MarshallForum.com
Reply
Thread Tools Display Modes
Old 11-03-2012, 09:16 PM   #1
J. Burns
Three amps, same problem.
I now have THREE, count 'em: THREE amps (1968 Fender Bassman, 1979 Park 1207, 2004 Soldano Avenger) that don't work and have the exact same problem (low-to-non-existent output).
It is HIGHLY suspicious that all three amps would have the EXACT same problem at the same time.
I've tried running through different speaker cabinets, I've tried switching pre-amp tubes, I've tried switching IEC cables, I've tried switching speaker cables, I've tried switching instrument cables, I've tried switching fuses, I've tried switching outlets.
Is the power in my house killing the amps? That's the only thing I can think of.
__________________
Amps:
1979 Park/Marshall 2203
If it has more than ten knobs, I'm not interested.
J. Burns is offline   Reply With Quote
Old 11-04-2012, 01:20 AM   #2
mickeydg5
V.I.P. Member
mickeydg5's Avatar
Re: Three amps, same problem.
Did you try moving to a different supply circuit in your home or wherever?
Is there a common surge protector or power conditioner involved?
mickeydg5 is online now   Reply With Quote
Old 11-04-2012, 03:11 AM   #3
thenakedcorninferno
Junior Member
This is probably a dumb question, but did you try switching guitars?
thenakedcorninferno is offline   Reply With Quote
Old 11-04-2012, 05:01 AM   #4
blues_n_cues
V.I.P. Member
blues_n_cues's Avatar
Quote:
this.
__________________
LIFE,LIBERTY,& the pursuit of TONE.
2007 Epi LP Custom LTD.
1991 Jackson DK-2 HSS
2010 Austin LP GT w/ P90s
custom rebuilt Washburn BT-2 Maverick
Marshall JMP-1 (rack)
Marshall CODE 100 (eventually) lol
a bunch of other carp
my music,sounds,samples,& snippets-
http://www.reverbnation.com/rlcltd
https://soundcloud.com/rlc-ltd
Stratisfied
https://soundcloud.com/rlc-ltd/stratisfied
just riffing
https://soundcloud.com/rlc-ltd/just-riffage
blues_n_cues is offline   Reply With Quote
Old 11-04-2012, 09:27 AM   #5
Ken
Senior Member
Ken's Avatar
Are the amps in need or repair, i.e. there is a fried component, or do they just stop working in a particular outlet or group of outlets in your house. Did you try an outlet on a diffent fuse/circuit breaker? Does anything else work in the outlet, like a stereo or lamp? Can you measure your wall voltage without killing yourself?
When 3 different amps all die the same way, it's not the amps independently. You need to find out what's wrong with the amps and maybe call a qualified electrician to check out your house if the amps are indeed damaged.
Ken
__________________
1999 Marshall DSL 50
Late 1970's (?) Fender Champ
Marshall battery amp
PRO 4x12 from the 1970's
Woodson 2x12
1976 Les Paul Standard
Epiphone Les Paul knockoff
ESP Lawsuit Explorer
1979 Chiquita Travel Guitar
1995 Taylor 310
Ken is offline   Reply With Quote
Old 11-04-2012, 09:31 AM   #6
Micky
V.I.P. Member
Micky's Avatar
Quote:
Ken
__________________
Stupidity should be painful...
Marshall MHZ15, DSL40c, DSL5c, M4, 4X12 full stack, Gibson LP, VOX, Eminence, Celestion, Ovation, Fender & more...
Micky is online now   Reply With Quote
Old 11-04-2012, 12:59 PM   #7
J. Burns
Yes, I tried different guitars. In most cases, not even getting any amp hum through the speakers.
I tested all of the outlets in the basement with a multimeter, this is what I came up with:
One outlet is steadily oscillating between 116-124.
One outlet holding steady at 120.
One outlet bouncing back and forth anywhere between 114-128.
One outlet that reads a somewhat steady 119, but has spikes up to 400 and will occasionally drop down to zero.
Obviously I need to get an electrician down there, but knowing my landlords, that could take several months. It took them nearly three years to get them to re-shingle the roof!
Might lug the heads and a cabinet upstairs to test on a different circuit, but not looking forward to it.
Thanks all.
__________________
Amps:
Old 11-04-2012, 01:15 PM   #8
blues_n_cues
V.I.P. Member
[QUOTE=J. Burns;734716]
QUOTE]
as in 400v ac???
that sounds like your problem right there.
__________________
Stratisfied
just riffing
Old 11-04-2012, 01:24 PM   #9
J. Burns
I am going to discontinue use of that particular outlet until I have an electrician check out the basement.
