MarshallForum.com
Reply
Thread Tools Display Modes
Old 12-03-2011, 05:22 PM   #1
Macro
Senior Member
Macro's Avatar
How long do you warm up your tubes before switch on your amp?
I have a TSL and noticed that if I turn the amp on before letting the tubes get hot I get a horrible white noise that won't go away and results in no output from the guitar....just a waterfall water sound and nothing else.
On the other hand, if I let the tubes warm up for 4-5 minutes before taking the amp off standby I have no problems whatsoever....great tone, no problems, everything is perfect.
The tubes are the problem...already swapped them. It really isn't even an issue as long as I wait a few minutes for the tubes to get hot before I start playing.
I this normal? Is that just how long it takes or is something wrong with my amp?
Macro is online now   Reply With Quote
Old 12-03-2011, 05:25 PM   #2
Ken
Senior Member
Ken's Avatar
Re: How long do you warm up your tubes before switch on your amp?
Quote:
Originally Posted by Macro View Post
I this normal? ?
No.
You likely have a bad contact that becomes good again when the heat from the tubes expands the metal. Sooner or later your amp may fail; if you can check the solder connections yourself or bring it to a tech it might be a good idea.
An amp should warm up in under 30 seconds to make a sound. There's no drama associated with it.
Ken
__________________
1999 Marshall DSL 50
Late 1970's (?) Fender Champ
Marshall battery amp
PRO 4x12 from the 1970's
Woodson 2x12
1976 Les Paul Standard
Epiphone Les Paul knockoff
ESP Lawsuit Explorer
1979 Chiquita Travel Guitar
1995 Taylor 310
Ken is online now   Reply With Quote
Old 12-03-2011, 05:43 PM   #3
rjtm
Senior Member
rjtm's Avatar
Quote:
Originally Posted by Ken View Post
No.
Ken
+1. Its probably a bad contact that becomes good with the heat. You should get that checked out. I usually let my amp warm up for around 2 - 5 minutes while I warm up and let it cool down for a minute or two after turning it off.
rjtm is offline   Reply With Quote
Old 12-03-2011, 05:59 PM   #4
DSL100 Dude
Senior Member
DSL100 Dude's Avatar
At least two minutes to warm up.
At least two minutes to cool down.
I am a firm believer that if the standby switch is there, why not make use of it.
__________________
1987x
DSL 100
Class 5
Class 5 Rojo
G30RCD
1960A
Quote:
Originally Posted by StootMonster View Post
My friend, deep down - every guitar longs to play the blues. Even the BC Rich Bitches...
Heck, I even was doing a little blues on my 2 year old's Ukulele the other day.
Quote:
Originally Posted by Lespaulnmarshall View Post
...LESS BITCHIN' MORE PLAYIN'!
DSL100 Dude is offline   Reply With Quote
Old 12-03-2011, 06:07 PM   #5
NaturalBornBoy
NaturalBornBoy's Avatar
Not normal at all. My Legacy did that a few months back and I didn't do anything about it immediately. Bad move cos it cost me a few SGRs and two red-plated tubes.
My tech said that a few of the components were on its last legs and were acting up when the amp heated up.
NaturalBornBoy is offline   Reply With Quote
Old 12-03-2011, 06:15 PM   #6
diesect20022000
V.I.P. Member
diesect20022000's Avatar
standby's there for tube life when NOT playing. if that is unclear you can get proper info on here in the tech section, from any major amp maker or electronics site but, to each their own there.
Basics of Tube Amps for Beginners
as far as your amp goes no it's not normal take it to a take and for warming up the tubes....again it's only needed for more than 60 seconds IF your amp is stored in a non heated environment in the winter as glass tubes and heat makes breakage.
Old 12-03-2011, 06:29 PM   #7
Stringjunkie
Senior Member
Stringjunkie's Avatar
The book on my new amp recommends 4 mins. warmup on standby for the "best tube life"
__________________
EVH 5150 III 50w 1/2 stack
Sourmash 1x12/WGS Reaper
Sourmash 1x12/WGS Retro 30
Ibanez RG- MHD pups
Gibson LP 50s tribute studio-490r/498t
Gibson V-dirty fingers
"My point is if you are legit then there is no reason to clear anything to anyone. Do not bother."
