MarshallForum.com
Reply
Thread Tools Display Modes
Old 01-04-2009, 12:11 PM   #1
JL mayze
Junior Member
Marshall 4140
I have just bought it, anyone have any specs on it? I can't seem to find any.
Marshall 4140 2x12" combo from 1979.
JL mayze is offline   Reply With Quote
Old 01-04-2009, 11:06 PM   #2
steelhorse
Senior Member
steelhorse's Avatar
Re: Marshall 4140
You must mean the 4104:
Marshall JCM 800 Series Amplifiers
__________________
www.ricojronline.com
760-956-6619
Garmopat Pedal Mods
I wouldn't mind hearing your head smash through a glass door. That would be cool..." luekmeyer
steelhorse is offline   Reply With Quote
Old 04-02-2009, 05:23 AM   #3
disturber
Junior Member
Re: Marshall 4140
If you mean the fawn brown 2x12 Marshall 4140 Club & Country, then you just picked up a great & rare Marshall combo.
This amp was Marshall's take on the Fender Twin. It was aimed at the Nashville market, for tele and steel guitar players mainly. When it was released in the late 70's it was the most expensive amp to develop that Marshall had ever done up to that date.
It has two channels, one with a reverb that sounds like it is from heaven, and one non-reverb channel.
The amp came loaded with gold lion KT77 tubes, hard to come by today. But JJ makes a good KT77 substitute. You should use these tubes instead of EL34's, as they are what the amp was designed for originally.
I use my 4140 mainly for clean sounds, but it can sound pretty dirty with an original Marshall Guv'nor pedal in front. It does not overdrive so well on its own, it rather creates a fuzzy distortion.
Alex Lifeson used two of these combos to create his best guitar sound so far, on the most legendary Rush albums. He also used them a lot on tour, even way after he stopped using them in the studio. Think the famous Tom Sawyer riff, that is the sound of his two 4140's.
Stevie Ray Vaughn also used one of these amps for his clean sounds, earlier in his career.
Neil Giraldo from Pat Banetars band also used these amps.
If you still have the original red framed speakers in the amp you should change them out for something better. They were the amps only weak point. That is if you are not one of the lucky few who scored the 4x10 version with Celestion speakers.
These amps looks super cool and sound great. Just don't expect to get the ordinary Marshall tone of them. They are different beasts. If you want a Twin amp with more muscle, then this it it!
Feel free to mail me through the profile if you have more questions, as I see you are a fellow Swede.
disturber is offline   Reply With Quote
Old 04-30-2009, 10:41 PM   #4
kelly briggs
Junior Member
Re: Marshall 4140
If you mean the 4140 Fawn/straw amp, then you have a goldmine on your hands. This is the first amp I ever owned and have found it difficult to use anything else in the 24 years since. I usually run the dry side with effects and keep the reverb/boost side clean. I was using this for clean sounds and a JCM800 2204 w/4x12 for my drive sounds with an a/b box switching them. Got more than a compliment or two on that setup.
Unfortunately that amp weighs about 80 lbs and doesn't come with casters. My Carvin 4x12 didn't have casters either. Pretty much killed my back lugging that stuff around
kelly briggs is offline   Reply With Quote
Old 08-06-2009, 10:26 PM   #5
tarznamps
Senior Member
tarznamps's Avatar
Re: Marshall 4140
My amp has 6L6's in it.
Did all 4140's come stock with KT77? Can you substitute KT77 with 6L6 tubes or do you have to do some mods?
I hope who ever put in 6L6's did it correctly. How would I know if the 6L6 are in properly?
__________________
Tarz-N-Amps
MARSHALLS
Heads - 6100LM, DSL15H, JVM410JS, 2555SL, JVM1, DSL1, JCM1, JMP1, JTM1, JMD1, YJM100, AFD100, JVM210, JTM45, DSL100, JCM800 2203 & 2205, JCM900 4100, VM2466, 1974, 1987x, Haze15, C5H
Cabs - 1960AX/BX, 1960A/B, 1960AV/BV, 425A/B, 1965B, 1936, Haze A/B, C5 A/B
Combos - SL5, Class5, JMP4140 Club & Country, DSL401, JCM900 4501, JTM615
tarznamps is offline   Reply With Quote
Old 09-17-2009, 08:19 PM   #6
tarznamps
Senior Member
tarznamps's Avatar
Re: Marshall 4140
BUMP - Does anyone know about which tubes should be in this? Since I have 6L6's, how do I know if those are the correct ones?
__________________
Tarz-N-Amps
MARSHALLS
Old 08-22-2010, 06:11 PM   #7
Hazysun
Junior Member
Re: Marshall 4140
Hey eveyone...oh dear, hope you're not all dead or something as it's taken me all this time to find you.
I've also got two of these beauties although one of them is the prototype and comes with a dark brown grill-cloth and the McKenzies are not coloured red either.
They are amaaaaaaazing amps and I just wish that I lived somewhere where I could crank them up
I was thinking of investing in an Axe FX processor (for convenience) and was working out what I could get rid of in order to raise the cash....just can't bear to part with these beauties, they really are quite unique.....I was a huge Alex Lifeson fan but as soon as I got these amps I started to look for (and find) amazing sounds of my own.
I don't really care who's used them anymore, if you see one then buy it...you won't be sorry....they sure help you soul to sing.
Hazysun is offline   Reply With Quote
Old 04-07-2011, 02:03 PM   #8
Brad key
Junior Member
Re: Marshall 4140
I have one of these 4140's on lay away and don't know if it needs fixing. Should I put the money into it and restore it?
Brad key is offline   Reply With Quote
Old 06-15-2011, 05:17 PM   #9
Hazysun
Junior Member
Re: Marshall 4140
Yes Yes you most certainly should...but if you have the original red McKenzie speakers my advice would be NOT to change em. These amps are clean but rich and wonderful. You can get a nice crunch just at the point that the amp starts to break....combine that with a great distortion/fuzz/overdrive and your squarewave dreams are realised. Add a little modulation and or just use the built in reverb.
A very wonderful amp indeed, it is one of those rare amps that helps you to be yourself and to become your own favourite musician.
Old 09-23-2011, 09:35 AM   #10
guitarwolf
Junior Member
Re: Marshall 4140
what were the original tubes for the 4140 combo amp (1980 )
EL34 or 6550 ?
guitarwolf is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
