MarshallForum.com
Reply
Thread Tools Display Modes
Old 10-28-2012, 03:09 PM   #1
DirtySteve
V.I.P. Member
DirtySteve's Avatar
New DSL40 tube layout?
I apologize in advance for the noob questions, but I just stepped up from a Class 5 and I can't find any of this info on the new DSLs. I kind of need a quick lesson. I'm not a total idiot about this, but I don't want to take any chances.
I was just about to roll a couple of NOS preamp tubes in V1 & 2 in my new dsl40c when it dawned on me that I don't know what all these tubes are for and if I might screw something up if I put a wrong tube type in the wrong position. It's my first amp with more than 3 pres.
Can anyone give me a rundown of what the preamps are? I assume V1 is closest to the input like any other amp? What are V3 and V4? I also assume V4 is the PI?...or am I way off?
It also just occurred to me that I probably have to re bias if I swap power tubes????
Any info at all in this department is much appreciated!
edit: I have some pix, but I can't download them to my computer at home, I'll post them if I need to in the am.
__________________
I wish I could give you a '****' for that...
Quote:
Originally Posted by Swede View Post
Lot of very NOT rock n roll folks here....
DirtySteve is offline   Reply With Quote
Old 10-28-2012, 06:07 PM   #2
Dogs of Doom
Super Moderator
Dogs of Doom's Avatar
Re: New DSL40 tube layout?
Funny how google images refers back to this forum...
Looks like the front row from right to left V1-V3 & the PI far left in front of the 4 power tubes...
Typical is following the path from the input socket to the power section.
__________________
My 2...
Dogs of Doom is online now   Reply With Quote
Old 10-28-2012, 07:11 PM   #3
DirtySteve
V.I.P. Member
DirtySteve's Avatar
Yes, but I'm talking about the new one that was just released. The tube layout is different than that in mine. I'll post photos in the morning. There are 4 preamp tubes in mine and 2 power tubes.
__________________
Old 10-28-2012, 07:41 PM   #4
big dooley
V.I.P. Member
big dooley's Avatar
V1 and V2 are the gain stages,
V3 is the last gain stage and cathode follower
V4 is the PI
__________________
JVM, the only marshall that's been modded to tame it, instead of hotrodding it
big dooley is offline   Reply With Quote
Old 10-28-2012, 07:59 PM   #5
DirtySteve
V.I.P. Member
DirtySteve's Avatar
Thanks Dooley, that helps. ...and V1 is closest the input? Are there certain tubes that shouldn't be used in the Cathode follower? I've read that somewhere before and I want to be sure...and what's a good PI tube? The last time I had a PI was in my PV classic 50 and the Sovtek LPS was highly recommended on the PV forum.
I guess I have to open her up after all if I want to swap el34s, and I think I want to check the bias anyway. Where can I find out what it should be set at?
__________________
Old 10-28-2012, 08:02 PM   #6
DirtySteve
V.I.P. Member
DirtySteve's Avatar
Sorry, I must have misread your post earlier. So V1 is closest to the input just like normal and the 4th pre is indeed the PI. Thanks man.
__________________
Old 10-28-2012, 08:07 PM   #7
big dooley
V.I.P. Member
big dooley's Avatar
i'm not sure about these new series,
but i avoid anything from new sensor like the plague for the cathode followers (in truth i avoid them anyway, but that's personal preference)
as for other positions that's up to you... happy experimenting
as for bias, just stay under 70% of max plate dissipation
__________________
Old 10-28-2012, 08:09 PM   #8
Dogs of Doom
Super Moderator
No worries... I figured there might be a little differences between the models, but by looking at the image, you should be able to figure it out.
I posted some other pic's in the other thread too. Maybe not identical, but should give clues to what to look for when you take it apart.
__________________
My 2...
Old 10-28-2012, 08:24 PM   #9
DirtySteve
V.I.P. Member
DirtySteve's Avatar
Forgive my ignorance, but how do I know what 70% of max plate dissipation is? I'm learning here...
