MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 11-13-2011, 11:49 PM   #1
sccloser
Senior Member
sccloser's Avatar
Which speaker for dsl 401
Ok, I guess I am going to HAVE to change the speaker in the dsl 401 if I am going to be able to use it at band practice. I did a lot of tweaking and all with it and had it sounding pretty good at home, but I was playing it through a 1960 cab. I took it to practice today and played through it and it sounded like crap. It was OK by itself, but would not cut through the mix. I tried to eq it, but it ended up sounding like it had an aluminum foil speaker. I have never heard any marshall amp sound so sh...crappy my whole life. It was embarrassing it sounded so bad. The other guitar player had a legend 50 combo that sounded like a 1959 sl compared to my amp!
So, what speaker do I need? Somebody help me. The Class 5 just blows this amp away and it should not. We are talking paper thin sound. The only time this amp even sounds close to decent with a band is when I play on the clean channel cranked, and even then it still was kinda thin.
Marty...speaker-man!
I mostly play classic rock. Heavy on 70/80's.
__________________
1983 Marshall JCM 800 4210 modified
1986 Marshall JCM 800 2205
1991 Marshall JCM 900 Mkiii 2500
2010 Marshall Class 5 Combo
JCM 800 Lead Series 1960b cab
JCM 900 Lead Series 1960a cab
1960 ax cab (greenbacks)
sccloser is offline   Reply With Quote
Old 11-13-2011, 11:51 PM   #2
rjohns1
Senior Member
rjohns1's Avatar
Re: Which speaker for dsl 401
Greenback or Vintage 30. A lot of guys like the Vintage 30 in that amp. I'm not experienced with pther brands, I've always used Celestions. Some one else will chime in I'm sure.
__________________
"Everything electronic runs on smoke. Forget all that electron nonsense.
Notice how stuff stops working when you let the smoke out?"
rjohns1 is offline   Reply With Quote
Old 11-14-2011, 12:26 AM   #3
MartyStrat54
V.I.P. Member
MartyStrat54's Avatar
The main things to be concerned about with a 1 X 12 combo is efficiency and tone. You want to get the most volume out of the 401 that you can.
In the Eminence Patriot Series, I would say try the Black Powder or the Red, White and Blues.
In the Eminence Red Coat Series, I would recommend the Man 'O War, the Governor or the Tonespotter.
You see, some speakers sound great when you play them in your room. However, in a band mix, that same speaker can suck air. You need a speaker that kicks out some good mids to cut through the mix.
Please note-Not all of the speakers I listed are available as 16 ohm. If I had to pick one for your style, it would be the Man 'O War, 16 ohm.
__________________
Old 11-14-2011, 12:50 AM   #4
thrawn86
Senior Member
Can't use a Greenback, unless it's the 65w version or whatever it is. Greenbacks are only 25w and you'd end up blowing it. I still tout the extension cab.
__________________
-Martimus Maximus Tone Packs - MHD Pickups - OFA Pedals-
thrawn86 is offline   Reply With Quote
Old 11-14-2011, 01:10 AM   #5
sccloser
Senior Member
sccloser's Avatar
It sounds pretty good through my 1960a or my 1960ax, but if I have to lug a cab along then it kind of defeats the purpose of why I wanted to use a combo.
I have been using the Class 5, but thought I'd try the dsl tonight because I thought I could switch between different gain settings easier with no extra pedals and I could get a little cleaner sound I though. I was most shocked when I stepped out directly in front of it, about 12 feet away and got hit with the "beam!" I just wanted to crawl into a hole it sounded so bad. I guess I could just get the coffee can lid back out and tape it on the front as a diffuser again. That gold back speaker just sounds like crap...like th econes are aluminum foil or something. Crap, I could put a piece of paper against my comb and blow through it for a better tone. I am just disgusted with it.
__________________
Old 11-14-2011, 01:14 AM   #6
thrawn86
Senior Member
Yeah, I didn't like the original speaker either. I'd go with Marty's rec's, since he knows his stuff.
__________________
Old 11-14-2011, 01:18 AM   #7
sccloser
Senior Member
sccloser's Avatar
Marty, how does the man o war compare to the wgs veteran 30?
__________________
Old 11-14-2011, 01:20 AM   #8
sccloser
Senior Member
sccloser's Avatar
Quote:
A couple of years back I took the dsl 401 to like 1 or 2 band practices, then just started playing my 2205 half stack because it sounded so thin back then. I thought I had it tweaked...
__________________
Old 11-14-2011, 01:22 AM   #9
JohnH
Senior Member
JohnH's Avatar
Yes, in my case a V30 and a home-made beam blocker behind the grill cloth. And EQ in the loop for more bass on OD, unless i have my 1x12 cab under it.
If you want a simple $5 project, ask me about my bass boosting patch cable designed for this amp - to do that EQ job .
John
__________________
DSL401
Crate Powerblock
1 x 12 Vintage 30 cab
'76 Shergold Masquerader
'91 Les Paul Studio
'83 Roadstar
'10 American Special Strat HSS
JohnH is offline   Reply With Quote
Old 11-14-2011, 01:25 AM   #10
sccloser
Senior Member
sccloser's Avatar
I have the fx loop jumped with a patch cable to get more oomph out of it.
