MarshallForum.com
Reply
Thread Tools Display Modes
Old 08-30-2012, 08:35 AM   #1
DILLIGAS
DILLIGAS's Avatar
JCM 800 2205 or 2204?
I have the chance to pick up a 2205 for $950 locally that looks good in and out. I currently have a JCM 900 4500 that I have done the simple mods (clipped 1 leg on R7 & R43, jumping C10 & D27) running a Seymour Duncan "pickup" booster on the front end, and an EQ in the effects loop. Using a JCM 800 cab with the 75's in it and like the sounds I get. I mostly like Sabbath, motorhead, etc... and can get the sound I'm after the way I have it set. Been doing a lot of reading here (great website by the way). Also available but much further away is a 2204 in about the same condition for $1,000. Please tell me why you'd go with one over the other.
Thanks,
Drew
DILLIGAS is offline   Reply With Quote
Old 08-30-2012, 10:43 AM   #2
Adrian R
Senior Member
Adrian R's Avatar
Re: JCM 800 2205 or 2204?
Dude,
It depends on how you wish to use the amp. If all you need is just one channel without a lead boost by all means get the 2204 as imo has slightly tighter tone then the 2205, but the 2205 is BAD ASS as well! I used a 4500 for nearly 6 years in a band...and would use it the way you have described. I would boost both the A and B channel with a boost pedal, and run a BBE sonic maximizer in the loop. Got GREAT tones that way. However, the B channel is 100% solid state minus the power section. As such, my lead tones never had any cut, and were thin in comparison to the A channel.
A Solution that worked for me, and I owned both 2204 and 2205s..(love the tone of those amps)was a 900 2500/2100 MK3 or Mk4 (prefer the 3). This had more pure tube tone, will cut FAR better then the 4500..and had a foot switchable MV control..perfect for mix cutting solos. Plus, you can leave the FX empty with the exception of a patch cord. (this is almost mandatory)
My final solution that worked perfectly for me was the DSL..IMO its a step up tone wise with respect to ANY 900..and its more responsive to your playing. Hard to explain..but the 900s all seem to be more difficult to play through..they respond slower to your picking in where a good 800 or DSL responds with complete fluidity... It can give you 800 like tones with the *right tubes and bias,*(very important) and yet has the OTHER channel!...Use it in the same manner that you use your current rig, and leave the FX empty if need be. That 4500 sounded dull without the BBE in the FX loop...
I have never been happier in 20+ years of Marshall ownership. The DSL buries the 4500 in *just* about every category. Its a much warmer sounding amp that has serious cut..allowing your solos to DOMINATE the mix..incredible. Plus, and as you probably already know, doesn't slice you in half like those DRs do when standing in front of the cabinet. My 4500s were so damn directional...the DSL just seems to project its tone far more evenly.. DSLs are everywhere and their affordable in the used market. You can get one in mint condition for around $650...a great bargain when you are considering buying a 20+ year old amp for almost twice as much..and imo in many ways sounds just as good, and has more flexibility then an older 800.
__________________
99' Marshall JCM 2000 Dual Super Lead 100 w/mods
00' Marshall JCM 2000 DSL 100 w/mods
05' Marshall 1960 4x12 w/mods
85' Marshall 1960 4x12 w/mods
06' Marshall MG-15 microstack w/mods
95' Gibson LP Standard
00' Gibson Flying V98
01' Gibson Flying V98
01' Gibson 67' RI Flying V
06' Gibson 67'RI Flying V
00' Guild DV-6
*Some* hearing loss?
Adrian R is offline   Reply With Quote
Old 08-30-2012, 11:39 AM   #3
ramble
Junior Member
The 2205 is more versatile than the 2204 because it has two channels and can switch between the two and it has reverb. US models have 6550 tubes. Nice fat chunk sounds good. The clean channel is ok but really you can dial in a better clean tone on the "boost" channel, or the dirty channel if you will. Nice amp. I jam on one a couple nights a week on a retubed and capped 2205 and its great. But next to my 2204 amps it sounds a bit dull and not nearly as punchy and alive. Honestly I put them side by side a couple times a week (throgh celestian loaded cabs) and I like the 2204 better. My 2204s have el 34 tubes and the amps themselves are new. Your ymmv with an older 2204... you can see my amps online here: Trenkler Amplification - Home on my forum posts, and ebay.
ramble is offline   Reply With Quote
Old 08-31-2012, 03:00 AM   #4
medicjg
Senior Member
IMO get the 2205. If that wasnt available I would get a mkIII. 2205/10 both bury the DSL or 2204 IMO. The MKIII is less versatile but covers a wide range of tones from slightly dirty to all out high gain that reacts very will with a boost. I have owned all of them at one point.
medicjg is offline   Reply With Quote
Old 08-31-2012, 04:34 AM   #5
S÷ulcaster
V.I.P. Member
S÷ulcaster's Avatar
Just to confuse you, I'd grab the the 2204, only because it is totally different to what you already have.
__________________
"weight of my heart...not the size"
Quote:
Originally Posted by bulldozer1984 View Post
there is something about the raunchy n sexy sounding AFD that makes me tingle !
