MarshallForum.com
Reply
Thread Tools Display Modes
Old 08-30-2012, 12:52 AM   #1
kam4ff
Senior Member
Jubilee And JCM 800 Not Metal Enough
Any tips besides pedals for getting where I need to be? An ep or mxr 10 band get there but they're noisy.
kam4ff is offline   Reply With Quote
Old 08-30-2012, 01:20 AM   #2
JBMarshalLover
JBMarshalLover's Avatar
Re: Jubilee And JCM 800 Not Metal Enough
Sell both and get something else or a 2210? or 2203 modded
JBMarshalLover is offline   Reply With Quote
Old 08-30-2012, 01:51 AM   #3
HeHasTheJazzHands
Senior Member
HeHasTheJazzHands's Avatar
When I think metal, I really don't think Jubilee...
As for the JCM, try a Boss SD-1 or an MXR ZW OD. They may add noise, but thats the nature of the beast.
If all else fails, trade your JCM for a 2203KK, which has a boost and noise gate built in.
__________________
Djong
HeHasTheJazzHands is offline   Reply With Quote
Old 08-30-2012, 02:10 AM   #4
Wycked Lester
Senior Member
Wycked Lester's Avatar
i use 2 2203's in stereo boosted with an sd1 for metal and they sound amazing in the context of a band. Very chunky and smooth but with sweet mids that cut thru and fill the mix like no other head i've tried.
I have a jubilee too, but the brute punch, definition, and clarity of the 800 still win in my book.
You have to be careful dialing up metal tone,... its VERY easy to over do lows and gain, and VERY VERY easy to scoop out too much mid... The 800s pretty much prevent this from hapening
__________________
I have a bunch of amps and guitars...
My favorite head ever - 2203
Second favorite head - Jubilee
My #1 Guitar - 98 Custom Shop Jackson Soloist-Mike Shannon Built
My #2 Guitar - 1982 Les Paul Std.
I dig blues and metal.
"IF IT'S TOO LOUD, YOUR TOO CLOSE"
Quote:
Originally Posted by Fretboard View Post
Personally, I'd never get another person's signature guitar, amp, etc. So, I'd go with the Jackson. I'm planning on getting an RR-1.
Wycked Lester is offline   Reply With Quote
Old 08-30-2012, 02:19 AM   #5
diesect20022000
V.I.P. Member
diesect20022000's Avatar
dude death metal bands use 2203's lol. yeah they need a boost though to get there but modern amps need a boost too. it's the nature of a good tight metal tone to need a clean boost/od set clean.
if that doesn't do it though the bogner alchemist is a great cheap option (refer to my sig, recertified and sweep 16) or Framus Dragon and cobra (which i also have. i have a cobra modified dragon for sale or partial trade right now)
or the age old classic 5150.
900 SL-X
900DR etc may do okay too dependong on tastes.
but imo no amount of gain makes up for a clean/set clean boost out front to the amp.
the only amp i've owned that's come to where i can get away with (in my mind) using no boost is the Framus cobra and dragons but i still PREFER a boost to tighten things up.
i take that back, peavey XXX is tight enough without a boost but it's hella compressed unless biased up better.
they're pretty solid metal amps with a brighter tone than 5150's.
Old 08-30-2012, 03:41 AM   #6
DSL 50
Senior Member
DSL 50's Avatar
About $250
DSL 50 is offline   Reply With Quote
Old 08-30-2012, 06:59 AM   #7
newbies
Senior Member
newbies's Avatar
A good boost, 2203 and high output pickups will get you metal. As diesect said so many metal bands have used 2203s over the years. Mxr wylde overdrive can be a good change to a sd1 but you will need a noise gate.
__________________
'83 JCM 800 2203
JCM 800 2203ZW
6100
JCM1H
'87 Silver Jubilee 2553
1965b Lead Cab
76' Gibson Les Paul Custom
96' Gibson Les Paul Custom
newbies is offline   Reply With Quote
Old 08-30-2012, 07:51 AM   #8
spacerocker
Senior Member
spacerocker's Avatar
What about a JVM410? I have head good metal clips with these?
__________________
Amps: Marshall JVM410: Hotter Bias, Plexi mod, 10H choke, "Stiffness" Mod, Neg Feedback Mod to 2203 spec., Tone Stack Mods to 2203 spec. R72 Compression Mod (OD1/2), OD2>OD1 Conversion,; Marshall AVT20 Valvestate practice amp; 1980 2203 - Totally original.
Guitars: Les Paul Traditional, Fender HM Strat x 2 with Dimarzio Evolution Humbucker, Fender Standard Strat
Effects: Morley Wah/Volume Pedal. Behringer Vintage Phaser, TC G-Major, Alesis Midiverb. Behringer FCB1010 Midi Foot Controller
spacerocker is online now   Reply With Quote
Old 08-30-2012, 08:06 AM   #9
dreyn77
Senior Member
good suggestions guys! those hot pickups are the first improvement you should make. that 10band EQ is great! there is 10 little amp circuits built in to the pedal each is amplifiing the high impedance (current) signal (voltage) that noise is the full current of the voltage. It's supposed to be noisey!
dreyn77 is offline   Reply With Quote
Old 08-30-2012, 09:43 AM   #10
Adrian R
Senior Member
Adrian R's Avatar
As mentioned, both amps require a good clean boost pedal or overdrive pedal to push the preamp into overdrive..NATURALLY...
