MarshallForum.com
Reply
Thread Tools Display Modes
Old 04-11-2011, 01:21 PM   #1
mike_pittsburgh
mike_pittsburgh's Avatar
I'm ready to sell it all this bull**** & start over
I'm looking for some opinions from you grizzled tone masters to get rid of my **** gear and pick up something that will serve me well the rest of my miserible life.
I'm looking for an amp that can do early Allman Bro's to Jethro Tull type distortion.
I think my dream rig would be a plexi, a twin and an a/b box, but that is way too much amp for my needs.
Maybe if you guys can suggest an amp to pair up with my Fender blues jr that would cover the overdrive tones that I'm looking for, that would be cool.
I play mostly at ***** volumes, like 90% of the time.
My budget would be $1,000 or under.
Any amp suggestions would be appreciated.
mike_pittsburgh is offline   Reply With Quote
Old 04-11-2011, 01:29 PM   #2
charveldan
Banned
Location: Somewhere with a Friedman Marshall & Les Paul.
Re: I'm ready to sell it all this bull**** & start over
You can pick up a used DSL 50 watt for $6 to & $800 but they're not ***** amps.
They have a nice clean channel.
charveldan is offline   Reply With Quote
Old 04-11-2011, 01:34 PM   #3
Ydna
Senior Member
Ydna's Avatar
http://www.ceriatone.com/productSubP...assCabinet.htm
Duane Allman used a 1968 50 watt plexi. Bass specs. That one, completely assembled with a head cabinet is $895 plus $ for shipping 172. If you have a cabinet, and if you can push $1,000 a little bit, that would be the way to go. You can have them put a master volume in it so you can get it at any volume you like, it wont sound fantastic, but when you crank it up with a nice Les Paul, that'll be the tone.
The other thing you could look at for quiet volumes would be the new class 5. It wont nail it perfectly, but it would be quiet, and sound good. Throw a few pedals in front of it. Would sound really good.
Ydna is offline   Reply With Quote
Old 04-11-2011, 01:58 PM   #4
plexilespaul
Senior Member
plexilespaul's Avatar
get yourself an early 80's 4010 combo or a late 70's jmp combo and you will never look back these babies got tone!
plexilespaul is offline   Reply With Quote
Old 04-11-2011, 02:39 PM   #5
JayCM800
Senior Member
JayCM800's Avatar
So get a Class 5! "mini-plexi"
a/b/y box and your Blues Jr.
That should do it!
JayCM800 is offline   Reply With Quote
Old 04-11-2011, 02:43 PM   #6
ynot
Senior Member
ynot's Avatar
I'd say a used 1974x but that would probably still be over your budget & most likely too loud.But it would get you what you want,no need for the twin.Maybe a clone/kit with power scaling or MV though.I haven't played a Class 5 but it's on my to do list for a home use amp.
__________________
1987x
6100
18 watt TMB
Fender Bassman LTD
JCM 900 1960 cab
Avatar 2x12
Power Brake
Bunch of Les Pauls
ynot is offline   Reply With Quote
Old 04-11-2011, 02:55 PM   #7
DirtySteve
V.I.P. Member
DirtySteve's Avatar
1 more vote for the Class 5 here. At least try one out.
__________________
I wish I could give you a '****' for that...
Quote:
Originally Posted by Swede View Post
Lot of very NOT rock n roll folks here....
DirtySteve is offline   Reply With Quote
Old 04-11-2011, 03:10 PM   #8
rockinr0ll
Senior Member
A Plexi or Twin is way too much amp. The Fender Hot Rod Series is really good. I'm getting one and I own a Marshall '72 Lead 50 watter.
rockinr0ll is offline   Reply With Quote
Old 04-11-2011, 03:32 PM   #9
Ydna
Senior Member
Ydna's Avatar
Well, maybe a plexi will inspire him to find more oppurtunities to crank.
There is no substitute for a nice plexi if that is the sound you want.
Old 04-11-2011, 04:16 PM   #10
mike_pittsburgh
Thumbs up Re: I'm ready to sell it all this bull**** & start over
Wow guys, thanks for the quick replies.
I will look into all the suggestions you were good enough to provide.
Thanks!
Old 04-11-2011, 04:19 PM   #11
DSL100 Dude
Senior Member
DSL100 Dude's Avatar
CLASS 5 FTW!!!!!
These little crank monsters have a ton of tone and will keep ya happy if your looking to jam without blowing out your ear drums.
