MarshallForum.com
Reply
Thread Tools Display Modes
Old 01-08-2012, 01:00 AM   #1
Drewby
Senior Member
Drewby's Avatar
Modding a Plexi. Advice Please.
I want to get a 1959sl or a 1987 and mod it. I'm relatively new to amp mods so bare with me. I'd like to install a MV and increase the gain into VH, and Randy Rhoads territory. I'd like to keep the low input channel and mod the lead channel. On the lead channel I'd like to be able to go from ACDC to RR and maybe even a bit hotter. I would just keep the rhythm channel stock. Are these mods possible? Could you recommend some mods that would do this? Thanks in Advance!
Drewby is offline   Reply With Quote
Old 01-08-2012, 08:31 AM   #2
Goosey
Senior Member
Goosey's Avatar
Re: Modding a Plexi. Advice Please.
Adding another gain stage maybe? Get the amp first and see how you go, maybe just boosting it with a pedal is the way to go?
__________________
Marshall TSL100
EVH 5150III 50W
Marshall 1960BX Cab (25W Greenbacks)
2011 Gibson Les Paul Traditional
Charvel San Dimas Tele USA
Kramer Pacer Classic
Epiphone Appetite Les Paul Standard
Washburn WR-150
Cort MR710F Acoustic
Goosey is offline   Reply With Quote
Old 01-08-2012, 10:13 AM   #3
Ken
Senior Member
Ken's Avatar
Quote:
I agree. You seem to have a sound in your head, so before you start trying to reinvent the wheel, see what some pedals will do. Then maybe add the MV. Unless you just want to "mod an amp"; in that case your finished product is a moving target..
Ken
__________________
1999 Marshall DSL 50
Late 1970's (?) Fender Champ
Marshall battery amp
PRO 4x12 from the 1970's
Woodson 2x12
1976 Les Paul Standard
Epiphone Les Paul knockoff
ESP Lawsuit Explorer
1979 Chiquita Travel Guitar
1995 Taylor 310
Ken is offline   Reply With Quote
Old 01-08-2012, 01:18 PM   #4
Drewby
Senior Member
Drewby's Avatar
I actually had the chance to try out my buddy's 1987x. It sounded awesome but there wasn't enough gain for me. It sounded ok with a TS but I'd like to be able to get those VH/RR tones from the amp itself. Would Adding a gain stage make a huge difference?
Old 01-08-2012, 03:08 PM   #5
Strateuphoria
Senior Member
Strateuphoria's Avatar
but you have a 2204?, RR played a cascaded 1959, the same amount of gain you'll get through a 2203. He just cranked he's more.
Strateuphoria is offline   Reply With Quote
Old 01-09-2012, 04:15 PM   #6
scat7s
V.I.P. Member
scat7s's Avatar
adding just one gain stage, WILL make a huge difference imo.
__________________
We're listening, and we're watching.
scat7s is offline   Reply With Quote
Old 01-09-2012, 04:32 PM   #7
MKB
Senior Member
Before you buy, you may want to try out a Vintage Modern, it is almost exactly what you describe. I first bought a VM because I realized I'd have to add all sorts of mods to a 1987 or 1959 to get what I wanted (gain boost, master volume, gain switching, etc). The VM had all that stock. I could not be happier with the VM.
MKB is offline   Reply With Quote
Old 01-09-2012, 04:33 PM   #8
demonufo
Banned
I generally tell people never to mod until they've had time to learn to live with an amplifier first off, so as they can really be sure of what they want to change.
And only change one thing at a time, and again, learn to live with the changes before moving on to the next.
Many people have been in a hurry to destroy perfectly good sounding amps.
Never buy an amp your unfamiliar with, with the idea that your going to mod it in exactly one direction, because things often turn out different. Sometimes less is more, and these things occasionally cause revelations that cause you to rethink everything, even the way you play. I've seen it happen many a time.
demonufo is offline   Reply With Quote
Old 01-09-2012, 04:47 PM   #9
core
Senior Member
core's Avatar
I've been down this road recently and was given a solution that works perfectly WITHOUT modding either my 72 SL or my 74 1987. Was originally going to mod it from the same guys who do Green Days/Sum 41's amps, crunch mod - Martin Golub and Doug Aldrich's high gain mod (this mod adds a fourth preamp tube) here. L.A. Sound Design
BUT instead realizing I love the natural sound of the amp as it is and what I really needed was both clean and crunch and even into high gain. Dave over at LA Sound Design ended up selling me a pedal they distribute that worked PERFECTLY for what I need and I tell you it not only does not change the character of the tube amp but it replicated both the Green Day AC/DC crunch and higher gain lead tones. It was as if I had modded the amp. Sounds awesome at very low volumes, cranked stage volume or through an attenuator.