If I go to the trouble to change speakers, I would hope I would not still need a beam blocker/diffuser.
__________________
Old 11-14-2011, 01:41 AM   #11
diesect20022000
V.I.P. Member
diesect20022000's Avatar
WGS greet beret OR blackhawks. alnico speakers are awesome man. I think it's blackhawk...anyway they have some lower wattage alnicos. if you're playing anything but, modern metal (and i'd still use 'em for it but, i like modern meets vintage) they have some great options. at 20-40 watts clean i'd say double it so you can still get some vintage speaker breakup without killing it.
imo a green beret and aan alnico 2x12 would be amazing for that amp but, i know you're looking for a swap not an extension setup.
Old 11-14-2011, 10:14 PM   #12
MartyStrat54
V.I.P. Member
The Eminence Governor = Celestion V30
The Eminence Man 'O War = Celestion G12T-75
The Eminence Tonespotter = Celestion G12-65
Please note that the Eminence speakers have their own tone. I really don't think they sound that close except for the Tonespotter. The Man 'O War has some super chunky midrange and it is very loud. It would be like using a lower efficiency speaker and a DSL50. Yes, you can get the 401 to be as loud as a DSL50 with the right speaker. The MOW is rated at 102dB with one watt. To me, it sounds much better than a Celestion G12T-75. I run a pair in my TSL122 and it is as loud as most 412 cabs.
The other thing is the speakers I picked will work with an open back cab. Some speakers can only be used in a sealed cab. You need to consider that.
The VET 30 has a "cleaned up" midrange and is not spikey like the Celestion V30. So it is a smoother sounding speaker. The MOW is more aggressive sounding. Very articulate and is 4dB louder than the VET 30. That is a big difference with a 40 watt amp.
__________________
Old 11-20-2011, 02:11 PM   #13
SmokestackElRopo
Senior Member
SmokestackElRopo's Avatar
Marty how close should a speaker be, to the output wattage of the amplifier? In this case I am also using a DSL 401.
__________________
Marshall VM 2266C
Marshall JTM 45
Marshall JCM 900 4102 5881 combo
Marshall 1922 cab w/ Eminence wizards
Marshall 1936 w/ eminence Barkin blues spkrs
Marshall Valvestate VS100R combo
Marshall VS102R combo
Marshall DSL 401 w/ eminence Red Fang spkr
Marshall DSL 100
Marshall Class 5 head
Gibson Les Paul standard (2007) with guitarforce Lord of the blues pups
Gibson Les Paul supreme goldtop (1 of 400)
Cheap tone ain't good and good tone ain't cheap.
SmokestackElRopo is offline   Reply With Quote
Old 11-20-2011, 04:24 PM   #14
SmokestackElRopo
Senior Member
I found my answer in search. I believe that I will go for the Red fang. I hope that Sccloser gets his deal straightened out. I like the Red Fang due to the alnico magnet but it triples the price.
__________________
Marshall VM 2266C
Marshall JTM 45
Marshall DSL 100
Old 11-20-2011, 05:42 PM   #15
50 watt CJ
Junior Member
I have a dsl201 that sounds great with a 30 watt 70th anniv g12H. Of course yours being 40 watts needs a higher rating. I also have a 212 loaded with 60 watt neo magnet celestion century vintage speakers that sounds killer. They have a nice warm sound. Give those a try, they weigh like 2 pounds-which is a treat! Some guys won't go near 'em because they don't have your traditional ceramic magnet. I like speakers that don't kill you with high end. I do not like the std 75 watt celestions at all-no mids whatsoever and too much treble. Check out a cd called cone tones. It's great. It has demos of all kinds of 12 in speakers to hear. It helped me make a few purchases I ended up being happy with, like the century vintage.
50 watt CJ is offline   Reply With Quote
Old 11-20-2011, 05:44 PM   #16
MartyStrat54
V.I.P. Member
I'm running the Red Fang in mine and have for about two years. I actually got mine before Eminence bumped the price up. All ALNICO speakers are pricey.
__________________
Old 11-22-2011, 03:40 PM   #17
Frankie
Senior Member
Frankie's Avatar
I say V30 too! I just threw one in my 1x12 Haze combo and it sounds pretty much awesome. I have an extra one, new in box that I'd sell you if you're interested. Shipping shouldn't be much from FL to SC.
__________________
"Motorhead meets the Ramones and NY Dolls."
Frankie is offline   Reply With Quote
Old 04-07-2013, 04:54 PM   #18
j in SM
Junior Member
For others that run across this thread who are looking for a good replacement spearker for the DSL401.
Just installed a Weber silver bell, ceramic, 75 watt, medium dope, in my DSL401. It is now much closer to the amp I thought it could be. All channels sound better: everything is thicker, no more fizz or tin sound, and the amp still retains great sustain and crunch and is much closer to what I expected for a true marshall sound.
j in SM is offline   Reply With Quote
Old 04-07-2013, 05:30 PM   #19
MartyStrat54
V.I.P. Member
Yeah that Weber stuff is tops. I just did a piece on them over in my "Everything About Speakers" thread.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