Mickeydg5
Stringjunkie is offline   Reply With Quote
Old 12-03-2011, 06:30 PM   #8
ESPVH
Senior Member
ESPVH's Avatar
30 sec's
__________________
'scuse me tarbender, take me drunk! I'm HOME!
ESPVH is offline   Reply With Quote
Old 12-03-2011, 06:31 PM   #9
80's Rocker
Senior Member
80's Rocker's Avatar
I usually turn on my amp, put my strap on my Les Paul, tune up and then standby on. Takes couple minuits give or take. I need a new indicator light bulb tho because mine is burned out lol.
__________________
80's Rocker is offline   Reply With Quote
Old 12-03-2011, 06:49 PM   #10
RiverRatt
V.I.P. Member
RiverRatt's Avatar
I agree with diesect. I usually turn both switches on at the same time. I like hearing the fade-in. It usually takes 10 or 15 seconds to start producing sound. If I leave the amp unattended for more than a minute or two, I put it on standby.
Anybody old enough to remember the old black & white all-tube televisions? They didn't have a standby switch. Neither did hi-fi sets and radios. It certainly doesn't hurt anything if you want to use the standby switch, though. If it makes you feel safer then by all means do it.
Macro, you said you already swapped the tubes. Did you change all of them or just the preamp tubes or the power tubes? I've had noisy 12AX7's that had to get really hot before they quiet down and sound right.
__________________
Quote:
Originally Posted by MartyStrat54 View Post
That's what I like about you Alan...you got it bad. You're a tube-aholic.
Quote:
Originally Posted by dreyn77 View Post
IT's JUST A MAGNET AND A WIRE!!!!!!!!!!!!!! GET OVER IT!!!!! BIG DEAL!!!!!!!! WOOHIPY!!!!!!!!
RiverRatt is offline   Reply With Quote
Old 12-03-2011, 06:56 PM   #11
rjtm
Senior Member
rjtm's Avatar
Well I mean it doesn't hurt to do it if it increases the longevity of the tubes. Thats why I do it
Old 12-03-2011, 07:02 PM   #12
TwinACStacks
Senior Member
TwinACStacks's Avatar
I don't use the Standby as the Vox is Tube Rectified, so I guess the answer is ZERO minutes.
TWIN
__________________
Quote:
Originally Posted by triftstrassa View Post
Are you retarted?
Quote: longfxukxnhair
I knew they were wrong. I can find my ass with both hands
Jm D1 Trusted by more musicians than Fed Ex
Want to make GOD laugh? Tell him about your plans.
TwinACStacks is offline   Reply With Quote
Old 12-03-2011, 07:09 PM   #13
RiverRatt
V.I.P. Member
RiverRatt's Avatar
I've just never worried about tube life that much, especially with NOS power tubes. Most of the old ones are easily good for 3,000 to 5,000 hours if you maintain your amp. That means if you play an hour a day every day of the year, you could expect at the very minimum 10 to 15 years of tube life.
__________________
Old 12-03-2011, 07:32 PM   #14
American Viking
Senior Member
American Viking's Avatar
Tubes contain moving electrons. These electrons do not move in a cold tube. The standby switch allows the heaters to heat the electrons in the tube before they are put into "play mode". Turning the amp on without using standby is about equal to pouring hot water on your windshield to defrost it when it's covered in ice. The electrons are "shocked" into use and fall dead and lifeless. The less electrons moving in the tube, the less efficient it will work, the less volume you will get and so on and so forth. Eventually the tube will cease to function.
So in short, the standby protects the life of your output tubes and doesn't have an effect on the amp. Since tube amps don't work without tubes I use the standby in every case. 30 seconds is the bare minimum you really need to let it warm up. Out of habit most players will turn the amp on and hang out for a minute or two before going right into "play mode". That is a safe practice.
There is absolutely no need in letting the amp "cool down" in standby. Off is off.
