MarshallForum.com
Go Back   MarshallForum.com > The Amps > Cabinets & Speakers
Reply
Thread Tools Display Modes
Old 03-30-2011, 02:50 PM   #1
noise5150
Senior Member
Can I replace a 4 ohm stock speaker with an 8 ohm speaker in my 1x12 combo?
I want to replace the stock speaker in my MG100dfx 1x12 combo. The back the amp says 4 ohm (I wrote Marshall and they confirm 4 ohms) but I want to know if I can replace the stock MG speaker with a HM75 Warehouse Guitar Speaker and they only carry 8 and 16 ohm speakers. Can this be done considering the difference in the ohms? Oh and since Im on this topic, I also sometimes run that amp through my 8ohm 2x12 Avatar cab and it sounds great. I disconnect the internal speaker wire and then just use a good speaker cable to hook it up to the Avatar. Is this ok? because on the back of the combo it says "minimum total Imp. 4 ohm".
noise5150 is offline   Reply With Quote
Old 03-30-2011, 03:20 PM   #2
chuckharmonjr
Senior Member
chuckharmonjr's Avatar
Location: About as far south in Alabama as you can go without swimming
Re: Can I replace a 4 ohm stock speaker with an 8 ohm speaker in my 1x12 combo?
Minimum is the key word in that phrase. With a solid state output section, the min number is the only one that counts. It would push 16 ohms as well. The only thing is you lose some of the rated power. Going from 4 to 8, your 100 watter would become roughly a 75 watter.
__________________
JCM2000 DSL100
JMD-1 100 Watter
JMP800 2204
Hughes and Kettner 18w
JTM 50
1960A
1960B
2061BX Clone
(2)Seismic Audio 2-12
Avatar V30 1x12
Joe B Sig Goldtop
Tobacco Burst Les Paul
Black Les Paul Custom
Honey Burst Les Paul
R8 Les Paul in Tea Burst
ES-175 in Cherry
EDS-1275 in White
Fender Strat in Tobacco Burst
http://soundcloud.com/chuck-harmon-1/woman
http://soundcloud.com/chuck-harmon-1/webs-and-dust
chuckharmonjr is online now   Reply With Quote
Old 03-30-2011, 03:24 PM   #3
noise5150
Senior Member
Ok so if I put an 8ohm speaker in there as a replacement that should be ok as well as running the combo through my 8 ohm 2x12?
Old 03-30-2011, 03:29 PM   #4
chuckharmonjr
Senior Member
Actually if you put an 8 in the combo, and also run the 8 ohm cab, your load would be 4 ohms overall which is perfect. You'd be perfectly fine putting an 8 in there.
__________________
JCM2000 DSL100
JMD-1 100 Watter
JMP800 2204
JTM 50
1960A
1960B
2061BX Clone
Avatar V30 1x12
Joe B Sig Goldtop
ES-175 in Cherry
EDS-1275 in White
Old 03-30-2011, 03:30 PM   #5
Adwex
Super Moderator
Adwex's Avatar
Yes. What Chuck said.
Old 03-30-2011, 03:35 PM   #6
noise5150
Senior Member
Quote:
Hey just to be clear, there is only one output on the back of the combo so I either have to use the internal speaker OR disconnect that and hook it up to the 2x12 Avatar so I just want to make sure thats ok. But it sounds like installing an 8ohm internal speaker is ok from what you guys are saying.
Old 03-30-2011, 03:58 PM   #7
Adwex
Super Moderator
Adwex's Avatar
Yes, it's ok. Solid state amps are a different animal than tube amps, it's ok to connect speakers of different impedance, the only thing that is affected is the power output. So like Chuck said, if you connect an 8 ohm speaker, the power output is reduced. A four ohm speaker will produce the maximum power the amp is capable of, any lower impedance will damage the amp...that's why solid state amps have a minimum safe speaker load, and are vulnerable to speaker cable shorts...if you short circuit the speaker wires, that equals ZERO impedance, and is a sure fire way to fry something.
It's the opposite for a tube amp. Tube amps don't like higher impedances than they "expect", so if the amp sees an open speaker circuit, it can be damaged.
Old 03-30-2011, 04:05 PM   #8
Georgiatec
V.I.P. Member
Georgiatec's Avatar
Quote:
Can you use a 2 into 1 jack connector to run both?...or wire the internal speaker so it's always on and just use the input for the Avatar?.
Georgiatec is offline   Reply With Quote
Old 03-30-2011, 04:10 PM   #9
noise5150
Senior Member
Quote:
I dont know but I probably would only run it one or the other because when I'm home if I use the MG, Ill plug it into the Avatar. The only time Ill use the MGs internal speaker is if I bring it somewhere to jam.
Old 03-30-2011, 04:12 PM   #10
chuckharmonjr
Senior Member
Yes you could do that Georgia. Add a 1/4 inch jack and wire it in parallel with the existing jack. I believe the 100 watt head version of the MG series has just that arrangement.
__________________
JCM2000 DSL100
JMD-1 100 Watter
JMP800 2204
JTM 50
1960A
1960B
2061BX Clone
Avatar V30 1x12
Joe B Sig Goldtop
ES-175 in Cherry
EDS-1275 in White
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
