MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 05-31-2011, 08:36 AM   #1
shredless
Senior Member
shredless's Avatar
Passive Crossover for Speaker Cabinet
How will a Marshall tube amp (or others) react to a passive crossover being installed at speaker level?
Thinking I could build a couple different ones to recreate the EQ curve of different speakers
say I have V30s and want to mimic the EQ of a Greenback or 75
Ive built many for audio use and have all the parts...just curious how a guitar amp would respond
Anyone know the EQ differences between a V30 and a Greenback
I know breakup and other factors cant be mimiced...but the overall eq is what Im after
thanks
shredless is offline   Reply With Quote
Old 05-31-2011, 06:15 PM   #2
shredless
Senior Member
shredless's Avatar
Re: Passive Crossover for Speaker Cabinet
I guess I should rephrase the question
How would a tube amp respond to a speaker load that had a cap or choke in its path?
Would it be fine or cause damage?
Tube amps are used in audio apps all the time, with crossover networks to seperate freqs
I would basically be creating a notch filter or two to change the response of the output
Old 05-31-2011, 06:18 PM   #3
shredless
Senior Member
shredless's Avatar
"They" say that a V30 has a mid spike that is annoying, or the 75 has a dipped midrange
Well what if you had a switchable speaker level box that changed the eq curve to mimic these different speakers
would it work or fail
Old 05-31-2011, 07:52 PM   #4
IbanezMark
Senior Member
I have no answer to your question, but it sounds like an interesting idea!
IbanezMark is offline   Reply With Quote
Old 06-01-2011, 10:45 AM   #5
shredless
Senior Member
shredless's Avatar
Maybe if you started with a G12K100 or something more neutral?
Old 06-03-2011, 09:25 AM   #6
marvar
Senior Member
marvar's Avatar
first off- passive crossovers/filters suck up alot of power, therefore, changing your over all tone-
I would think putting a 8/10 band graphic eq somewhere in line or in your loop would be a more workable solution.
marvar is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