American Viking is offline   Reply With Quote
Old 12-03-2011, 07:43 PM   #15
61rocker
Senior Member
61rocker's Avatar
Send a message via Yahoo to 61rocker
I like my tubes hot, so I'll turn on my amp and let it sit on standby for "a while"....after reading some comments here, I have to ask: Is this bad for the amp?...I have done this with every tube amp I've ever owned and not ever had any kind of problem...The obvious to me would be to reduce tube life....
__________________
'71 Marshall 1959 100w Super Lead
'82 Marshall 2203 JCM800 100w Lead
'87 Marshall 2210 JCM800 100w Lead
'91 Marshall 2599 JCM900 100W MKIII
'03 Marshall JCM2000 DSL 100w Lead
'82 Marshall JCM800 1960A w/G12-65s
'85 1960A Marshall 4x12 Cab w/Checkerboard Grill
'95 1960A Marshall 4x12 Cab w/Vintage 30s
'78 Gibson Firebird III
'82 Gibson Les Paul Custom
'95 Gibson SG Standard
'04 Gibson Custom Shop 1960 ReIssue
'07 Gibson Les Paul Standard Double Cutaway
'12 Fender American Special Telecaster
61rocker is offline   Reply With Quote
Old 12-03-2011, 07:46 PM   #16
S÷ulcaster
V.I.P. Member
S÷ulcaster's Avatar
first thing i set up is my head so i can turn it on straight away and let it warm up as i set my pedals and guitar up so probably id say roughly 10min warm up
i also leave the amp totally off for at least 10mins(longer if possible) to cool down b4 i move my amp after finished playing i dont like to feel any heat coming from it when i put the cover on her or take her out to my car(worried about the hot tubes hitting the outside air)
S÷ulcaster is offline   Reply With Quote
Old 12-03-2011, 08:02 PM   #17
Macro
Senior Member
Macro's Avatar
Thanks for the replies guys. A little while ago I turned the amp on and only gave it maybe a minute or two and had no issues. The white noise sounds happens intermittently, and I have suspected a loose solder joint that expands when the tubes get hot. Maybe tomorrow I will pull the board out and go over it with my glasses on.
Old 12-03-2011, 08:23 PM   #18
diesect20022000
V.I.P. Member
Quote:
it's not "bad" but, you're wearing the tubes if the amp's on. I sit here like right now and type with my amp on and standby off. when i'm on here i'm practicing so i'm letting it run all the time,lol. it just uses the tubes but, it won't hurt your amp at all.
Old 12-03-2011, 08:37 PM   #19
blues_n_cues
V.I.P. Member
blues_n_cues's Avatar
this. 'nuff said.
i usually plug everything in,hook it up, turn it on, go get a glass of iced tea, & come back and make sure it all rolls out right before breaking a sweat.
__________________
LIFE,LIBERTY,& the pursuit of TONE.
2007 Epi LP Custom LTD.
1991 Jackson DK-2 HSS
2010 Austin LP GT w/ P90s
custom rebuilt Washburn BT-2 Maverick
Marshall JMP-1 (rack)
Marshall CODE 100 (eventually) lol
a bunch of other carp
my music,sounds,samples,& snippets-
http://www.reverbnation.com/rlcltd
https://soundcloud.com/rlc-ltd
Stratisfied
https://soundcloud.com/rlc-ltd/stratisfied
just riffing
https://soundcloud.com/rlc-ltd/just-riffage
blues_n_cues is offline   Reply With Quote
Old 12-03-2011, 10:10 PM   #20
Rafał
Senior Member
But you know that on standby the tubes aren't getting any colder (hell, you are using it to warm them up) so why wait before turning the amp off? Or did you mean something different while writing "two minutes to cool down"?
Nevermind, I guess you meant 2 mins before moving the amp.
Rafał is offline   Reply With Quote
Old 12-03-2011, 10:18 PM   #21
rjtm
Senior Member
rjtm's Avatar
Thats another thing to remember, make sure to let the amp stay for at least a few minutes after turning it off before moving it
Old 12-03-2011, 10:21 PM   #22
Rafał
Senior Member
Quote:
Glad I got it right (about no need to wait before turning it off, but waiting before moving it). I feel kinda safer now.
Old 12-03-2011, 10:24 PM   #23
blues_n_cues
V.I.P. Member
that's why any good band quits 15 mins before"last call". our last call is always @ least 2 hours after last call- & the money is counted.
