MarshallForum.com
Reply
Thread Tools Display Modes
Old 10-06-2012, 11:16 AM   #1
Arthur
Arthur's Avatar
How to slave?
Hey Guys,
Getting a new amp tomorrow, which I already posted. And wanted to know how to "slave" it to my DSL.
Thanks
FYI the amp is a JMP1c.
__________________
'08 Epiphone G-400 Ebony
'09 Gibson Billie Joe Les Paul Junior Classic White
'11 Fender American Special Stratocaster Sunburst
'12 Gibson Les Paul Junior Special Satin Cherry
Marshall 50th Anniversary JMP Combo
Marshall DSL 401
Arthur is offline   Reply With Quote
Old 10-06-2012, 12:08 PM   #2
Username2
Banned
Re: How to slave?
Run a instrument cable for the 16 ohm speaker output into the FX return of the DSL. This will automatically disable the internal speaker. Be sure you set the JMP1 amp to low range (0.1 watt) so not to damage either amp.
Thats it really, adjust the JMP1 as you would any preamp and then use the master volume on the DSL.
Username2 is offline   Reply With Quote
Old 10-06-2012, 12:18 PM   #3
duncan11
Senior Member
duncan11's Avatar
Re: How to slave?
Pretty much it, and if you want to put fx in between it, just go from JMP1 into FX, then out of the FX into the loop return of the DSL, then affix the appopriate cab to the DSL and you're good to go.
__________________
"Well, it's one louder, isn't it? It's not ten. You see, most blokes, you know, will be playing at ten. You're on ten here, all the way up, all the way up, all the way up, you're on ten on your guitar. Where can you go from there? Where? NOWHERE!!!"
AFD100
YJM100
Class 5 combo
1986 Lead 12 Microstack
1960A
JCM900 1960A V30's
JCM900 1936
duncan11 is offline   Reply With Quote
Old 10-06-2012, 01:10 PM   #4
SmokeyDopey
V.I.P. Member
SmokeyDopey's Avatar
Re: How to slave?
By sword or by debt.
Or what nuke said.
SmokeyDopey is offline   Reply With Quote
Old 10-06-2012, 02:52 PM   #5
big dooley
V.I.P. Member
big dooley's Avatar
Re: How to slave?
be aware that the master volumes on DSL's are placed BEFORE the loop!!!
that means you're running the poweramp at full tilt...
__________________
JVM, the only marshall that's been modded to tame it, instead of hotrodding it
big dooley is offline   Reply With Quote
Old 10-06-2012, 04:29 PM   #6
metromutt
Senior Member
Re: How to slave?
Don't know about the jmp1 but with my valve amp I run a powerbrake set to load to protect the amp in one speaker out then in the other I run a line out box converting the signal to instrument level then send that into the front of my second amp. This is the best way to have both the pre and power section working as one. The only thing is you need to keep the second amp clean. A lot of guitarist have used power amps as the second amp because of their clean tone like the old mosfet HH amps.
I guess this new jmp1 doesn't need to see a load, is it a ss circuit or is it an inbuilt line out where only the pre amp section works? I've had a few amps with that feature but without the power section cooking it sounded too fizzy/buzz like.
metromutt is offline   Reply With Quote
Old 10-06-2012, 08:35 PM   #7
Arthur
Arthur's Avatar
Re: How to slave?
Thanks for the replies guys! But do I use a speaker cable or a guitar lead? Also is it safe to use this without a power break or is it likely that I will blow my amp?
__________________
Marshall DSL 401
Old 10-06-2012, 09:50 PM   #8
kamran
Senior Member
kamran's Avatar
Re: How to slave?
im not a hundred percent sure but since the signals so low as long as its in .1 watt mode an instrument cable should be fine. i feel like an unscreened (i think they are?) speaker cable would either not work or would sound awful or something. and which amp are you worrying about blowing? the jmp or DSL? you definitely wont blow the jmp by running it this way as it was suggested by the designers. the DSL on the other hand, you dont NEED a power break seeing as theres nothing wrong with diming an amp. as long as you have a properly rated cab. but its going to be loud as all **** and since dooley says that the Master on the DSL comes before the loop youll essentially have no way of controlling the volume, save for turning down the JMP which would decrease the signal to the jmp1 power section which means you wont get the power tube break up that probably drove you to buy the jmp1 in the first place. you should buy a volume pedal to place between the jmp and the DSL and that would act as your new DSL master volume, allowing you to crank your JMP and keep the DSL at whatever volume you wish.