S÷ulcaster is offline   Reply With Quote
Old 08-31-2012, 08:59 AM   #6
V-man
Senior Member
V-man's Avatar
Quote:
This.
If you had but one Marshall, the 2205 would be more of a consideration. Since you already have a diode-driven Marshall, I would go for the 2204 as well.
V-man is offline   Reply With Quote
Old 08-31-2012, 09:12 AM   #7
NewReligion
V.I.P. Member
NewReligion's Avatar
Quote:
This +1
All of my US 2205/2210's past and present, came with EL34's. I prefer the 2205/2210 and original non cascaded gain designs of the 1987/1959 Plexi circuits.
They are all great amps. It just depends on which one inspires you to play with passion. For many it is the 2204. However there are many who are not aware of the Split channel models (True First Hot Rods) Channel Switching, Reverb and Effects Loop clipping diodes added to circuit which would later be used by Marshall again in the Jubilee series then later World famous amp guru's. That was a huge deal in 1982.
Here is a video I made just for this purpose:
To those who have seen the video time and again, I appologize lol.
Smooth, Clear and Sustained.
David
__________________
I DON"T HAVE TIME FOR THIS
Cameron/Friedman/Marshall/Hopkins DH 50 Amps.
NEW RELIGION Download $5.95 @ CD Baby http://www.cdbaby.com/cd/davidchopkins
NewReligion is offline   Reply With Quote
Old 08-31-2012, 09:37 AM   #8
Georgiatec
V.I.P. Member
Georgiatec's Avatar
The boost channel and reverb on the 2205 would be the deal clincher for me. Make sure everything works well. If the boost channel feeds back at relatively modest volume steer clear...(you should be able to get the master up to 5-6 with boost vol and gain at 7-8 without a problem)
__________________
JCM2000 DSL100
VINTAGE MODERN 2466 WITH 425 A & B CABS
2061x
SL-5, CLASS 5 Mk 1.
JMP1c & JCM1H.....BADCAT UNLEASH
JMD50
1960B, MX212, 1922 & VS112 CABS
1983 FENDER TWIN REVERB II
1978 PEAVEY CLASSIC 212 COMBO
GIBSON LES PAULS....R7, R8, R9, R0, '04 CLASSIC & '12 TRAD. PREMIUM
'00 FENDER USA STANDARD TELECASTER
FENDER MODERN PLAYER TELE+
'94 FENDER MIJ '62 RI FOTOFLAME STRAT.
'99 FENDER USA STANDARD STRATOCASTER
Georgiatec is offline   Reply With Quote
Old 09-01-2012, 03:09 AM   #9
DILLIGAS
DILLIGAS's Avatar
Thanks to all for your responses.
Drew
Old 09-01-2012, 04:24 AM   #10
plexilespaul
Senior Member
plexilespaul's Avatar
Quote:
2205/10 both bury the dsl or 2204 IMO
__________________
MARSHALLS FOR LIFE
original jubilee 2555 87 with matching cab
jcm 800 2203 83
jcm 800 2210 1982
old 4 holer 50 watts
jcm 800 4*12 cab with g12-65
jcm 900 cab with 73 greenbacks
plexilespaul is offline   Reply With Quote
Old 09-01-2012, 09:57 AM   #11
Adrian R
Senior Member
Adrian R's Avatar
Quote:
Originally Posted by avivoni View Post
I am right there with ya Avivoni..
That is an opinion of course..and I have owned all of them..and that is NOT my experience... Most of the time these opinions are formed by people whom DO NOT have practical experience with the amps...but..of course everyone hears things differently..
I LOVE all the aforementioned amps...they ALL sound like Marshalls...and imo, are the anesthetist of breed. The DSL..*probably* has the least desirable tone in its stock form with respect to the 2205/10 04...BUT the very small disparity in tonal quality is easily equaled by its functionality.
The 2205/2210's clean channels are no where as good as the DSL's clean channel, and for me was basically useless..for my application. Having the DSL's OD1 red channel for a band mix cutting, warm solo boost ON TOP AND OVER a good rhythm channel cannot be accomplished with either the 2205/10 (cept' for putting a clean boost in the 05/10's FX loop) or 2204! This makes the DSL for me a hands down winner...
__________________
00' Guild DV-6
Old 09-02-2012, 11:18 AM   #12
medicjg
Senior Member
The clean channel on the 2210 is no slouch. It can get a little wooly if you have the master up high. However beautiful when used with the right guitar. So if you were performing with the 2210 then it wouldnt be as practical as a DSL. For me the drive channel is where its at on the 2210 and would be worth toting along another head for cleans.I could have been doing something wrong when I had a DSL but have had no issue what so ever dialing great tones from an 800 or 900. The 2210 is a monster of an amp you can dial it in from bedroom level to all out anarchy and it sounds killer. I respect others opinions im sure you get a killer tone from the DSLs they just werent for me clean dirty or otherwise.
