MarshallForum.com
Reply
Thread Tools Display Modes
Old 10-22-2007, 11:00 PM   #1
fiftycalibre
Senior Member
fiftycalibre's Avatar
Amp Settings
Here are two different amp settings you might like to try. I think these are pretty close. Guitar is straight into amp with no FX. OD channel.
AC/DC GAIN=3 TREBLE=7 MID=7 BASS=7 REVERB=0
Deep Purple GAIN=7 TREBLE=5 MID=6 BASS=5 REVERB=0
Does anyone have settings they want to share?
.50
__________________
Whats wrong with Jack the Riffer anyway....
fiftycalibre is offline   Reply With Quote
Old 10-23-2007, 07:36 PM   #2
Alex
Administrator
Alex's Avatar
Re: Amp Settings
Good thread.
Slash from GnR/VR
Presence: 8
Treble: 5
Middle: 7
Bass: 7
Gain: 7
Gary Moore
Presence: 5
Treble: 7
Middle: 9
Bass: 5
Gain: 5
Alex is offline   Reply With Quote
Old 10-23-2007, 11:37 PM   #3
coldsteal2
Senior Member
coldsteal2's Avatar
Re: Amp Settings
Jake E Lee
Presence: 10
Treble: 10
Middle: 10
Bass: 10
Gain: 10
Dimes all the way!
Ajust output with guitar volume and tone with crybaby wah.
__________________
Playing Marshall's since 1969
Vintage Modern 2266, JCM-800, JCM-900,1960A(G12H's), DSL-401,AVT-50combo , CLASS 5 Head,Orange Rockerverb 50, and cab
My Youtubes......ColdSteal II on Soundclick.com
coldsteal2 is offline   Reply With Quote
Old 10-25-2007, 01:32 AM   #4
LoKi
Senior Member
Re: Amp Settings
My settings on my JCM 800.
Presence 6
Treble 5
Mids 7-8
Bass 10
Pre 10
Master 3-6 depending. Normally its on 3 or lower... ****ing 2203's are so damn LOUD.
LoKi is offline   Reply With Quote
Old 10-25-2007, 03:11 AM   #5
coldsteal2
Senior Member
coldsteal2's Avatar
Re: Amp Settings
Presence 6
Treble 5
Mids 5-6
Bass 10
Pre 10
pretty close to your settings, master on 3 if nobody is around
below 3 it starts droping out.
My 900 Settings are alot different.
Presence 8
Bass 10
Mids 5
Treble 7
Pre 5
Chanel A 2-3 at home 50 watt switch on
(Gov'ner II through effects loop for bass/sub end boost)
__________________
Old 11-04-2007, 08:22 AM   #6
Rocktiger74
Junior Member
Rocktiger74's Avatar
Re: Amp Settings
Hi guys, can you help...
I have searched and searched the web for famous players amp settings that I can add to my recently aquired JMP-1, and cannot believe there are so few (almost none!) sharing these tones.
Is everyone really that secretive over there tone findings or have I just purchased something that nobody owns anymore?!?!
I can remember years ago ol' Geoff Whitehorn and Phil Hilbourne of Guitar Techniques magazine (showing my age now...lol) both using JMP-1's to create the sounds of the guitar gods....sometimes giving away the tone settings.
Thanks for reading my waffle, and I look forward to hearing from anyone that could help.
Cheers
RockTiger74
Rocktiger74 is offline   Reply With Quote
Old 01-01-2008, 01:20 PM   #7
Dave B
Re: Amp Settings
Hi Rocktiger74
I have the JMP-1 and agree there doesn't seem to be many patch settings out there.
I remember the guitar techniques settings, but found most of these work best when going direct with the JMP-1.
When it comes to using the JMP-1 in a live situation the pre programmed settings sounded awful, way to much top end so I've done the following.
JMP-1 into Digitech Studio Quad V2 All mono.
Then use one side of a Marshall 9100 power amp,Voicing B, into a Marshall 1922....... 2 x 12 cab.
Jmp-1 settings for rhythm are:
Vol...12
Gain..15
Bass..4
Mid....0
Treble..-3
Presence....-3
OD/1
No Effect or maybe a splash of reverb
Bass Shift off
For Lead I use the same settings as above, but up the gain to 19 and push the treble up a couple of notches.I also add some delay.
This seems to give me a nice crunchy Rhythm tone with a fluid lead.
I've tried a few different pickups on my main guitars an Ibanez RG, namely Seymour Duncan TB4, I've used a stock Peavey wolfgang (Korean model), but the one I find works the best is an old Les Paul copy I've had for 30 years equiped with a dimarzio super distortion pickup.Controlled top and serious bottom end.All done via the guitars volume.
