MarshallForum.com
Reply
Thread Tools Display Modes
Old 10-23-2011, 09:08 AM   #1
Lespaulnmarshall
Senior Member
Lespaulnmarshall's Avatar
1987x LAR/MAR PPIMV mod
20 minutes ago I finished modding my 1987x.
Tried it and it sounds pretty good to me. Haven't cranked it up higher than 8:30 o' clock for longer than a second, but I can say that at low volume levels it sounds better than any attenuator I have tried so far.
Pics:
Before starting:
5K6 swamp resistors installed:
Gnd5 and QR wires and 220k resistors removed! Bias wire installed:
Installed the other wire:
Under the PCB:
Wires that go to pin 5 of the power tubes installed:
Wired up the pot:
Hole drilled in chasis:
Ready to install the pot:
Ready to put it back in it's cabinet:
Done!
Cheers!
__________________
1987x .Every guitarist should have experienced it at least once
Lespaulnmarshall is offline   Reply With Quote
Old 10-23-2011, 09:39 AM   #2
hbach
Senior Member
hbach's Avatar
Re: 1987x LAR/MAR PPIMV mod
Congratulations! Was this your first mod?
hbach is offline   Reply With Quote
Old 10-23-2011, 09:49 AM   #3
Lespaulnmarshall
Senior Member
Quote:
Thanks!
No, I've moddded my 800 before. I have done some mods on pedals and guitars too.
__________________
Old 10-23-2011, 12:45 PM   #4
Midnight Blues
Senior Member
Midnight Blues's Avatar
Nice job!
Has anyone tried this on a 1959?
__________________
Midnight Blues
Midnight Blues is offline   Reply With Quote
Old 10-23-2011, 05:18 PM   #5
Lespaulnmarshall
Senior Member
Quote:
Originally Posted by Midnight Blues View Post
Nice job!
Thanks, midnight!
Many people have. Should work just as well as on my 1987. The mod is exactly the same, except that the wires that go to the power tubes go to V4 and V6 (there are jumpers between pin 5 of V4 and V5 and pin 5 of V6 and V7 on a 1959) instead of V4 and V5.
__________________
Old 10-23-2011, 07:13 PM   #6
hbach
Senior Member
hbach's Avatar
I have it on my 2061 clone and it works great too. It just uses a different pot value.
Old 10-23-2011, 08:18 PM   #7
TradAmpGuy
Senior Member
TradAmpGuy's Avatar
Nice job!
I have one on my 1959 clone and it kicks ass
__________________
TradAmpGuy aka Brian
http://www.tradamps.com
http://www.facebook.com/tradamps
1959 clone, modded (too many to list)
Tweed Twin clone
Tweed Deluxe clone
Ampeg V4... not a clone
Ovation Viper with DiMarzio PAF (n), SD (b), coil taps
Quote:
Originally Posted by American Viking View Post
I am at work at just trying to type fast and move on so it looks like I'm doing something.
Quote:
Originally Posted by TwinACStacks View Post
*wiping away the tears* OH ****, I peed myself....
TradAmpGuy is offline   Reply With Quote
Old 01-01-2012, 11:27 AM   #8
Neaves The Wicked
Senior Member
Neaves The Wicked's Avatar
Hi, I'm looking at buying at 1987x with the effects loop in the near future and would like to maybe have this mod done by a proffesional since I suck at this sort of stuff. Is there a schematic available for this?
Thanks, Josh
__________________
2009 1960A W.E.G.
2007 JVM410H
1997 DSL 50
2012 50th Anniversary DSL1 watt combo
2011 Class 5 Head
2008 1960AV
Check out our band.
www.EmpireDown.Com
or
www.Facebook.com/empiredown16
Neaves The Wicked is offline   Reply With Quote
Old 01-01-2012, 12:18 PM   #9
Neaves The Wicked
Senior Member
Oops Nevermind. I did some more research and using this mod in conjuction with an amp having an effects loop is not the best. I guess it's OD pedals for room volume and cranked for the stage
__________________
2009 1960A W.E.G.
2007 JVM410H
1997 DSL 50
2011 Class 5 Head
2008 1960AV
Check out our band.
www.EmpireDown.Com
or
Old 01-01-2012, 02:37 PM   #10
plexifier
Senior Member
plexifier's Avatar
Quote:
Originally Posted by Neaves The Wicked View Post
Oops Nevermind. I did some more research and using this mod in conjuction with an amp having an effects loop is not the best...