__________________
Stratisfied
just riffing
Old 12-03-2011, 10:48 PM   #24
Marshall Mann
Senior Member
Marshall Mann's Avatar
There is no proof that warming up a tube by leaving the amp in stand by has any benefit. If the heaters are hot enough to excite the electrons in the tube, it will operate. Period. You cant "shock" electrons in to use.
As River Ratt said, for years, TV's, stereos and yes, amps, did not even have a stand by switch.
By way of direct example - I recently re-tubed an early 80's Laney AOR for a friend that came stock without a stand by switch. It has seen regular use since 1987. I pulled the stock tubes out of it this year. They were still operating after 27 years of regular use WITHOUT a warm up period. If turning on the amp with out a stand by "warm up" period was harmful to the tubes, his stock tubes would have failed years ago.
I have also seen tubes fail after only a couple of years even with using the warm up / stand by method.
If it makes you feel better to warm up your tubes, go ahead. It's certainly not hurting anything (unless your warming them up or leaving them idle for excessive time periods). But there is no proof that you are extending the life of your tubes by doing so.
__________________
Quote:
TwinACStacks "BTW: I AM going to own a 6100 sometime. Then I'm gonna mod the EVER-LOVIN' **** out of it....Just to piss these guys off.
Marshalls a Mesa and mostly Les Pauls
Marshall Mann is offline   Reply With Quote
Old 12-03-2011, 10:56 PM   #25
FFXIhealer
Senior Member
FFXIhealer's Avatar
Quote:
What amp model do you have? I was able to pull the red power switch for my Lead 12 out far enough to pull the switch apart, find the broken line and resolder it so the light worked again...all without having to remove a single wire from the switch in the first place. But I found that out AFTER I got the replacement switch. Oh well, if the switch goes out, I'll always have a replacement handy, I guess.
__________________
2007 Marshall JVM410H + 1960A Lead
2011 Fender Mustang V + V412
2010 Fender Mustang II
1985 Marshall Lead 12 3005 Microstack
2012 Marshall JTM1H
2012 Marshall JMP1H
2011 Gibson Les Paul Custom Silverburst
2012 Gibson SG Special Faded
2009 Fender American Special Stratocaster
2007 Hagstrom Ultra-Swede
Custom Warmoth Strat with S/D pickups
FFXIhealer is offline   Reply With Quote
Old 12-03-2011, 11:04 PM   #26
jvm210guy
Senior Member
jvm210guy's Avatar
Is it bad if I plug in my guitar and can't notice if the amp is on or off?
__________________
THE SIG OF DEATH
Tiny Terror
Marshall Class Five
JVM 210h
1960a Lead (v30's/g12-75's)
2008 American Standard Telecaster
2008 Gibson Traditional Les Paul Plus (cherry sunburst flametop)
jvm210guy is offline   Reply With Quote
Old 12-03-2011, 11:14 PM   #27
diesect20022000
V.I.P. Member
Quote:
too much gain man
Old 12-03-2011, 11:38 PM   #28
Cosmik de Bris
Some tube "experts" claim that leaving valves on standby for long periods of time cause the emitted electrons to bombard the other plates and cause deterioration in them. I don't know whether this is a factor in valve life or not. There is a lot of myth on the Interweb.
Cosmik de Bris is offline   Reply With Quote
Old 12-03-2011, 11:39 PM   #29
mickeydg5
V.I.P. Member
mickeydg5's Avatar
I have an older tube stereo, no stanby, if the reciever is on you can hear tubes kicking in.
Lots of tubes were used in mobile equipment while operating, with means they were thrown around a lot more than your amp.
mickeydg5 is online now   Reply With Quote
Old 12-03-2011, 11:49 PM   #30
Ken
Senior Member
Ken's Avatar
Quote:
Originally Posted by diesect20022000 View Post
standby's there for tube life when NOT playing. .
I'm actually not even sure it does that...I have a hunch it's a placebo switch. That being said, I still put the amp on standby between sets, and turn it on after the power switch and off before the power switch. Old habits die hard.
Ken
__________________
Woodson 2x12
1995 Taylor 310
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
