Roadburn is offline   Reply With Quote
Old 01-12-2013, 04:46 AM   #6
mickeydg5
V.I.P. Member
mickeydg5's Avatar
An inch is 25.4mm.
Old 01-12-2013, 05:05 AM   #7
diesect20022000
V.I.P. Member
diesect20022000's Avatar
my SG's set at .6mm to .4 but it needs a slight adjustment. i keep mine LOW generaly .4mm low e (fret board to bottom of the string without fretting anything) but they have to have perfect frets for it. all of mine are in the .4-.6mm territory though depending on when i set them up. the SG is due.
Old 01-12-2013, 06:03 AM   #8
Stringjunkie
Senior Member
Stringjunkie's Avatar
WTF is a MM? Lol
__________________
EVH 5150 III 50w 1/2 stack
Sourmash 1x12/WGS Reaper
Sourmash 1x12/WGS Retro 30
Ibanez RG- MHD pups
Gibson LP 50s tribute studio-490r/498t
Gibson V-dirty fingers
"My point is if you are legit then there is no reason to clear anything to anyone. Do not bother."
Mickeydg5
Stringjunkie is online now   Reply With Quote
Old 01-12-2013, 08:16 AM   #9
Georgiatec
V.I.P. Member
Georgiatec's Avatar
Thanks for that David. I will use this as a starting point. I've found over the years (especially with older guitars) that a bit of adjustment from factory settings is possible. I like the action as low as possible without any nasty chokes or buzzes. I've just bought a new Les Paul so it will be interesting how much is "left on the bone" from factory settings.
__________________
JCM2000 DSL100
VINTAGE MODERN 2466 WITH 425 A & B CABS
2061x
SL-5, CLASS 5 Mk 1.
JMP1c & JCM1H.....BADCAT UNLEASH
JMD50
1960B, MX212, 1922 & VS112 CABS
1983 FENDER TWIN REVERB II
1978 PEAVEY CLASSIC 212 COMBO
GIBSON LES PAULS....R7, R8, R9, R0, '04 CLASSIC & '12 TRAD. PREMIUM
'00 FENDER USA STANDARD TELECASTER
FENDER MODERN PLAYER TELE+
'94 FENDER MIJ '62 RI FOTOFLAME STRAT.
'99 FENDER USA STANDARD STRATOCASTER
Georgiatec is online now   Reply With Quote
Old 01-12-2013, 09:47 AM   #10
Vmodder
Senior Member
I've found that my Lp's also need some relief in the neck to get a good low, buzz free action.
Vmodder is offline   Reply With Quote
Old 01-12-2013, 11:03 AM   #11
KISS NATION
Senior Member
Thanks for the help guys. I have thought for a while that something doesn't quite feel right. it wasn't until I replaced my strings the other day when I noticed how high the strings were.
__________________
Old 01-12-2013, 11:09 AM   #12
TwinACStacks
Senior Member
TwinACStacks's Avatar
Plus, if you REALLY want to play around with it, a lot of the Buzz you can hear with it unplugged cannot be heard with it plugged in. The check for TOO Low is bending a string up past the 12th fret. If it doesn't choke out, even though you may hear buzz, with it unplugged, you are good to go.
Lower away.
TWIN
__________________
Quote:
Originally Posted by triftstrassa View Post
Are you retarted?
Quote: longfxukxnhair
I knew they were wrong. I can find my ass with both hands
Jm D1 Trusted by more musicians than Fed Ex
Want to make GOD laugh? Tell him about your plans.
TwinACStacks is offline   Reply With Quote
Old 01-12-2013, 11:12 AM   #13
TwinACStacks
Senior Member
Quote:
Originally Posted by mickeydg5 View Post
An inch is 25.4mm.
So I'm taking it is if your action is 25.4mm, then you are set a Tad high?
Just throw on some 15 Gauge Strings and SRV would be proud....
TWIN
__________________
Are you retarted?
Old 01-12-2013, 11:14 AM   #14
TwinACStacks
Senior Member
double post
TWIN
__________________
Are you retarted?
Old 01-12-2013, 11:16 AM   #15
TwinACStacks
Senior Member
Quote:
.010 at the 9th fret holding the string down at the 1st and 14th frets. According to Gibson Manual. Fender says @ 7th and 1st and 15th.
TWIN
__________________
Are you retarted?
Old 01-12-2013, 11:43 AM   #16
mickeydg5
V.I.P. Member
mickeydg5's Avatar
TWIN
Nah man, 25.4 action is for when I use wire rope and tune down 18 steps.
Old 01-12-2013, 11:45 AM   #17
mickeydg5
V.I.P. Member
mickeydg5's Avatar
All this sounds like SHREDDER talk.