DSL100 Dude is offline   Reply With Quote
Old 04-11-2011, 04:52 PM   #12
NewReligion
V.I.P. Member
NewReligion's Avatar
Sounds like you are on the right track Mike.
I suggest a Re-Issue. 1987X (50 watt small box) Marshall with an effects loop.
The effects loop is a must so that you can run a old Alesis/Yamaha/Lexicon etc.. reverb multi effect processor. The great thing is that you can use the Input/Output volumes of the processor to "attenuate" the volume. That is to say CRANK the amp for tone and set the volume level with the processor. This works very well. Then add additional OD with a pedal if you wish.
There will be those that say no it will cause artifacts "tone suck" etc... Seriously, that is BS. I use 100 watt half stacks at conversation levels by using this method and have done so for over 25 years. If you have any additional questions just send me a PM. I bought my 2007 1987X from used guitar center .com for $800 as a 10 out of 10.
Good luck and don't settle for less. By this method you WILL achieve studio quality tones in all of your live settings.
Think outside of the box!!!!!!!!!!!!!!!
David
NewReligion is online now   Reply With Quote
Old 04-11-2011, 06:17 PM   #13
peterichardz
Senior Member
peterichardz's Avatar
Quote:
I have recently played thru 4 different Hot Rod Deluxes at jam nites and they were ALL junk unless you use a pedal board into the clean channel.
I can't get MY sound from pedals as I'm spoiled playing a Gibson straight into a JMP 2204 and the gain channel on the fenders is just BAD.
__________________
The Sneaky Pete Band
www.sneakypeteband.info
Loud and Proud for 40 + years
2 '77 JMP 50 watt MV's
1 JCM 2000 DSL 50 Head
1 1960AX W G12M's
1 1960A W/ EVM12L's
1 Laney Straight cab W/ G12M-70's
1 1965A Modded & Loaded with 2 EVM12L's
1 112AVT Loaded with EVM12L
Seymore Duncan Convertible 100 watt
2 Gibson Les Paul Jr.s STOLEN
Gibson Les Paul Special
Gibson Firebird
Epi. Custom Shop Les Paul Jr.
Epi. Les Paul Classic Quilt Top
Epi. Korina Explorer
Epi. Les Paul Chamilien
peterichardz is offline   Reply With Quote
Old 04-11-2011, 09:28 PM   #14
nedcronin
Senior Member
nedcronin's Avatar
Agreed Pete! Those new Fender amps sure don't do it for me either. Thumbs Down!
__________________
Check out my Marshall Amp Lovers facebook page if you facebook....click below
Click Here if you love Marshalls!
Come Join the TSL Tribe!
nedcronin is offline   Reply With Quote
Old 04-11-2011, 09:31 PM   #15
Michael1987xl
Senior Member
Michael1987xl's Avatar
Quote:
Originally Posted by NewReligion View Post
....I suggest a Re-Issue. 1987X (50 watt small box) Marshall with an effects loop...
+ ten billion.
__________________
Call me "JonnyX"
What matters most is what you learn after you know it all.
2007 Marshall 1987xl MK II Vintage Re-Issue.
Univox 1221.
Kasino Model 802 (Make me an offer...please).
A few guitars and a couple of cabinets.
Michael1987xl is offline   Reply With Quote
Old 04-11-2011, 10:15 PM   #16
mike_pittsburgh
David
OMG, I thought I was full-o-****.
I ran an old processor like this for years, until it fried on me. Literally, I mean it had smoke rolling out of it and sizzling. (It died a noble death, as a warrior should.)
In any case, it was an old DSP128 that only had one usable sound, reverb. It had the input and output volumes that you are talking about and I got very usable tones out of my POS 3203.
Guess that is why I kept that rig all these years?
Oh man, I'm jump'in on used gear postings now.
Thanks man!
Old 04-12-2011, 09:08 AM   #17
wannabweiland
Junior Member
I'm going to get face-punched for this, but why not a Soldano Hot Rod 50? Warren Haynes has used Soldano stuff for Allman Bros forever. You can find 'em on craigslist for around $1000. Single channel, hi/low inputs, FX loop. Very cool. One of my favorite amps.
I would also like to +1 on the 1987x. Those are really sweet.
wannabweiland is offline   Reply With Quote
Old 04-12-2011, 10:33 AM   #18
mike_pittsburgh
Thanks man!
OK, Guitar center lists two in the used gear for around $1,000.