like metromutt said you want the DSL power section running clean or else youll have your already distorted tone coming from the JMP being distorted even further (most likely in a very unmusical way)
__________________
____________________________________________
JVM210H
1959SLP Dookie mod
1985 Mosfet Lead 100
Marshall 1960A
Marshall 1960BX
Avatar G412B Vintage with Vintage 30's
Les Pauls n Strats
Victim of Society
http://www.facebook.com/pages/Victim...91497534209866
Quote:
Originally Posted by FFXIhealer View Post
That's why I didn't want to ask what tubes to get here. Everyone's biased.
kamran is offline   Reply With Quote
Old 10-06-2012, 10:32 PM   #9
Username2
Banned
Re: How to slave?
Use a instrument cable not a speaker cable. When these Marshall 1 watt amps are set to low range or .1watt the actual output is actually even lower then that ( about 0.022 watts)
Not every amp is a good candidate to be a slave amp. As Big Dooley pointed out the master volume is before the loop which will work but not the best setup. Other loops can be to hot to be slaved. Idealy you should use a amp that allows you to select the +4 dbu setting for the loop, the DSL does. Amps like the Vintage Modern, JVM, and the JMD1 are also excellent for this.
Old 10-06-2012, 10:55 PM   #10
Arthur
Arthur's Avatar
Re: How to slave?
OK, I think I'll give it a shot with a volume pedal. But my amp is a combo and kamran you said something about having a properly rated cab? And yeah I was asking about blowing the DSL.
__________________
Marshall DSL 401
Old 10-11-2012, 11:11 AM   #11
poeman33
Super Moderator
poeman33's Avatar
Re: How to slave?
I know the answer is over a week old...but I just read about this... You say the DSL allows you to select the +4dbu setting...what one is that? It just has a loop level switch...in or out...the manual doesn't give specs, just says basically one is better for pedals, and one for processors. Doesn't even say which position is for which. Did I mention that I have never used an effects loop in my life?
__________________
CSA (Certified Strat Addict)
Quote:
Originally Posted by EL 34 View Post
poeman33 is a midget busker champion of ****-town ontario so he knows everything.
https://soundcloud.com/poe-man-1/king-bee-no-eq
poeman33 is offline   Reply With Quote
Old 10-11-2012, 03:57 PM   #12
Ken
Senior Member
Ken's Avatar
Re: How to slave?
As many DSL's have the ground loop mod, be sure yours doesn't or the speaker out will not be disabled!!
PS - I just realized he has a combo so I'm not sure this applies, but others with a DSL head who want to slave it should keep this in mind.
Ken
__________________
1999 Marshall DSL 50
Late 1970's (?) Fender Champ
Marshall battery amp
PRO 4x12 from the 1970's
Woodson 2x12
1976 Les Paul Standard
Epiphone Les Paul knockoff
ESP Lawsuit Explorer
1979 Chiquita Travel Guitar
1995 Taylor 310
Ken is offline   Reply With Quote
Old 10-13-2012, 08:14 AM   #13
Brett Blackmore
Senior Member
Re: How to slave?
I do it like this with a DSL and Plexi:
Guitar > DSL input > DSL send > stereo fx-unit @+4bd >
Left channel -> DSL Return (set to +4db)
Right channel -> Marshall Plexi fx-loop return (which can only do +4db)>
So I am hi-jacking the Plexi thru its fx-loop return which cuts out all of its preamp/eq/and channel inputs - they now do nothing on the Plexi- only the Presence works.
Thru a coincidence I have a wet/dry fx-mix knob on my Plexi which now governs the volume for the plexi. If I would not have this then the DSL volume would govern volume on the plexi.
On the DSL the FX loop switch is either +4db or -10db. When pressed in the switch is set to +4db which is used for rack mounted effects. The button pressed OUT is for normal instrument levels at -10db
ps. last note: in my humble opinion if you are using different types of cabs - or are sending signals from different types of tubes eg. el34 amp to a 6550 amp then the slaved amp (in my case my Plexi) gets the full DSL sound yet stops sounding like a Plexi - This is strange for me as a Plexi fan. The new sound is somewhat full, loud, but loses something which is difficult to describe - the slaved amp now sounds like any xyz china-made Peavey. I therefore would only recommend slaving identical types or avoid it. Use a stereo delay pedal to send 2 signals into 2 amps and forget the slaving - to me this sounds best of all.