Now I just have to figure out what to do with these amps. "Take it to a tech" is the simple answer, but most techs in Seattle will charge an arm and a leg for spotty work that they'll make you wait several months for.
__________________
Amps:
Old 11-04-2012, 01:29 PM   #10
blues_n_cues
V.I.P. Member
an old tv/radio repairman w/ the right schematics might be able to help you.
there's always the old acoustic guitar.
__________________
Stratisfied
just riffing
Old 11-04-2012, 01:35 PM   #11
J. Burns
Quote:
NOOOOOOOOOOO!!!!!!!!!!!
__________________
Amps:
Old 11-04-2012, 02:06 PM   #12
diesect20022000
V.I.P. Member
diesect20022000's Avatar
I'd also check those cabs impedances to make sure they're running within range. you may well be runing an open ground or something and frying your OT's. i don't KNOW that obviously but something's clearly not right here.
Old 11-04-2012, 02:08 PM   #13
diesect20022000
V.I.P. Member
you can get a coltage tester for $10 at your local hardware store. it plus in like any device and just shows you a light that will indicate wether it's an open ground or not.
i have ONE outlet in my WHOLE house that's an open ground. i only plug window fans in that one and that's only when i'm in the room.
Old 11-05-2012, 06:50 AM   #14
blues_n_cues
V.I.P. Member
time to ground that thing.
__________________
Stratisfied
just riffing
Old 11-05-2012, 07:22 AM   #15
Wycked Lester
Senior Member
Wycked Lester's Avatar
extention cords are your friends.
__________________
I have a bunch of amps and guitars...
My favorite head ever - 2203
Second favorite head - Jubilee
My #1 Guitar - 98 Custom Shop Jackson Soloist-Mike Shannon Built
My #2 Guitar - 1982 Les Paul Std.
I dig blues and metal.
"IF IT'S TOO LOUD, YOUR TOO CLOSE"
Quote:
Originally Posted by Fretboard View Post
Personally, I'd never get another person's signature guitar, amp, etc. So, I'd go with the Jackson. I'm planning on getting an RR-1.
Wycked Lester is offline   Reply With Quote
Old 11-05-2012, 03:27 PM   #16
J. Burns
I've heard that running one's amplifier off of an excessively long extension cord is bad news. Anyone confirm/deny?
__________________
Amps:
Old 11-05-2012, 03:41 PM   #17
Ken
Senior Member
Ken's Avatar
You have to use good quality cords if you run long distances. I have the orange outdoor types that are rated for heavy duty use. I've never had a problem.
You can use a regular lamp type indoor cord just fine, but I wouldn't connect a bunch together...although I'd think it would be okay if it's just one amp on the other end. Most can carry lots more amps than you need.
Ken
__________________
Woodson 2x12
1995 Taylor 310
Old 11-09-2012, 04:05 AM   #18
Maynar
Maynar's Avatar
I've run orange outdoor cords with no probs in the past but as we all know, the more copper cable the more resistance, the less juice at the end where you need it.
Higher gauge, longer length = more resistance. Something to take note.
JMHO.
Maynar is offline   Reply With Quote
Old 11-09-2012, 04:33 AM   #19
NewReligion
V.I.P. Member
NewReligion's Avatar
So is it a fact that these amps stopped working correctly When/During/After you drew power from the outlet that peaked at 400V?
N R
__________________
I DON"T HAVE TIME FOR THIS
Cameron/Friedman/Marshall/Hopkins DH 50 Amps.
NEW RELIGION Download $5.95 @ CD Baby http://www.cdbaby.com/cd/davidchopkins
NewReligion is offline   Reply With Quote
Old 11-09-2012, 11:30 AM   #20
Wilder Amplification
Senior Member
Wilder Amplification's Avatar
If you're gonna use extension cords of 200' or more, make sure you're using one rated at 12AWG or lower.
__________________
Jon Wilder
http://www.wilderamps.com
Old 11-12-2012, 12:14 AM   #21
J. Burns
Quote:
N R
All three amps failed at different times, but have the same issue. Not sure if the failures are 100% linked to the outlet quite yet, but that's the outlet that's on the right side of the drum kit, so it's the one I've used most often in rehearsals with all three amps.
I left the Park with a tech-savvy friend (he builds amps as a side business) who is going to take a look at it at his leisure. If he can't figure it out, then it's off to the shop, which is a bummer because in nearly 20 years of playing, I've yet to have anything more than a halfway-decent experience with any amp tech in the region.
__________________
Amps:
Old 11-12-2012, 12:47 AM   #22
mickeydg5
V.I.P. Member
mickeydg5's Avatar
J. Bursns
I was wondering if any new information, questions and answers would surface.