One on the local craigslist, but it didn't have the fx loop. (Still $1,000)
So technically, your suggestion of a 1987x fits the requirements that I specified.
I'm gonna go play a class 5 first. (cuz I'm a cheap bastard.) And because I don't have the chance to play a 1987x in the near future. I'll keep my eyes open, but I NEVER buy without playing first. (lesson learned from historic GAS.)
Regarding the Soldano, I never thought Warren got Dickey's tone? Maybe it's just me, but Warran's tone is much raunchier, with Dickey's more sweet and singing. Only talking about tone here. Warren is a great player and I was always a fan of gov't mule. (even when he played a strat)
BTW, you guys are great. Thanks for all the ideas!
Old 04-12-2011, 04:47 PM   #19
dave999z
Senior Member
I have a blues jr. in my living room as a low volume practice amp. I have a tubscreamer (ts-808 reissue) in front of it to get overdriven tones at low volume. And I really like it. It's nothing like my Marshall rig, but for practicing/writing, it's great. I disagree with the bashing on the new Fender amps. I paid $450 for my blues jr. iii (new), plus like $170 for the tubescreamer, and the tone out of that pair is phenomenal for the price.
dave999z is offline   Reply With Quote
Old 04-26-2011, 01:25 PM   #20
mike_pittsburgh
Question Re: I'm ready to sell it all this bull**** & start over
Hi all,
Been scanning local adds and saw a 1987x for sale. Contacted the guy and he thought the amp was already sold. Oddly he said that it did not have a "tone sucking" fx loop. Did they make such a reissue?
BTW, looks like the sale fell thru as he relisted for $950 (was $999).
sale-9dgs3-2340109347@craigslist.org
I would hate to spring for my dream amp without the "tone sucking" fx loop, as this was the means I wanted to use to tame the volume. (instead of a "tone sucking" attenuator.)
What reissue is this and do you guys think it's worth $950?
Old 04-26-2011, 01:27 PM   #21
IbanezMark
Senior Member
The 1987X is the reissue without a loop, the 1987XL has a loop.
IbanezMark is offline   Reply With Quote
Old 04-26-2011, 01:31 PM   #22
Bieling3
Senior Member
Bieling3's Avatar
Hi all,
Ya, that's a decent price:
1987x musical instruments : craigslist eBay kijiji mash : United States
Get it and throw in a zero loss loop...
__________________
Tone is in the instruments. Technique in the hands. Do what you will.
Bieling3 is offline   Reply With Quote
Old 04-26-2011, 01:53 PM   #23
Michael1987xl
Senior Member
David
What he said.
__________________
Call me "JonnyX"
Univox 1221.
Old 04-27-2011, 07:59 AM   #24
Alabama Thunderpussy
Senior Member
Alabama Thunderpussy's Avatar
My vote goes to a Fender Bassman just for variety's sake. Everyone else seems to recommend the Plexi.
__________________
For your amps, ya dingus.
Alabama Thunderpussy is offline   Reply With Quote
Old 04-27-2011, 08:01 AM   #25
ynot
Senior Member
ynot's Avatar
Quote:
Originally Posted by Alabama Thunder***** View Post
My vote goes to a Fender Bassman.
Got one,love it.but it ain't no plexi.There's a certain magic in that amp.
__________________
1987x
6100
18 watt TMB
Fender Bassman LTD
JCM 900 1960 cab
Avatar 2x12
Power Brake
Bunch of Les Pauls
Old 04-27-2011, 08:08 AM   #26
Senior Member
There's no magic. It's a Bassman circuit topology with different transformers and a few component value changes. People do that much to a DSL.
__________________
Old 04-27-2011, 08:15 AM   #27
ynot
Senior Member
ynot's Avatar
Wanna mod my bassman into a plexi combo for me then (seriously,not sarcasm)?
__________________
1987x
6100
18 watt TMB
Fender Bassman LTD
JCM 900 1960 cab
Avatar 2x12
Power Brake
Bunch of Les Pauls
Old 04-27-2011, 08:24 AM   #28
Senior Member
I totally would, but I'm going to be unfathomably busy starting the end of this month. I'm actually rushing to finish a job now.
PM Lane Sparber or Jon Wilder and see what they might be able to do for you.
__________________
Old 04-27-2011, 09:04 AM   #29
ThePoppster
CLASS 5 ALL THE WAY!!!!
ThePoppster is offline   Reply With Quote
Old 04-27-2011, 12:44 PM   #30
DSL100 Dude
Senior Member
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