Thanks guys. I really only want to swap V1 & 2 right now and check the bias, I might swap in some GT EL34Ms I have, but I'm more concerned with the pres right now. I wanted to know what the other ones are for too just in case I get froggy and want to go further. I have a bunch of NOS pres sitting here all laid out.
__________________
Old 10-28-2012, 08:41 PM   #10
Dogs of Doom
Super Moderator
The problem is it's very subjective. Not only that, but you can have a recipe that works in one DSL & sound muddy, or flat in another.
As a matter of fact, I swapped out the stock tube in my JMP-1 for the 1st time not too long ago. I put a Genalex Gold Lion in & it sounded more Marshally goodness than ever before (not to say it didn't sound Marshally to begin w/). Now though, using it w/ different amps & using the JMP-1 through the EL34, it's not doing what I liked about it in the 1st place so much.
Using the JMP-1 direct into a board, through the speaker emulators, it kills. Through the direct outputs into either my Ampeg VL, or the EL34, it gets muddy & loses clarity in the mids.
You'll have to swap out #1 w/ just about everything you've got to see what you like best. Then go on to the rest of the stages.
__________________
My 2...
Old 10-28-2012, 08:56 PM   #11
big dooley
V.I.P. Member
big dooley's Avatar
Quote:
by measuring plate voltage and the voltage on the testpoints and do a little calculation...
you don't want to exceed 70% of 40 watt (20 watt per tube) on idle
__________________
Old 10-29-2012, 02:18 PM   #12
DirtySteve
V.I.P. Member
DirtySteve's Avatar
Thanks guys. After watching tube biasing videos all morning I think I'm in a little over my head, I'm just going to leave the power tubes alone for right now. I'm only going to mess with V1 & maybe V2. I don't think I need to get into anything else just yet.
__________________
Old 10-30-2012, 10:53 AM   #13
shades of blue
Senior Member
shades of blue's Avatar
Same here...I think I put my tubes in backwards! I though the tube with the cover was the PI, and I went backwards considering V1 the furthest from the jack...
I wish Marshall put a tube layout in their manual like Mesa, Egnater, and all other amp manufacturers! Their manuals are for crap.
shades of blue is offline   Reply With Quote
Old 10-30-2012, 11:01 AM   #14
Rocktane
Senior Member
Rocktane's Avatar
The PCB has markings for all the preamp tubes
Rocktane is online now   Reply With Quote
Old 10-30-2012, 11:10 AM   #15
shades of blue
Senior Member
Quote:
do i have to remove the chassis from the cabinet to see them? Sorry just not familiar with Marshall amps.
Old 10-30-2012, 11:16 AM   #16
DirtySteve
V.I.P. Member
DirtySteve's Avatar
You do, but I don't think you need to. V1 is closest to the input. I only swapped V1 and 2 and difference was huge, so I'm pretty sure of it. None of mine have a cover, but V1 does have a rubber ring on it.
__________________
Old 10-30-2012, 11:28 AM   #17
Rocktane
Senior Member
Rocktane's Avatar
Correct. And they are in order as well. V1 in the 100H has a cover.
Old 10-30-2012, 11:50 AM   #18
shades of blue
Senior Member
Thanks! The thing that was throwing me off is that the power tubes on the new DSL100 are not in line with the preamp tubes. The power tubes sit directly behind the preamp tubes.
Like this
not my pic!
Old 10-30-2012, 11:55 AM   #19
Stringjunkie
Senior Member
Stringjunkie's Avatar
That's purdy!
__________________
EVH 5150 III 50w 1/2 stack
Sourmash 1x12/WGS Reaper
Sourmash 1x12/WGS Retro 30
Ibanez RG- MHD pups
Gibson LP 50s tribute studio-490r/498t
Gibson V-dirty fingers
"My point is if you are legit then there is no reason to clear anything to anyone. Do not bother."