I have found the top end needs to be tamed on this amp.
Dave B is offline   Reply With Quote
Old 01-01-2008, 02:41 PM   #8
fiftycalibre
Senior Member
Re: Amp Settings
G'day Dave B,
Welcome to the forum and thanks for those settings.
What other rack gear do you have?
__________________
Old 01-01-2008, 04:17 PM   #9
Dave B
Re: Amp Settings
Hello fiftycalibre
Great forum, a wealth of knowledge.
In answer to your question gear I have a the moment is
In the Rack:
JMP-1
Marshall 9100
Marshall 1922 2 x 12 cab
Boss SD-1
Boss AC-2 Simulator
Boss Compressor
Digitech control Seven - midi controller
Marshall 1959 Superlead from 1971
Guitars:
Peavey Wolfgang (Korean)
Ibanez RG (I rebuilt it in blue and added gold hardware Inc SD TB-4,SD SH-2N Jazz Model,SD SSL 2.The TB 4 is going to be replaced by a Dimarzio DP100)
Tokai Custom
American Strat in Pewter (80's)
Saxon Les paul (Circa 1974)
Epiphone Flying V
Boss and Seiko Tuners
Steinberger Bass
Old pedals I don't use
Colorsound Overdrive
Colorsound Sustainer
Electroharmonix Big Muff
Electroharmonix Treble Booster
Dunlop Crybaby Wah
Gear I wish I hadn't got shut off:
4 x 12 cab with greenbacks from early 70's
Old 01-01-2008, 05:05 PM   #10
fiftycalibre
Senior Member
Re: Amp Settings
Wow. You have some great gear.
Welcome aboard BTW
__________________
Old 06-28-2009, 03:19 AM   #11
xophrax
Senior Member
xophrax's Avatar
Re: Amp Settings
I need settings for a JVM410H (nice sounding settings!) anybody got any?
I need clean, rhythm, and lead, and a bit distorted clean... or any artist settings ex. slash, dimebag, hendrix
__________________
"Those who criticize our generation forget who raised it."
xophrax is offline   Reply With Quote
Old 06-28-2009, 04:03 AM   #12
Jesstaa
Senior Member
Jesstaa's Avatar
Send a message via MSN to Jesstaa
Re: Amp Settings
On my 900 atm, I've got
Presence 10
Bass 8
Middle 2
Treble 8 1/2
Gain 20
Volume 2 - 4 When I'm just practising, but sometimes when I'm just being awesome I crank it up to like 5 or 6 (50watts mode)
I get a really nice tone for old school thrash, got the right mix of highs and lows happening, and a nice bit of saturation going on, no pedals whatsoever, EMG HZ H4 open pickup in bridge, agathis guitar body.
Tubes:
Power: Groove 6L6 Blue (IE Sovtek 5881WXT)
Preamp V3 JJ Balanced ECC83S (High gain) V2 National 12AX7A V1 JJ ECC83S (High Gain)
Hope that's helpful to anyone seeking an old school thrash tone.
__________________
GEAR LIST
Amps
1983 JCM 800 2203
1960AX
Guitars
B.C Rich Bich Perfect 10
Jackson Kelly
Basses
Ibanez SR300
Stagg BC300
I'm not a tech, don't take my advice as fact, I just like to offer my views.
Jesstaa is offline   Reply With Quote
Old 06-28-2009, 06:13 AM   #13
chris-a
Junior Member
chris-a's Avatar
Re: Amp Settings
My JCM 800 settings:
Presence 0
Bass 10
Mid 10
Treb 4
Master 1-2
Pre 6-7
1981's JCM 800 2204
Engl E 412 SS cab
Gibson SG Standard using Bridge PU both knobs at 10.
chris-a is offline   Reply With Quote
Old 06-28-2009, 08:06 AM   #14
Rypsolisti
Senior Member
Rypsolisti's Avatar
Re: Amp Settings
Marshall Vintage Modern 2266 settings:
Reverb: 3.5
Master Volume: 7
Presence: 2.2
Bass: 5
Middle: 9
Treble: 9
Detail: almost 9
Body: almost 8
Low or High Dynamic Range depending on what I play. Mid boost on for solos.
I sometimes boost it with Boss SD-1 or Digitech Bad Monkey. Chorus for cleans and Delay for solos and some other stuff.