Old 01-12-2013, 01:04 PM   #18
Vmodder
Senior Member
TWIN
That's a good baseline to go by. Here in the NW I have to check/adjust my necks twice a year. You are also correct about hearing the buzzing unplugged better.
The best gear investment I have done was to get a basic setup kit from Stew-Mac. Big time saver when you have a lot of guitars....
STEWMAC.COM : Basic Setup Kit
Old 01-12-2013, 01:30 PM   #19
KISS NATION
Senior Member
That seems like a good thing to buy. I don't think it would be currently worth it for the replica guitars I have though. but when the day comes that I can afford a real les paul and a real fender strat, that will be one of the things on my shopping list.
a friend also suggested I buy a gibson and fender tool kit, which would be nice but I already have all the tools I need to adjust everything on both guitars.
__________________
Old 01-12-2013, 01:38 PM   #20
Vmodder
Senior Member
If you ever start modding or building guitars it is almost a must. They come in metric too you know.
Old 01-12-2013, 01:52 PM   #21
Nudge68
Senior Member
Nudge68's Avatar
Knowing how to setup a guitar is just as important as knowing how to restring and tune it
Get a capo, feeler gauge and mm ruler and you're good to go.
Start with factory specs, then tweak from there. None of my guitars are setup exactly the same. I go for a trade off between feel, string gauge, buss and intonation.
Go to Stewmac for the tools and you'll never look back Oh, being patient help as it can take DAYS get get the setup you feel is juuuuust right.
Cheers,
Matt
Nudge68 is offline   Reply With Quote
Old 01-12-2013, 01:55 PM   #22
KISS NATION
Senior Member
I have never felt the need to change my guitar from it's factory set up.
most people might think they can make a difference by tweaking string and pick up height, but my guitars have everything set up as they were when they left the factory and that is just fine for me.
I'm not sure I would ever like to modify or build my own guitar. not that I couldn't of course, building it would be fine, but the electrics might be a little beyond me. I'm not very good when it comes to soldering electrics.
__________________
Old 01-12-2013, 02:52 PM   #23
TwinACStacks
Senior Member
I use an Automotive Feeler Gauge set for checking relief, My Luthier for my Nut heights and Fretwork, and corresponding size NEW DRILL BITS (Shank end) for String and Pickup heights. Works like a champ....
TWIN
__________________
Are you retarted?
Old 01-12-2013, 04:01 PM   #24
KISS NATION
Senior Member
I use an Automotive Feeler Gauge set for checking relief, My Luthier for my Nut heights and Fretwork, and corresponding size DRILL BITS (Shank end) for String and Pickup heights. Works like a champ....
TWIN
you must know your luthier very well if you let him check your nut height.
__________________
Old 01-12-2013, 05:29 PM   #25
TwinACStacks
Senior Member
We're this close.
Don't worry. I'm not going to tell you about nutslots....
TWIN
__________________
Are you retarted?
Old 01-12-2013, 06:06 PM   #26
Wycked Lester
Senior Member
Wycked Lester's Avatar
these here Stewart MacDonald string height guages are the cats ass for adjusting the actions,... they come in metric and regular ole usa.. Highly Recommend.
__________________
I have a bunch of amps and guitars...
My favorite head ever - 2203
Second favorite head - Jubilee
My #1 Guitar - 98 Custom Shop Jackson Soloist-Mike Shannon Built
My #2 Guitar - 1982 Les Paul Std.
I dig blues and metal.
"IF IT'S TOO LOUD, YOUR TOO CLOSE"
Quote:
Originally Posted by Fretboard View Post
Personally, I'd never get another person's signature guitar, amp, etc. So, I'd go with the Jackson. I'm planning on getting an RR-1.
Wycked Lester is offline   Reply With Quote
Old 01-12-2013, 06:41 PM   #27
RussBert
Senior Member
RussBert's Avatar
Quote:
Are your numbers right? Is that a typo?
That's around 1/64" is real speak (.016" to .024") and when you fret at the first fret...your string height drops even more!
RussBert is offline   Reply With Quote
Old 01-12-2013, 08:21 PM   #28
Vinsanitizer
V.I.P. Member
Vinsanitizer's Avatar
*Adjust the truss rod first, then:
E = 5/64 @ 12th fret
e = 4/64 @ 12th fret
Thou shalt find thy satisfaction inst the fulfillment thereof.
Vinsanitizer is offline   Reply With Quote
Old 01-13-2013, 04:30 AM   #29
Roadburn
Senior Member
Quote:
Thanks Wycked.
That is a usefull piece of kit. Not just for guitars.
Must get me one, pronto!
__________________
Old 01-13-2013, 06:58 AM   #30
Stringjunkie
Senior Member
They are very helpful. I have the standard and metric versions
__________________
Ibanez RG- MHD pups
Mickeydg5
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