Mickeydg5
Stringjunkie is offline   Reply With Quote
Old 10-30-2012, 12:33 PM   #20
DirtySteve
V.I.P. Member
DirtySteve's Avatar
Remove the 2 outside power tubes, but leave the holes for the sockets and it's the 40w. It's the exact same chassis. I have pics of mine to post, but I can't do it from home and I didn't go to work today to do it there.
__________________
Old 10-30-2012, 12:43 PM   #21
Rocktane
Senior Member
Rocktane's Avatar
Yep same board. Transformers are different. I think the originals shared a board as well, at least that's what I've gathered from reading but I have no first hand knowledge.
Old 10-30-2012, 02:22 PM   #22
big dooley
V.I.P. Member
big dooley's Avatar
Quote:
Originally Posted by Stringjunkie View Post
That's purdy!
it is... the powertubes have more space in between them... great for people who want to try KT88's or 6550's without worrying about clearance
__________________
Old 10-30-2012, 03:25 PM   #23
DirtySteve
V.I.P. Member
DirtySteve's Avatar
...wish I hadn't seen that.
__________________
Old 10-30-2012, 04:33 PM   #24
shades of blue
Senior Member
hmmm....I didn't know this!!! SWEEEET
Old 10-30-2012, 04:40 PM   #25
Robert Arthur
Senior Member
Robert Arthur's Avatar
Would'nt a DSL40 have EL84's ? My dsl401 does...
__________________
JCM800 2203
JCM2000 DSL 401
JTM45 Combo Amp.
Class 5 head
various 1922, 1936, and 1960 cabs..
Robert Arthur is offline   Reply With Quote
Old 10-30-2012, 05:22 PM   #26
DirtySteve
V.I.P. Member
DirtySteve's Avatar
Quote:
No sir, the new ones have EL34s...like it should be!
__________________
Old 10-31-2012, 03:53 AM   #27
Lowlife
Senior Member
Lowlife's Avatar
I thought the DSL's had external bias measuring points, or that doesnt go for the combo? like this:
That should make it farily easy to get the necessary measurements
__________________
JVM 410H
(Mods: Compression reduction, gain reduction, 3rd stage bias, negative feedback, Plexi, OD2 -> JCM800, clean -> Blackface)
...into a JCM 900 1960A cab with G12-65's and G12T-75 in X-pattern
JCM1 combo
...into a Haze 15 cab with a G12T-75 speaker
Class 5 - modded
Valvestate VS8080
Gibson LP Standard Faded
Gibson LP 70'ies tribute
Epiphone Casino, John Lennon edn.
Fender stratocaster, Richie Sambora edn. (mex)
Kramer Custom Pacer II
Lowlife is offline   Reply With Quote
Old 10-31-2012, 09:06 AM   #28
DirtySteve
V.I.P. Member
DirtySteve's Avatar
The new ones are different, or at least the 40w is...
__________________
Old 10-31-2012, 09:49 AM   #29
Robert Arthur
Senior Member
Yes much different. The Dsl 401 has 4 el84's (which I like) and one gt-75 .That's why the used ones are going for as much as the new ones. Highly sought after for the compactness and versatility. The only complaint I have is that then effects loop is not very good in terms of it making much of a difference. It's better to front load the thing. But, I only use it at home and for sit ins. If theyn inproved the effects loop then I'm on board. Maybe even convert it to use some NOS Philco 6l6c (winged) I have circa 1950.
__________________
JCM800 2203
JCM2000 DSL 401
JTM45 Combo Amp.
Class 5 head
Old 10-31-2012, 09:56 AM   #30
Robert Arthur
Senior Member
I re-tubed my "Bluesbreaker" with kt88's at one time but it was an expensive proposition to find two matched tubes. But, in the case of that amp, I don't know why anyone would ever need drop d tuning for rich bottom end because the thing was earth-shattering and would get over my JCM800 Lead series H/S with ease. I went back to kt66 and it'a little glassier.
__________________
JCM800 2203
JCM2000 DSL 401
JTM45 Combo Amp.
Class 5 head
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