Carvin X50B settings:
Reverb: 3.5
Presence: 1.4
Treble: 5.2
Middle: 2.4
Bass: 5.5
Master Volume: around 3
Lead Drive: 7.2
Rhythm channel volume: around 3
I'm boosting it with a Boss SD-1
Rypsolisti is offline   Reply With Quote
Old 06-28-2009, 10:03 AM   #15
RobS
Senior Member
RobS's Avatar
Re: Amp Settings
On my JCM900 i run
Pres 2
Bass 8
Mid 4
Treb 4.5
Gain 15 (Ch B)
Gain 7-10 (Ch A)
Vol 6 Ch B
Vol 8 Ch A
Rob
__________________
JCM900 4100 DR + 1960 A + B + Powerbrake
JCM800 2203x
Homemade 1936 with Lorantz Greenbacks
Ibanez PS10CL Paul Stanley Custom
Gibson LP Traditional
Epiphone LP Custom
RobS is online now   Reply With Quote
Old 06-28-2009, 06:42 PM   #16
American Viking
Senior Member
American Viking's Avatar
Re: Amp Settings
JCM800,
mids always on 10
preamp gain always on 10
presence 0
bass 5 or 6
treble 5 or 6
American Viking is offline   Reply With Quote
Old 06-28-2009, 07:54 PM   #17
Flipstick
Junior Member
Re: Amp Settings
JCM 800 2203 Settings (for Strat)
Presence 8
Bass 10
Middle 10
Treble 2
Gain 8
Master 5 on up
Flipstick is offline   Reply With Quote
Old 02-05-2010, 12:29 PM   #18
darrylportelli
Senior Member
darrylportelli's Avatar
Re: Amp Settings
I dont think that settings are relevant putting up!! since very amp is different + there are SOOO many variables,,,,pick ups, wood of guitar, speakers, wood of cab ecc it will all make a difference, its no use trying a setting on my 2203 that someone said is like the slash tone if he tried it on a 900 with different pups, guitar,cab ecc !!!
__________________
AMPS:
marshall JCM 800 2203
marshall 1982A cab(hendrix edition, borrowed)
Hohner tube amp( made in the 60's)
Laney LV300
marshall big ass bass amp(dont know model lol)
GUITARS:
I trust only my trusty Ibanez rg2570E prestige
Pedals:
digitech hotrod(trading this for a boss SD-1 for my 800!)
some zoom's which I rarely use.
MXR 10 band EQ
some homegrown ones
darrylportelli is offline   Reply With Quote
Old 02-05-2010, 03:46 PM   #19
Ken
Senior Member
Ken's Avatar
Re: Amp Settings
Quote:
LOL I agree, but it's interesting to me how everyone seems to have such different settings! On my DSL for stage/rehearsal volume most controls are around 5 except the mids are 10 and the presence about 3. That gives a good compromise on both channels and cuts through the mix well. But on a DSL pretty much ALL the settings sound good even though the EQ is way more responsive than on my old Fenders and Music Man.
Ken
Ken is online now   Reply With Quote
Old 02-05-2010, 04:04 PM   #20
big dooley
V.I.P. Member
big dooley's Avatar
Re: Amp Settings
yeah i got some settings... but i'm not trying to get "that sound" i adjust to my likings only
i play a les paul standard with ernie ball's .012's/.056's in standard tuning
footswitch is programmed as follows:
1, clean channel green orange or red (switching the modes constantly)
gain 3.5
treble 7
middle 5
bass 6
2, crunch orange
gain 10
treble 8
middle 6
bass 4
3, crunch red
4, OD1 orange
gain depending on volume (at high volumes i tend to set the gain lower) overall around 4.5
treble 7.5
middle 5
bass 7
5, OD2 red
gain depending on volume, but at around 3.5
treble 8
middle 6
bass 8
6 masterswitch
master 1 at around 5
master 2 one point higher then master 1
presence and resonance at around 4, depending on where to play
every channel has the FX-loop engaged (because of the noise gate i use) and a little bit of reverb (around 1.5)
__________________
JVM, the only marshall that's been modded to tame it, instead of hotrodding it
big dooley is offline   Reply With Quote
Old 02-05-2010, 10:20 PM   #21
Landshark
Senior Member
Landshark's Avatar
Re: Amp Settings
I figured I'd give the TSL users some rep...
All my gear is listed below in my sig but for kicks:
Gibson Les Paul Studio with stock pickups wired directly into the PCB.