Why the predisposed disliking for pedals?
Some of the greatest metal tones of all time were conceived this way...from Rhodes, to King, to Tipton..**** Mercyful Fate...could go on and on..
*Most* of these players used Marshall amplification with their front ends being boosted with some kind of pedal. Guitars and their pickups have great influence as well..
Very few amps today, even the high end boutique style amps, can touch the tonal purity of a properly setup JCM 800 (the RIGHT tubes and bias) being punched in the teeth with a good quality boost pedal. It really is the benchmark from which all other rock/metal amps are judged.
__________________
99' Marshall JCM 2000 Dual Super Lead 100 w/mods
00' Marshall JCM 2000 DSL 100 w/mods
05' Marshall 1960 4x12 w/mods
85' Marshall 1960 4x12 w/mods
06' Marshall MG-15 microstack w/mods
95' Gibson LP Standard
00' Gibson Flying V98
01' Gibson Flying V98
01' Gibson 67' RI Flying V
06' Gibson 67'RI Flying V
00' Guild DV-6
*Some* hearing loss?
Adrian R is offline   Reply With Quote
Old 08-30-2012, 09:50 AM   #11
rdamaral
Senior Member
rdamaral's Avatar
hmm, that Kasha mod is interesting, anyone build one berfore?
rdamaral is offline   Reply With Quote
Old 08-30-2012, 09:55 AM   #12
Adrian R
Senior Member
Adrian R's Avatar
Quote:
Originally Posted by DSL 50 View Post
Ha!! That was pretty cool man! A possible solution for the 800 04/03 users..especially with footswitch capability. However, you can *almost* get the much of a gain boost using a GOOD quality OD pedal without having the expense of a FX loop installed, and maintain the natural TIGHT tonal integrity of the amp. To me when the guy switched on the mod the bottom end loosened slightly... but it still sounded good..and at $250 for the little box..was affordable.
But for me, I don't need it! The DSL does this well boosting the green channel and..having the red channel with its MV control for not only a gain boost but a VOLUME boost as well..
Sorry, love me DSL!
__________________
00' Guild DV-6
Old 08-30-2012, 10:40 AM   #13
DSL 50
Senior Member
DSL 50's Avatar
Sorry, love me DSL!
You don't need to have an effects loop for the Kasha mod.
It just plugs into the V1
Quikmod Classic (Rockstar Mods of the 80's) - $236.55 : Kasha Amplifiers, Store
Old 08-30-2012, 11:05 AM   #14
Adrian R
Senior Member
Adrian R's Avatar
Ahh..that's VERY cool...and for the price..well, that is about what a boutique OD pedal will cost you. I'd love to do a side by side test with a 2204...one with the F/Tone pedal driving the amp stock, and then comparing it to the amp running that mod device. The Fulltone pedal is only about $150.00...I got ALLOT gain out of my 2204 with the F/tone pedal..not *quite* as much as what that video depicted, but pretty damn close..and my tone stayed SUPER TIGHT.
But, as I mentioned early, my DSL does all of this and then some...
__________________
00' Guild DV-6
Old 08-30-2012, 11:52 AM   #15
Ayrton
Senior Member
Ayrton's Avatar
Hot pups, an EQ pedal and a boost... done.
If that don't get it, you are not looking for a Marshall.
__________________
-Chris
Ayrton is offline   Reply With Quote
Old 08-30-2012, 12:07 PM   #16
V-man
Senior Member
V-man's Avatar
This. Everything from the 80s was a boosted 2203. when Celtic Frost reformed, Tom Warrior had whatever he wanted to recreate his sound. After testimg the modern gear, he went back to the 2203 (boosted), which was the quintessential metal sound.
The jubilee would be more of a solo/melodic metal amp. It is clear gain, not raunchy gain, so it's for shred, not riffage. IMO, the best thing to add is a transparent OD to a Jub if boosting. I use the Tim, a marshall-based circuit.
V-man is offline   Reply With Quote
Old 08-30-2012, 12:52 PM   #17
Adrian R
Senior Member
Adrian R's Avatar
Quote:
And there you have it. Very well illustrated V-man.
__________________
00' Guild DV-6
Old 08-30-2012, 02:04 PM   #18
luisgarciaalanis
Didn't Metallica used a JCM800?
luisgarciaalanis is offline   Reply With Quote
Old 08-30-2012, 03:16 PM   #19
Fiftywattmafia
Senior Member
Fiftywattmafia's Avatar
Quote:
Modded
Jesus...not metal enough? Try Engl.
Fiftywattmafia is offline   Reply With Quote
Old 08-30-2012, 03:23 PM   #20
HeHasTheJazzHands
Senior Member
Only the power sections for their Mesa Mark 2c+s.