There shouldn't be any issue using a PPIMV in an amp with an effects loop. What concerns did you have?
plexifier is offline   Reply With Quote
Old 01-01-2012, 02:55 PM   #11
Neaves The Wicked
Senior Member
I read a post here in the forum mentioning something about since the PPIMV mod uses the PI that when using the effects loop it would be distorted because the PI works with the Effects Loop? Unless I completely read it wrong.
__________________
2009 1960A W.E.G.
2007 JVM410H
1997 DSL 50
2011 Class 5 Head
2008 1960AV
Check out our band.
www.EmpireDown.Com
or
Old 01-01-2012, 03:27 PM   #12
Lespaulnmarshall
Senior Member
I can send you the schematic and manual I found if I can find it somewhere haha. PM me your email.
__________________
Old 01-01-2012, 03:39 PM   #13
Neaves The Wicked
Senior Member
Awesome, Thanks!
__________________
2009 1960A W.E.G.
2007 JVM410H
1997 DSL 50
2011 Class 5 Head
2008 1960AV
Check out our band.
www.EmpireDown.Com
or
Old 01-01-2012, 04:34 PM   #14
plexifier
Senior Member
plexifier's Avatar
The effects loop is right before the PI and the master is after it so any effects should sound the same as they do without the PPIMV. You can make the PI overdrive a little more when turning down the PPIMV, mainly because negative feedback is reduced, but the overall sound from effects should be okay.
I've never heard anyone mention any problems when using the MV with a loop. However, my amps don't have loops so I can't say for sure based on experience.
Old 01-01-2012, 04:44 PM   #15
jonzguitar
Senior Member
jonzguitar's Avatar
Just wondering... do you use any modulation effects?
jonzguitar is offline   Reply With Quote
Old 01-01-2012, 04:45 PM   #16
Neaves The Wicked
Senior Member
Oh Ok what you said sounds familiar to what I read. Yup I messed that up,
Thanks Guys!
__________________
2009 1960A W.E.G.
2007 JVM410H
1997 DSL 50
2011 Class 5 Head
2008 1960AV
Check out our band.
www.EmpireDown.Com
or
Old 01-01-2012, 05:08 PM   #17
RickyLee
V.I.P. Member
RickyLee's Avatar
Cheers!
Good work!
What was the cable and the gauge of it that you used?
Did you use a dual 250K pot with the two 2.2MEG resistors?
Did you use metal flame or carbon comp or carbon film?
I want to try this mod on my '88 2205 as well.
Regarding the FX loop together with a PPIMV? I have the LarMar PPIMV on my Ceriatone 2555 which has an FX loop. There's no issues there. But the Jubilee loop is a very different topology than most loops, as the Jubilee loop is before/upstream of the tone stack and before the last gain stage as well.
The thing I've noticed with the PPIMV on the 2555, is that it is actually not all that useful. The Jubilee seems to actually get a bit harsher using the PPIMV and running the normal Master Volume up past 8. And the PPIMV negates the Presence circuit as well somewhat. I am actually thinking of removing the PPIMV on the 2555 and use the vacant hole to try something else. Maybe a Resonance control.
RickyLee is online now   Reply With Quote
Old 01-01-2012, 05:40 PM   #18
plexifier
Senior Member
plexifier's Avatar
Quote:
I use chorus occasionally but mainly just a couple of clean boosts. I have run a phaser and flanger in front of the amp and they sound fine. Just my opinion, but the only time you really need a loop is for reverb or delay when using a lot of preamp gain. I use an analog delay in front when clean or lightly overdriven and it works fine.
Old 01-01-2012, 06:06 PM   #19
Lespaulnmarshall
Senior Member
Quote:
Originally Posted by RickyLee View Post
Good work!
1) What was the cable and the gauge of it that you used?
2) Did you use a dual 250K pot with the two 2.2MEG resistors?
3) Did you use metal flame or carbon comp or carbon film?
1) I don't know I just got some decent size coax wire
2) I used a 220K pot, and the 2.2 meg resistors
3) carbon film
__________________
Old 01-01-2012, 08:11 PM   #20
RickyLee
V.I.P. Member
RickyLee's Avatar
3) carbon film
Coax cable like what is used on a cable box to TV?
