MarshallForum.com
Reply
Thread Tools Display Modes
Old 03-24-2011, 02:02 AM   #1
thinlizzy96
Senior Member
thinlizzy96's Avatar
Question Do i need to Re-Bias my amp if i replace the tubes with the same type?
Say I was to replace my tubes and I replace them with the same exact type/model, do i need to re-adjust the bias?
thanks!
thinlizzy96 is offline   Reply With Quote
Old 03-24-2011, 02:25 AM   #2
T-Bird
Senior Member
Re: Do i need to Re-Bias my amp if i replace the tubes with the same type?
Hi.
Ideally no, but You should always check the bias in any case and adjust if necessary when changing power tubes.
Mesa claims are mostly BS and so are GT claims as well when it comes dow to the need (or the lack of it ) for re-biasing after a tube change, if that's what You're wondering.
Talking about A/B PP fixed bias circuit mainly, obviously. On class A SE it shouldn't be necessary. If the same type of a tube is used.
Regards
Sam
T-Bird is offline   Reply With Quote
Old 03-24-2011, 02:45 AM   #3
thinlizzy96
Senior Member
Thank you so much!
so essentially it isn't completely necessary if i'm using the same type, but occasionally it'd be good to check to make sure?
Old 03-24-2011, 03:18 AM   #4
thrawn86
Senior Member
I would check them.
__________________
-Martimus Maximus Tone Packs - MHD Pickups - OFA Pedals-
thrawn86 is offline   Reply With Quote
Old 03-24-2011, 03:20 AM   #5
thinlizzy96
Senior Member
i guess it couldn't hurt!
thanks!
Old 03-24-2011, 04:30 AM   #6
Wilder Amplification
Senior Member
Wilder Amplification's Avatar
ALWAYS CHECK THE BIAS WHEN REPLACING OUTPUT VALVES!!!
"Theoretically", if you get valves that have identical matching numbers (i.e. PC and TC numbers) to the ones you're replacing, the bias SHOULD be perfectly adjusted for the new set. However, there is the human factor, and when there's the human factor, you remember really quick that we don't live in a perfect world. Who's to say the matching was done correctly? Who's to say the valves got the correct labels on them? Who's to say they didn't end up in the wrong box with the wrong labels on the box?
You do not know with 100% certainty unless you have the bias checked. Just like you check all your bearing clearances, degree the cam, check the ring gaps, valve to piston clearance, valve train geometry, etc etc when you build a performance motor so that you know with 100% certainty that everything is right on the money, you ALWAYS ALWAYS ALWAYS check the bias when replacing output valves. Plain and simple.
__________________
Jon Wilder
http://www.wilderamps.com
Old 03-24-2011, 10:56 AM   #7
Ron Meersand
Senior Member
Ron Meersand's Avatar
Send a message via Yahoo to Ron Meersand Send a message via Skype™ to Ron Meersand
See this amp:
Had E34L JJ tubes in when It was brought to my shop.
I put all new E34L in same tubes but different bias point and 3 were labeled #49 while one was labeled #48 in the next photo you will see the difference in the bias point of one.
you will see from the read out that at this set up V8 is doing 15.8 watts @ 34ma and the odd tube out is only making it to 13.5 watts @ 29ma
BTW V6 & V7 are spot on with V8 This is a very good reason to bias every time you replace your power tubes this type of circuit tends to drift over time.
I could not have replaced this amps tubes with out testing and adjusting the bias even though I was replacing the same tubes.
The old tubes were running at some crazy 57ma and of course one of the old tubes was bad and had low Emission under 20% a good tube is 80-100%.
This amp has switch's on the back to switch tubes this does not work I don't know what this designer was thinking. Any way it's not Marshall but it gives you and idea.
(I hope this keeps it simple enough for you)
Best of Luck,
Ron
Ron Meersand is offline   Reply With Quote
Old 03-24-2011, 02:09 PM   #8
thinlizzy96
Senior Member
thanks for all the detailed posts guys!
yeah i'm definately gonna bias it, or get someone to do it for me considering i have never had to change tubes before
Old 03-24-2011, 02:36 PM   #9
Senior Member
I'm gonna add a side note here for those who aren't yet in the know but are still learning.