JCM 2000 TSL 100
Clean Channel:
bass 1
mids 9
treble 4
volume 10
gain 3
pres 5
mid boost pressed
Crunch Channel:
bass .5
mids 8
treble 1
volume varies
gain 4
pres 6
Lead Channel:
bass 1
mids 8
treble 1
volume varies
gain 3
pres 6
These are my full band settings. Sometimes I'll use the deep switch... depending on the room we play in. The tone cuts and the harmonics are really high pitched and screaming. You might be thinking that with an amp like that, using so little gain, that owning this amp is overkill, but I find that the higher the gain is, the less noticeable the tone is and less useable tone is produced. It won't cut through the mix as well and it just over distorts IMO, becomes kinda fizzy after 7-ish. I just enjoy the tone with the gain at 3. Oddly enough if you use the crunch channel's gain at 7 it sounds nearly identical to the lead channel, but the crunch I get from the crunch channel with the gain at 4 is just amazing! Its clear and very articulate. The clean channel is simply amazing at those settings, especially with NOS preamp tubes or a Tung Sol in V1.
__________________
Shawn
'98 JCM 900 SL-X
Sourmash 4x12 (WGS ET-65s)
2008 Gibson Les Paul Studio
Revolving Door of Pedals including:
Out Front - Dunlop Crybaby, "On-stage" Tuner, Boss SD-1 Overdrive, Boss NS-2 Noise Suppressor. Loop - Boss RV-5 Reverb, Ibanez Tonelock DE-7 Delay.
Alvarez Acoustic-Electric
Landshark is offline   Reply With Quote
Old 02-05-2010, 11:04 PM   #22
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
Re: Amp Settings
Hey OP and Alex, you didn't state what amp/guitar you were using.
I have to agree with Darryl though. The age and type of tubes, speakers and cab used, speaker cab placement, guitar and pickups. An AC/DC setting is generally for a Gibson solid body of some sort, but what if you have a single coil guitar?
I do agree that it is interesting to see the settings and I will even try a few out myself. Remember the old saying, "It's like horseshoes and hand grenades...you only have to be close!"
__________________
Old 04-20-2010, 05:56 PM   #23
ac/dc
Junior Member
Re: Amp Settings
You have good settings for MG 102 too?
Chears!
ac/dc is offline   Reply With Quote
Old 04-20-2010, 09:03 PM   #24
RobS
Senior Member
RobS's Avatar
Re: Amp Settings
I know I have replied to this post a while back, but that was pre Deoxit Gold!
Now on my 4100dr is as follows
Pres 4.5
bass 4.5
mid 7
treb 5
gain A 10
gain B 12.5
Reverb off
Vol 6 both a & B
Very fat sounding and articulate, play open chords and every string is heard!
__________________
JCM800 2203x
Epiphone LP Custom
Old 04-21-2010, 04:26 AM   #25
nofearfactor
Senior Member
nofearfactor's Avatar
Send a message via Yahoo to nofearfactor
Re: Amp Settings
Rack 1>
digital stereo preamp/effects processor:
gain-50 to 75%
bass-6
mid-6
treble-6
amp level-50 to 75%
sonic maximizer:
(both channels)
contour-6
process-6
dual mono power amp:
(both channels)
presence- 50 to ?%
gain- 50 to 75%
Rack 1/Rig 1 signal path: guitar(ESP Eclipse,ESP-LTD EC-400,Les Paul Standard,a Schecter DamienFR and an Agile 7string superstrats w/Floyds,Fender Strat-all with EMG active pickups)>wah>Sabine rack tuner>Fractal AX-FX Ultra digital stereo preamp/effects processor>Rocktron Hush 2CX 2 channel noise reduction unit(levels set to minimum)>BBE 482i 2 channel sonic maximizer>Marshall 9200 Dual MonoBloc 100/100 power amp(Svetlana 6L6s,Brimar 12AT7s,Svetlana 12AX7s)>one Marshall 1960A cab running in stereo or 2 1960As running side by side in mono, one from each channel of the power amp(loaded with stock Celestion G12T-75s).
Rack 2>
gain-60 to 80%
bass-6
mid-6
treble-6
amp level-60 to 80%
sonic maximizer:
(both channels)
contour-6
process-6
stereo power amp:
(both channels)
Level- 50 to 75%
Resonance- 50 to ?%
Presence- 50 to ?%
Rack 2/Rig 2 signal path: guitar(ESP Eclipse,ESP-LTD EC-400,Les Paul Standard,a Schecter Damien FR and an Agile 7string superstrats w/Floyds,Fender Strat-all with EMG active pickups)>wah>Sabine rack tuner>Digitech GSP1101 digital stereo preamp/effects processor>Rocktron Hush 2CX 2 channel noise reduction unit(levels set to minimum)>BBE 482i 2 channel sonic maximizer>Peavey Classic 50/50 stereo power amp(JJ EL84s,JJ 12AT7s,JJ 12AX7s)>one Avatar 212 cab running in stereo or 2 Avatar 212s running in mono, one from each channel of the power amp (loaded with Celestion Vintage 30s).