But they did use Jose-modded JMP100s that were boosted by a Rat (Kill em all) and a Tubescreamer (Ride the Lightning, blended with a mark 2c+).
Why not add a DSL or a JCM900 SLX in your collection?
__________________
Djong
Old 08-30-2012, 05:05 PM   #21
Leendrix
I don't have a JCM 800 right now, or a Marshall for that matter. But when running my Jet City JC100, The gain is set around 10 o'clock, and I'm using a strat with it. It's kinda RHCP at that gain stage, but add in an SD-1 with the drive set just past 9 o'clock, and it screams! Try a boost pedal.
Leendrix is offline   Reply With Quote
Old 08-30-2012, 11:42 PM   #22
SwampThing
Senior Member
SwampThing's Avatar
I know im regurgitatng here, but just about EVERY thrash band from the 80's was an 800 or JMP Master. If its not tickling your fancy you may need to look into the solid state option, although I hate to see you do this because a boosted 800 I PROMISE will do the trick. Even a 50watter properly dialed in will do it.
__________________
Ultra Moderator
SwampThing is online now   Reply With Quote
Old 08-30-2012, 11:54 PM   #23
SonVolt
V.I.P. Member
SonVolt's Avatar
Everyone is saying the same thing but I don't think it's exactly the right advice for this particular question. If you are wanting a modern metal sound then an 800 is not the right amp for you. You will be better off with a true high gain amp like a JVM, 5150 or a Dual Rectifier. A JCM 800 is a classic rock amp that can be pushed hard with pedals... But then you're using pedals which may not give you the results you're looking for. You will never get clear tight high-gain, ala Metallica or KSE with an 800. It ain't gonna happen. Your ranges will be AC/DC to Slayer.
SonVolt is offline   Reply With Quote
Old 08-31-2012, 12:33 AM   #24
Billyblades
Banned
The 2203 can be turned into a fire breathing Dragon of an amp. The kasha was never very impressive and cumbersome. Pedals are the next step but i could turn that amp into a a killer!
Ideal wouod be Very crunchy and heavy like the uberschall / diezel
Most high gain amps are Marshall derivitives and the master volume is the perfect starting point for whatever.
Billyblades is offline   Reply With Quote
Old 08-31-2012, 01:28 AM   #25
David Corrales
Senior Member
David Corrales's Avatar
There're some DSL 2000 clips of Metallica sounds at the end of this thread.
David Corrales is offline   Reply With Quote
Old 08-31-2012, 01:30 AM   #26
kam4ff
Senior Member
Billyblades what are you suggesting? to turn that amp into a killer like an uberschall or diezel?
Old 08-31-2012, 02:22 AM   #27
SwampThing
Senior Member
SwampThing's Avatar
I think its a matter of a few things coming together, I know for a fact Jon from Shadows Fall and Mark Morton from Lamb of God both use....wait for it....Marshall 800's in the studio for leads and otherwise. Jon uses a Maxon 808 and if im not mistaken Mark uses a MXR GT-OD. Theyre both Modern Metal as ****. Are you going to Get cannibal corpse heavy? No, but I REFUSE to believe this lad cant get a "Metal" tone from an 800.
My advice? Whether you want to hear it or not- your choice. Take the 800 to a shop and have it looked at by someone who can service a Marshall, make sure everything is good under the hood, if not swap em out (tubes), then take a look at the ickups you have, Low output? High output? Duncans? EMG's? Research a pair to your liking- hook em up. Next, OD pedal GOD knows theres a ton of info on this forum alone however the most popular for pushing an 800 would be ;
Boss SD-1
OCD
Way Huge green rhino
Ibanez Tube screamer
MXR ZW 44
Theres literally thousands more and im sure whats his name will plug his on this thread eventually, try what you can. Research what your fav players amp/Pedal settings and go from there. Its out there dude, you just have to do the work to dial in what you want to hear.
Good luck
__________________
Ultra Moderator
Old 08-31-2012, 10:42 AM   #28
Billyblades
Banned
Sometimes money is a factor. And its easier to mod than to go buy another expensive amp. If you look at diezel and ubers,,, they started out modifying plexis and 800 which are actually the same amp.!
Im just eager to impress and i would love to take it and show people what i can do.
Please pardon me if i been seeming overzealous. I have spent alot of time perfecting this crafting of tone and am very passionate about it but yes. Turn it into a beast! Like diezel or uber style.
After my ordeal i drove myself at fanatical pace and studied the best of the best. In higain tone! Diezel, Cameron, Bogner, Mesa, Fortin.
I got the secrets and want to show off lol. Plus most of these mods arent available anylonger!
Im bringin Badass back! And bringin it on the cheap. Been doing alot of ceriatones lately for people.
Old 08-31-2012, 10:56 AM   #29
Billyblades
Banned
Primarily 2204-3 and plexis. Clones too especially handwired types.
I actually love it as much as playing guitar!
Old 08-31-2012, 10:58 AM   #30
50WPLEXI
Senior Member
50WPLEXI's Avatar
Mine's on the chopping block next bro...
50WPLEXI is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