Old 09-02-2012, 11:23 AM   #13
wakjob
Senior Member
wakjob's Avatar
I have a 2204. And played a bunch of DSL 50's and 100's. I too prefer the 2205/2210 for gain applications. Then again, I really like red LED's in my signal path.
The cleans are more than good enough for what I do.
wakjob is offline   Reply With Quote
Old 09-02-2012, 11:31 AM   #14
NewReligion
V.I.P. Member
I do not play Marshalls (2210/1987) for the Clean signal, I play them for the professional smooth Dirt!
Cleans? Well that is why I own 1963 Fender Bassman and a 120 Roland Jazz Chorus Head. Through a 412 they are beautiful.
I have a few amps that are mediocre at doing both. But I use the 2205/2210 as a single channel amp and the Split clean will do just fine for live IMO.
David
__________________
Old 09-03-2012, 01:07 PM   #15
DILLIGAS
DILLIGAS's Avatar
Can anyone tell me if a stock 2205 has the same, more, or less gain than a stock 4500?
Drew
Old 09-03-2012, 05:10 PM   #16
Adrian R
Senior Member
Adrian R's Avatar
Quote:
Drew
A 2205's hot channel has about the same amount of gain as the 4500's 'B' channel, but its character is completely different. In short the 2205's hot channel BLOWS away a 4500's B channel..far thicker/fatter and warm with good cut..
__________________
00' Guild DV-6
Old 09-03-2012, 05:12 PM   #17
NewReligion
V.I.P. Member
+1 Of course that is my favorite circuit anyway.
__________________
Old 09-03-2012, 05:25 PM   #18
SwampThing
Banned
FWIW..When discussing a 'Clean channel' if your tone is dialed in right, when you need a clean tone kill your front end OD (if you use one) and roll the volume back on your guitar. These discussions are repetitive, if you need absolute clean clarity whatever, spend the money on a roland Jazz chorus or a fender twin and get an A/B switcher. Marshall's are NOT known for their clean beauty and never will. Cranked= Amazing.
My .02
SwampThing is offline   Reply With Quote
Old 09-03-2012, 05:28 PM   #19
NewReligion
V.I.P. Member
Quote:
My .02
As I said earlier,
David
__________________
Old 09-03-2012, 05:31 PM   #20
SwampThing
Banned
Quote:
Originally Posted by NewReligion View Post
As I said earlier,
David
Im not knockin ya at all brother, I owned a 2210 that the Dirt channel would bleed over into the clean channel and drove me nuts. I just think the eternal quest/debate for clean tone on a Marshall is ridiculous. Its like lowering Big-Foot down to 11 inch rims.. makes no sense. Your 63 Fender Bassman, that the real deal or re-issue?
Old 09-03-2012, 05:42 PM   #21
NewReligion
V.I.P. Member
I knew where you where headin' Swamp. I was driving it home. Though My Plexi, Bogner, Mesa other Marshalls do okay on cleans just go all out and get the best clean tone possible which I too believe are the Fender and Roland.
The 1963 Blonde Bassman is the real deal 6G6. First model with SS Rectification. Sounds Unreal. Not like later Fenders. Literally can not dial in a fatiguing tone.
My Choice of Clean Amps: Fender Bassman, Roland Jazz Chorus 120-Head and Classic 50:
__________________
Old 09-03-2012, 05:50 PM   #22
SwampThing
Banned
Beautiful! If you dont mind me askin, how much did the Roland set you back, im on the lookout for one.
Old 09-03-2012, 05:58 PM   #23
NewReligion
V.I.P. Member
I bought it last fall from a local shop for $250. I paid much less for the Bassman. Truth, I swear. I have lost my ass before but not for a couple of years. I think my last bad investment all around was a Krank Rev-1 Head. My sons and I refer to it as the Krunk lol.
David
__________________
Old 09-03-2012, 06:08 PM   #24
SwampThing
Banned
David
250? wow not bad at all. Was expecting much more. Ya ive been down broke street too, traded a JCM-900 MK III for the 2210 about 5 yrs ago but I inherited a mess. Recently sold it too make room for Bigger and better. Im right there with you on Krank man, those amps are garbage.
Old 09-03-2012, 06:11 PM   #25
NewReligion
V.I.P. Member
Pure bzzzzzzzzzzz!
__________________
Old 11-19-2012, 03:48 AM   #26
Phoenix Guitar
Jazz Chorus is one of my favorites! Forgot about that one. Been awhile.
I just picked up a JCM2205. I use the Dirty channel mostly, but when I am switching to clean channel I will put some chorus in the loop via boss pedal. Clean channel works well enough live. I play in cover band these days. JCM 800 2 channel feels better than the DSL, TSL, JVM, and rest. Would like to bring the Roland Jazz and AB switch. Nice demo by the way!
Phoenix Guitar is offline   Reply With Quote
Old 11-19-2012, 11:10 AM   #27
Ampcrazy
Banned
Quote:
Oh man! i clicked the link and looked at the chassis shots of your amps cool cool cool cool! they are brilliant pics and so clear.
Everyone that loves looking at the insides of the chassis's and neat work; click on ramble's website and drool at the pics!
Great work man!
Ampcrazy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