Where is your home and basement? Is it in a commercial or industrial building of some sort.
I mean how are you getting 400+ VAC at a residential type outlet? Double check to be sure you actually saw 400VAC.
There is something going on with the utility service types there if that is the case which your landlord is not disclosing, not marking and is responsible for with your interest. You may want to get your own electrician to look things over and give a report with recommendations.
Bottom line is your landlord is responsible for the utilities at the dwelling and I hope you can work things out sensibly with him if it is due to an eletrical supply problem.
Old 11-12-2012, 01:34 AM   #23
J. Burns
It's a house in a residential area. I definitely was seeing spikes up to 400 and the voltage dipping down to 0, but it may be possible that I wasn't measuring correctly. That said, every other outlet I tested got more predictable results. It's an old house with old wiring, so anomalies are definitely possible. (It's also possible that the house is haunted, but that's another thread for another forum.)
I am going to be sending the landlord a message about this to try to get the power situation resolved. In a perfect world, I would be able to get them to help with the amp tech bill as well.
__________________
Amps:
Old 11-12-2012, 06:07 AM   #24
RickyLee
V.I.P. Member
RickyLee's Avatar
I have seen extreme voltages that did not make sense, but they were due to what I was REFERENCING the Hot side to. In that case I was referencing individual legs of 3 phase 480VAC to Ground. Only problem , was the service company did not have this feed Grounded. Each leg of this 480VAC measured correctly from phase to phase, just not to Ground.
So . . .
I need to ask, how were you measuring your wall voltage?
RickyLee is offline   Reply With Quote
Old 11-12-2012, 06:30 AM   #25
Guitar-Rocker
Senior Member
Guitar-Rocker's Avatar
Two items maybe worth mentioning. The hill billy rule of thumb for extension cords is 100 ft with marginal voltage loss, and the larger the cord wires, the less loss (#12 versus #18).
We had a control transformer go bad on a unit heater at work that drove 292V to ground through the rest of that circuit, burnt up everything. Was a nightmare to figure out. And that was on a standard panel of 208/120 volts.
Guitar-Rocker is offline   Reply With Quote
Old 11-12-2012, 11:01 AM   #26
RiverRatt
V.I.P. Member
RiverRatt's Avatar
Quick questions regarding the fuses: Do you mean you replaced the fuse on the circuit the outlets are on, or the fuses in the amps? Did you check the fuses with a multimeter for continuity? Your problem sounds like the HT fuses did their job and blew. You will still get power, everything lights up, but you get either no sound at all or maybe a whisper of sound. If you replaced the fuses but used that same circuit, they might have blown again as soon as you took the amps off standby.
I'm not trying to insult your intelligence or anything like that. I just didn't see where you elaborated on the fuses at all and they are the first place I'd look to check for problems. You may only have access to the mains fuse from the outside of the chassis. You may have to open them up to get to the HT fuse depending on the amp.
__________________
Quote:
Originally Posted by MartyStrat54 View Post
That's what I like about you Alan...you got it bad. You're a tube-aholic.
Quote:
Originally Posted by dreyn77 View Post
IT's JUST A MAGNET AND A WIRE!!!!!!!!!!!!!! GET OVER IT!!!!! BIG DEAL!!!!!!!! WOOHIPY!!!!!!!!
RiverRatt is offline   Reply With Quote
Old 11-12-2012, 09:19 PM   #27
J. Burns
Yep, the HT fuse is what I was referring to.
__________________
Amps:
Old 11-13-2012, 05:00 AM   #28
capnpat
capnpat's Avatar
Thanks all.
A UPS would give you a steady supply, no drops or spikes.
capnpat is offline   Reply With Quote
Old 11-13-2012, 05:05 AM   #29
capnpat
capnpat's Avatar
Here in Florida, lightening strikes and power outages are common. I keep everything in my home on either UPS or surge protector. Open up your amps and look for burned components. That would be a good start to solving your problem.
Old 11-13-2012, 03:07 PM   #30
Rockbert
Senior Member
Rockbert's Avatar
Quote:
Not unless you paid a ****load of money for it.
Consumer grade UPS's are mostly standby type which means that it just uses the wall power until power goes out and then it quickly switches to the battery. And even on battery the inverter output is probably ugly, more like a saw than a sine wave, not what you would want to run an amp on. But with normal wall power it's no different than a cheap surge protector.
High end UPS's like we use in server rooms are the online double conversion type, which means power always comes from the rectifier-inverter circuit. These have a stable voltage output and probably a cleaner sine wave but they cost more than your amp...
Rockbert is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