Take a look. Welcome to XAct Tone Solutions
I would highly recommend this for any early or late Marshall non master volume amp.
__________________
Aces & 8's
core is offline   Reply With Quote
Old 01-09-2012, 04:59 PM   #10
scat7s
V.I.P. Member
scat7s's Avatar
check out the lar/mar thread, the guys have been discussing the 'one wire mod', which i have just learned, is the cascaded V1 mod.
when i was scrapping my JTM45 clone together, since im only using one input, i cascaded V1....to me, it was too much, i put it back stock.
but im sure with a little planning, you could install that mod on a switch, which i still might do myself, since ive got a gainstage sitting and doing nothing right now. id like to be able to install it to operate with a footswitch. but i havent put much thought into how to do that yet.
seems like it should be doable w/o a lot of fuss though...at a minimum, with a manual switch mounted on the chassis.
__________________
Old 01-09-2012, 06:13 PM   #11
rjtm
Senior Member
rjtm's Avatar
You could always purchase an already modded one. I believe modded ones go for less or the same price as regular ones, and you could just buy it with the mod pre-installed. I agree with Ken, though. You should try some pedals on your friend's amp or at guitar center. Also, you will need to crank it to get a good distorted tone. The reason Randy and Eddie's tones were so good was because their amps were cranked, so you'll have to crank it somewhat to get near their tones
__________________
Marshall Silver Jubilee 2555
Marshall Silver Jubilee 2551AV Cab
Marshall YJM100
Marshall 1960b Cab
rjtm is offline   Reply With Quote
Old 01-09-2012, 06:24 PM   #12
scat7s
V.I.P. Member
scat7s's Avatar
not with the PPIMV mod. it kicks ass. turns a roaring marshall into an amazing home recording amp. just gotta get a moderate volume to push the speaks and get some nice hot levels.
__________________
Old 01-10-2012, 04:19 AM   #13
Strateuphoria
Senior Member
you should have posted a soundclip before you went back to stock, just to show how much gain is actually available from the standard JTM 45/1987/1959 platform, with the one wire mod and the PPIMV.
and just how right they got the design the first time, without knowing it.
But at the end of the day to get VH tone you need to crank it and overdrive the output tubes.
if any members here need help to do the one wire mod, easy steps. pm me.
Old 01-10-2012, 02:16 PM   #14
scat7s
V.I.P. Member
scat7s's Avatar
unfortunately, i dont have an easy computer recording setup. i have to record to tape, then burn it to cd, then dump it into my computer. not a dealbreaker, but im usually too lazy to bother with it...im still getting used to the extra gain in that 45 with a typical non-cascaded layout...i was playing much cleaner tones before, but the JTM45 just doesnt sound great to my ears on the cleaner side, it sounds best roaring.
i have to change my whole approach to playing thru this monster. its fun though. i would imagine i will eventually do the cascade again, but put it on a switch.
do you happen to know off the top of your head, if the cascade can be installed to operate on a ftswitch w/o having to use a relay? in some sort of short to gnd type of arrangement?
__________________
Old 01-12-2012, 12:56 PM   #15
slash38
Senior Member
slash38's Avatar
What rjtm said it would be cheaper to buy one already modded. It would be cheaper. Goodluck.
__________________
1999 Epiphone LP Standard Plus (SD Alnico II Slash)
2010 Slash Epiphone Appetite for Destruction LP
Marshall JCM SLASH 2555SL
Marshall 1960A 4x12 (G12T-75)
Marshall Slash SL5
slash38 is offline   Reply With Quote
Old 01-12-2012, 02:33 PM   #16
diesect20022000
V.I.P. Member
diesect20022000's Avatar
they do make amps for that
Old 01-12-2012, 03:17 PM   #17
Lespaulnmarshall
Senior Member
Lespaulnmarshall's Avatar
(foot)switchable 1 wire mod, lar/mar ppimv, zero loss FX loop, switchable bright cap. Heaven.
__________________
1987x .Every guitarist should have experienced it at least once
Lespaulnmarshall is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
