MarshallForum.com
Reply
Thread Tools Display Modes
Old 10-23-2011, 12:16 AM   #1
Phil In Ottawa
Haltron EL-34 Tubes
I have a pair of Haltron EL-34 tubes. I've had them for a long time and can't even remember where I got them.
I had not looked at them in some time and looking a them now, something seems strange about one of them. It appears as if there is no silver coating inside the top of the tube. Just a bit of white.
Here's a picture of the two tubes:
Before I go ahead and plug these in to my amp, can anyone tell me if the one on the left is damaged or faulty in any way? Or is the lack of the silver coating not something I should be concerned about?
Also, I've read that Haltron would rebrand tubes made by other manufacturers. Can anyone tell if this is the case with these tubes? Here's a picture of the bottom if that helps. I read that the hole in the guide pin could indicate that they are from the early 60s. MaybeTeslas?
Thanks for any information you can provide.
Phil In Ottawa is offline   Reply With Quote
Old 10-23-2011, 02:14 AM   #2
thrawn86
Senior Member
Re: Haltron EL-34 Tubes
I'm no expert, but the tube on the left appears to be losing its vacuum. The grey/black material is called getter flash, a characteristic of when the tube is made. When they lose their vacuum, usually due to a crack, that area clears up and turns white eventually.
Someone else will chime in here, but I have a bad feeling that one is shot.
__________________
-Martimus Maximus Tone Packs - MHD Pickups - OFA Pedals-
thrawn86 is offline   Reply With Quote
Old 10-23-2011, 10:40 AM   #3
jcmjmp
Senior Member
Yeah, the tube on the left has lost its vacuum and is toast.
jcmjmp is offline   Reply With Quote
Old 10-23-2011, 11:25 AM   #4
MM54
Senior Member
MM54's Avatar
Quote:
Yes. Any time there is white inside a tube where it should be silver, it's bad. Don't put that in your amp - at best nothing will happen, at worst it could short all over the place.
In neither case can you play through it
__________________
-Matt
If you don't understand what I'm saying, assume I'm making a joke. Trust me.
Lachesky Amplifiers - Home of the CA10
Orders for 2013 CA10s are now being accepted!
"... And I come from a place
where they drag your hopes through the mud
because their own dreams are all dying"
MM54 is offline   Reply With Quote
Old 10-23-2011, 02:50 PM   #5
Phil In Ottawa
Thanks for the replies.
I was afraid the tube was toast since every tube I've ever seen had the silver inside.
I'm slowly educating myself about tubes and have been doing some reading. But there's one thing I'm wondering about and can't find an answer to. Here it is:
I had two pairs of spare tubes. The Haltron pictured above, one of which I now know is toast. The other spare set was a set of Marshall branded tubes. But I dropped one while moving some stuff around the other day and broke it. So that now leaves me with one of the Haltron and one of the Marshall.
In the reading I've done it always mentions matched tube pairs. So my question is, even though they would not be a matched pair (more than likely not even the same brand), could I use the two spare tubes I have (Haltron and Marshall) together in the amp? Or is it a bad idea to mix tubes? Would they even work together if they are too "unmatched"?
Thanks in advance for your help. This tube stuff is all new to me.
Old 10-23-2011, 03:26 PM   #6
thrawn86
Senior Member
Bad idea if they aren't close. They won't sound great.
__________________
Old 10-23-2011, 06:02 PM   #7
big dooley
V.I.P. Member
big dooley's Avatar
it depends on the amp... an AFD or YJM would deal with that effortlessly...
a DSL50 could do it too, if the tubes are not too far off, as each tube can be biased seperately...
so what kind of amp?
__________________
JVM, the only marshall that's been modded to tame it, instead of hotrodding it
big dooley is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
