MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 11-23-2011, 01:22 AM   #1
Lespaulnmarshall
Senior Member
Lespaulnmarshall's Avatar
2X12 cab wiring diagram
Hey guys,
My 2X12 cab with two 8 ohm EVM12L's in it is now wired like two independent speakers in one cabinet. So it's like using 2 1X12's in a single cabinet.
Is this the best way to wire the cab for using it with two amps or would it be better to wire it in stereo with two inputs? Preferably at 8 ohms. Doesen't matter if it's wired in series or parallel. I'm not planning on using it in combination with another cab.
__________________
1987x .Every guitarist should have experienced it at least once
Lespaulnmarshall is offline   Reply With Quote
Old 11-23-2011, 07:54 AM   #2
Adwex
Super Moderator
Adwex's Avatar
Re: 2X12 cab wiring diagram
Quote:
Originally Posted by Lespaulnmarshall View Post
Hey guys,
Using it like 2 1x12's in a single cabinet, and, wiring it in stereo with two inputs....are the same thing. I'm not sure what you mean.
Do you want to use both speakers together with one amp? If so, it'll never be 8 ohms.
Old 11-23-2011, 09:31 AM   #3
Lespaulnmarshall
Senior Member
Before I swapped the speakers the previous owner, who built it wired it up with four XLR jacks on the back two were inputs the other two were used to jumper the inputs when only using one input when you want to use both speakers. Both speakers in the cab were 8 ohms and the total impedance was 8 ohms. (when using both speakers.
Right now the sound of each amp comes out of one speaker. But with a 'normal' wiring shouldn't the sound of both amps come out of both speakers?
__________________
Old 11-23-2011, 09:58 AM   #4
hbach
Senior Member
hbach's Avatar
With a switch and two jacks you can have all the combinations. 8 Ohms per side which you have now, 4 Ohms both speakers and 16 Ohms both speakers.
hbach is offline   Reply With Quote
Old 11-23-2011, 10:00 AM   #5
hbach
Senior Member
hbach's Avatar
You can't connect two amps to the same speaker(s) without damaging the amps.
Old 11-23-2011, 03:20 PM   #6
Lespaulnmarshall
Senior Member
Quote:
Okay thanks.
__________________
Old 11-23-2011, 04:16 PM   #7
Marshall Mann
Senior Member
Marshall Mann's Avatar
I dont see how this is possible with a 2 - 12 set up? Based on 8 ohm speakers, you can yield 4 ohms (parallel) or 16 ohms (series) but not 8 ohms.
__________________
Quote:
TwinACStacks "BTW: I AM going to own a 6100 sometime. Then I'm gonna mod the EVER-LOVIN' **** out of it....Just to piss these guys off.
Marshalls a Mesa and mostly Les Pauls
Marshall Mann is offline   Reply With Quote
Old 11-23-2011, 04:56 PM   #8
hbach
Senior Member
hbach's Avatar
It would not be 8 Ohms both speakers but "stereo" as LPnM has now each speaker separate for two different amps.
You are right 8Ohms out of two 8Ohm speakers can't be done.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