The wattage figures that Ron is talking about are what the valve itself is dissipating in a quiescent (i.e. "idle") state. This says nothing about what the load is dissipating which is very little compared to what the valve is dissipating in a quiescent state.
Furthermore, this also says nothing about what the load will dissipate when the amp is putting out a full clean power signal.
The valve dissipation will increase when hit with an input signal. Assuming a full power clean signal, valve dissipation will be at its highest when the signal is at 1/2 the peak swing, then dropping down to its lowest at the peak of the swing. This happens because most of the power is being transferred to the load and the voltage across the valve is at its lowest, while being at its highest across the OT primary, yet current is the same through both the OT and the valve (current is the same at all points of a series circuit).
What does this mean? This means that "plate dissipation" and "output power" are not one and the same like most tend to think. People ask all the time "How can you get 50 watts out of a 25 watt valve?". That's because plate dissipation power and output power to the load are not the same thing. Furthermore, power does not come from the valves. It comes from the "power supply" (hey...maybe THAT'S why they call it that!). The power supply draws current through both the valve and the OT primary, while the valve is just a metering device that meters this current based on the input signal that is fed into it. Think of the input signal as a "control signal". The greater the amplitude of the input signal, the more the valve opens to allow the power supply to draw more current through the OT primary (wow...is that why they call it a "valve"???).
__________________
Jon Wilder
Old 03-24-2011, 02:46 PM   #10
thinlizzy96
Senior Member
wow thanks for all the info!
Old 11-02-2011, 03:58 PM   #11
dezzy
Junior Member
Not sure U could mistake a 6l6 tube for an EL set, most marshall amps carry ELs
dezzy is offline   Reply With Quote
Old 11-02-2011, 06:13 PM   #12
chuckharmonjr
Senior Member
chuckharmonjr's Avatar
Location: About as far south in Alabama as you can go without swimming
Not a question of 6L6's vs. EL34's Dezzy. EL34's can vary widely all over the map. Thats why you always re-bias with a new set.
__________________
JCM2000 DSL100
JMD-1 100 Watter
JMP800 2204
Hughes and Kettner 18w
JTM 50
1960A
1960B
2061BX Clone
(2)Seismic Audio 2-12
Avatar V30 1x12
Joe B Sig Goldtop
Tobacco Burst Les Paul
Black Les Paul Custom
Honey Burst Les Paul
R8 Les Paul in Tea Burst
ES-175 in Cherry
EDS-1275 in White
Fender Strat in Tobacco Burst
http://soundcloud.com/chuck-harmon-1/woman
http://soundcloud.com/chuck-harmon-1/webs-and-dust
chuckharmonjr is offline   Reply With Quote
Old 11-02-2011, 11:50 PM   #13
mrrstrat
Senior Member
mrrstrat's Avatar
Great info on this thread for you!
When it comes to replacing a grade of tubes with the same and not rebiasing...
Its YES if:
(1) Not a lot of time elapsed since tube change (weeks, normal playing)
(2) You know the tubes are from the same batch and the grading is good
(3) If you dont bias at the upper end of idle dissapation (see above posts for definition of this)
(4) You dont mind rebuilding the power section if a tube fails, or giving your local tech something to do for an hour of so and some money
Its NO if:
(1) You have significant time between changes (component degradation is NOT at a known constant, neither is what true state of the amp since the last time you retubed)
(2) You have significant play on the amp since last change (again, the wear uncertainty thing)
(3) You have amp idle biased 'at the upper end' (like above 70%)
(4) You value your amplifier and dont think the risk is worth not spending 20 bucks for a rebias
(5) You cannot fix the amp
Its a risk/reward thing. I rebias my own gear because I can every time, and I like to observe the component wear to understand the natural progression of wear first hand.
__________________
Guitars:
* Gibson Les Paul Traditional
* USA Fender Telecaster, USA Strat
* 1979 Peavey Duce
* 2003 Marshall DSL 100
* Fender Hot Rod Deluxe
DiMarzio:
* Virtual Vintage Solo DP-404, 420, Heavy Blues 2
* PAF Joe, PAF Pro, PAF DP103, ToneZone DP155
* ClipLock straps, DiMarzio cables
Sponsor:
* http://www.dimarzio.com/player/michael-rogers
mrrstrat is offline   Reply With Quote
Reply
Tags
1959 super lead, bias, tubes, valve, valves
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