Cheers Brett
Brett Blackmore is offline   Reply With Quote
Old 10-13-2012, 09:40 AM   #14
Username2
Banned
Re: How to slave?
Quote:
The +4 dBu should be selected on the Slave Amps loop if equipped . If using a DSL1 to slave into a higher watt amp **** using the FX send on the DSL1 to slave, use the speaker output instead in the .1 watt mode so you take advantage of the preamp and power amp of the DSL1.
It is the cascading power amps where the magic happens.
Old 10-13-2012, 10:22 AM   #15
albertlespaul
albertlespaul's Avatar
Re: How to slave?
I started wondering while reading this topic: if you put a 1W amp into a 100W one, then is it 1W or 100W loud?
albertlespaul is offline   Reply With Quote
Old 10-13-2012, 12:02 PM   #16
crossroadsnyc
Senior Moderator
crossroadsnyc's Avatar
Re: How to slave?
$700 pedals FTW!
crossroadsnyc is offline   Reply With Quote
Old 10-13-2012, 12:10 PM   #17
HeHasTheJazzHands
Senior Member
HeHasTheJazzHands's Avatar
Re: How to slave?
Quote:
Originally Posted by crossroadsnyc View Post
$700 pedals FTW!
__________________
Djong
HeHasTheJazzHands is offline   Reply With Quote
Old 10-13-2012, 12:21 PM   #18
Ken
Senior Member
Ken's Avatar
Re: How to slave?
Quote:
I'll guess 101 watts!!
Your 100 watt amp cranks out 100 watts (at some arbitrary THD %)...that's all it can do at that rating.
Naturally with cranked volume plus pedals that boost, you can push it way beyond that with a tube amp. The input's level won't change the RMS rating though; it is what it is. The 1 watt amp is just bypassing the preamp in the 100 watter. It just gives a head start to power tube breakup.
So I would say 100 watts is the answer.
Ken
__________________
Woodson 2x12
1995 Taylor 310
Old 10-13-2012, 01:06 PM   #19
diesect20022000
V.I.P. Member
diesect20022000's Avatar
Re: How to slave?
Quote:
Or what nuke said.
you beat me to it
i'd ad through conveniences as well
Old 10-13-2012, 01:48 PM   #20
poeman33
Super Moderator
poeman33's Avatar
Re: How to slave?
It's one louder
__________________
Old 01-25-2013, 10:56 PM   #21
DragonSarc
Senior Member
DragonSarc's Avatar
Re: How to slave?
does this apply to any amp that has an FXloop? I got a JVM1 and JCM1 and would like to hook/slave it up to my egnater or peavey classic 30 to get that gnarly overdrive and distortion
__________________
JVM410H w/ 1960 Vintage A & Lead B
Egnater Renegade 65 w/ 1936 cab
Gibson LP Custom Classic Cream
Gibson LP Standard Ebony
Gibson LP Studio Heritage Cherry Sunburst
Gbison LP Special Vintage Burst w/ APH 11 Pro
Gibson LP studio faded mahagony w/ Burstbuckers Pro V
Gibson LP Studio 50's Tribute Humbucker
Gibson SG Classic
Edwards Les Paul w/ Duncan JB and 59's
Fender Am Std Strat w/ Vintage Noiseless
LTD EC-500 w/ EMG-X 81/85
Jackson Stealth Pro MIJ
DragonSarc is offline   Reply With Quote
Old 01-26-2013, 12:27 AM   #22
diesect20022000
V.I.P. Member
Re: How to slave?
Image Detail for - In the last post, Slave Mentality of America (Part 1) we set the ...
Old 01-26-2013, 01:05 AM   #23
RickyLee
V.I.P. Member
RickyLee's Avatar
Re: How to slave?
On the subject of slave outputs, I have a few older amps that have the slave outputs. My '84 4010, '88 2205 and even the Jubilee if I am remembering correctly.
Do the slave outs on these older amps function like what you guys are describing above?
RickyLee is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