Old 01-03-2012, 02:33 PM   #21
gldtp99
Senior Member
Many use RG-174 coaxial cable----- this has PVC inner insulation that is sensitive to heat so it can be tricky to solder in place---- there are other types with PTFE (aka Teflon) inner insulation available.
This place has several types listed---scroll down to Coaxial Cable: Wire
PS-- FWIW i use RG-174 and i'm careful when soldering it---- but Lar/Mar PPIMV's can be installed without using shielded cable----- it depends on the routing needed in the particular amp--- Here's a Lar/Mar PPIMV i put in an SIR #34 Mod Marshall 4010 --- twisted pairs work just fine in many cases----i just built a (mostly) Metro 50 watt 1987 clone (w/leftover Metro chassis, faceplates, turretboard, and PT) and i used twisted pairs for the Lar/Mar PPIMV on this one--no pics yet.
4010 with Lar/Mar:
gldtp99 is offline   Reply With Quote
Old 01-03-2012, 02:47 PM   #22
GIBSON67
Senior Member
GIBSON67's Avatar
I want to do this too, was it difficult? And we need sound clips...
GIBSON67 is online now   Reply With Quote
Old 01-03-2012, 02:57 PM   #23
Lespaulnmarshall
Senior Member
Yes, but stereo coaxial cable and just regular coax cable.
Regular for the bias wire (the thickest one)
And the stereo coaxial cable for the other wire.
__________________
Old 01-03-2012, 03:02 PM   #24
Lespaulnmarshall
Senior Member
Quote:
I'll try to record some soundclips when I have time. It wasn't very hard IMO, but I don't think it's a beginner mod. Wiring up the pot was tricky actually, especially the one I had, that is actually meant to solder onto a PCB. (no holes in the lugs) you can see the pot was tricky on the pic, my soldering on that pot is really nowhere near as clean as it usually is.
__________________
Old 01-03-2012, 03:14 PM   #25
gldtp99
Senior Member
The modded 4010 was one of the amps used in this demo of several SIR/AFD-type modded amps i built or modded--- the 4010 was used in the right rhythm track------ the lead tracks are the white 14/7 watt shown in the pic (#34 Mod preamp-- into EL84 x 2, cathode biased--- pentode/triode switch to drop from 14 to 7 watts).
No Lar/Mar PPIMV on the 14/7 but a similar 25 watter (6v6 x 2) i built does have a Lar/Mar.
Demo: SoundClick artist: gldtp99 - page with MP3 music downloads
Lar/Mar in the 25 watt #34 Mod:
i used twisted pairs from the board to the PPIMV pot and shielded cable (RG-174) from the pot to the output tubes on this one---i was concerned about interference from high voltage wires---- this one wasn't built initially with a Lar/Mar (added with the #34 Mod) so it isn't the best looking example i've ever seen ---it does work 100%---- the amp was built first as a near stock 25 watt JCM 800 with a "Power Dampering" type of MV----everybody likes it better like this--- this one wasn't used in the demo above--i had five total SIR/AFD-type amps to pick from for the musicians who played on the tracks--- three 50 watters (incl the 4010 above), the 14/7 used on the leads, and this 25--- this is the only one that didn't get used but it sounds pretty much the same as the others--- one player liked it the best out of all of them but it got lost in the shuffle in the studio that day......................gldtp99
Old 01-03-2012, 03:50 PM   #26
GIBSON67
Senior Member
GIBSON67's Avatar
Cool, sometime this year I will be doing the same. My amp is handwired and is a little Frankenstein anyway.
Nice clip gldtp99...
Old 01-03-2012, 04:52 PM   #27
Strateuphoria
Senior Member
Strateuphoria's Avatar
Now just need to add this very easy mod... and we're all done
ja nie te danke maatje
Strateuphoria is offline   Reply With Quote
Old 01-03-2012, 05:03 PM   #28
Lespaulnmarshall
Senior Member
Ha! Google translate!
I was actually considering a 1 wire mod, is there a way to make it switchable?
__________________
Old 01-03-2012, 05:26 PM   #29
Strateuphoria
Senior Member
een draad mit skakelaar, ik is 'n Afrikaner flaams
Old 01-04-2012, 05:19 AM   #30
Strateuphoria
Senior Member
are you going to do the onewire mod?
post soundclips!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