When I am running into a head instead of using rack preamp and power amps (I own several- a JCM800,a Mesa MKIV,Peavey 5150 and a 6505 both FJA modded- and I usually use JJ tubes I get from Bob/Eurotubes),my approximate settings are usually:
bass-6
mid-6
treble-6
resonance-50 to ?%
presence-50 to ?%
level/volume/gain- 25 to 75 to ?%
or
pre level/volume/gain- 50 to 75%
post level/volume/gain/Master- 25 to 75 to ?%
nofearfactor is offline   Reply With Quote
Old 04-21-2010, 12:39 PM   #26
eljeffebrown
Senior Member
eljeffebrown's Avatar
Location: Banding, Snorkeling, High Speed Line Skipping, Boot Hunting, Mud Diving, Midget Pummeling.
Re: Amp Settings
Yea but did you ever stop to think that someone that is new to tone and to this board might be reading this and think to themselves "wow i might try that setting on my amp". there is allot of knowledge on this board and up till you chimed in I thought we were all sharing that knowledge. don't be a doucheweasel and just have fun posting your #'s man!
with that said,
50 watt Hi Gain Dual (modded)
Vol (ch b) 4
Rev 0
Vol (ch a) 4 (useing it as a lead channel)
Rev 6
Pres 8
Bass 5
Mid 8
Treb 5
Gain (ch b) 14
Gain (ch a) 20
__________________
Quote:
Originally Posted by MartyStrat54 View Post
Are you loosing your mind???
Quote:
Originally Posted by Blackie View Post
.. I am retarted ...
eljeffebrown is offline   Reply With Quote
Old 04-21-2010, 01:19 PM   #27
indeedido
Senior Member
indeedido's Avatar
Location: Where the wind comes sweeping down the plains...
Re: Amp Settings
Quote:
Originally Posted by coldsteal2 View Post
Jake E Lee
Presence: 10
Treble: 10
Middle: 10
Bass: 10
Gain: 10
Dimes all the way!
I miss Jake E. Lee
indeedido is offline   Reply With Quote
Old 04-21-2010, 01:21 PM   #28
eljeffebrown
Senior Member
Re: Amp Settings
Quote:
Originally Posted by indeedido View Post
I miss Jake E. Lee
why you say it like that, is he gone?
__________________
Old 04-11-2012, 06:19 AM   #29
JCM900MkIII
JCM900MkIII's Avatar
Re: Amp Settings for AC/DC
Marshall JCM900 MkIII with JJ E34L power tubes
Amp boosted by Fulldrive II with Vol 1 o'clock, Tone 12 o'clock and the Overdrive 11 o'clock, with Compression Cut switch on (Comp Cut adds bottom end and chord clarity), Boost/Distortion is not needed.
Presence: 0 (this also adds bottom end)
Treble: 9
Mids: 5
Bass: 8
Gain: 0 (this disengages the crappy diodes)
Preamp: 6 to 7 (this provides that AC/DC medium dirty gain)
__________________
Amps:
1978 Marshall JMP 2204 MkII w/6550's
1990 Marshall JCM900 2500 MkIII w/EL-34's
2004 Marshall 1960B Cabs
1986 Carvin X-100B 100w
2008 Carvin GX412T Cab
Guitars:
1979 Gibson Les Paul Custom Black Beauty
2009 Gretsch Malcolm Young Sig Flame Maple
1998 Gretsch Electromatic Double Jet Black
2010 Fender Special Run Butterscotch Tele
Overdrives:
Barber Direct Drive v3
Visual Sound Route 808 v2
JCM900MkIII is offline   Reply With Quote
Old 04-11-2012, 09:56 AM   #30
Ken
Senior Member
Ken's Avatar
Re: Amp Settings
OMG..this is an old thread! I used to put my mids on TEN!! LOL These days it's more like 4. Very little sounds good on a DSL on 10. Just the gain on the green or volume on either!
Ken
__________________
1999 Marshall DSL 50
Late 1970's (?) Fender Champ
Marshall battery amp
PRO 4x12 from the 1970's
Woodson 2x12
1976 Les Paul Standard
Epiphone Les Paul knockoff
ESP Lawsuit Explorer
1979 Chiquita Travel Guitar
1995 Taylor 310
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
